Question about Lexmark Z1420 Printer
I turned on my printer and its makin a noise and the WIFI light is not on
    Problem Solver:
  • 10 Answers
Open Control Pannel and click on Connect Wireless while your printer is on and reasy to use, the noise your hearing is the slide bar inside going back & forth, it normally does this when newly installed or when new ink is put in.
Is this printer new? have you used it before?
After clicking connect wireless, click setup wizzard, this will take you through steps to find your printer (sometimes finds it automatically) pick it from the list of printers it gives you (yours), before you do this dissable Firewall & Antivirus (these somtimes stop connections especially WiFi security reasons).
Pick your printer - Set up and away to go - happy printing.
I hope this solves your problem it did for me on two different printers - good Luck ;-)
Steve
Posted on Jul 15, 2009
Car makin noise
could be drive shaft
Jun 06, 2012 | 2005 Ford Expedition
How to turn off wireless of samsung color laser printer clx-3185FW
The manual doesn't specifically state this but it appears that if the printer is connected to a wired LAN connection the wireless function will be disabled if the printer is set up in infrastructure mode. When I tried this the 'wireless' light turned off and I wasn't able to find the printer's WiFi SSID using a nearby netbook. If your goal, like mine, was to disable the printer's WiFi from transmitting to reduce extra WiFi noise then this seems to work. One of the wireless troubleshooting tips in the manual states to disconnect the wired connection before attempting to set up a wireless connection so it appears the two can't be used simultaneously. It seems odd that there's no specific "off" setting for wireless though. The printer will provide a WiFi connection when also connected to a wired LAN port if it is set up as part of an ad-hoc wireless network so make sure you set it to 'infrastructure' mode to disable WiFi.
Feb 11, 2011 | Samsung CLP-315W Laser Color Printer
The left rear wheel is kinda makin a knockin noise but at first it was kinda makin a howl noise a few weeks ago
bearing in wheel more than likely faulty
solution jack car up and see is there play in wheel
Jan 28, 2011 | 1998 Mercury Mystique
Brakes makin nosie
Sounds like a wheel hub assembly is bad without seeing it. Alot of GM vehicles have the ABS wheel speed sensors built into the hub assemblies. Should be able to narrow the noise down by driving the car slightly turn left and right noise should change from loud to soft when turning the wheel. ( if you turn left and noise gets louder hub on right front is noisey.Opposite will occur if left side is bad)
Jul 31, 2009 | 2002 Pontiac Aztek
Check engine light,'99 beetle
Have you had your brake light sensor replace. They have a recall on it. Change out your drive belt and it should make the noise go away. As long as it's cooling(a/c) i would not change compressor.
Jul 17, 2009 | 1999 Volkswagen Beetle
Bmw 330d noise scremin and smokin when rev and loss of power
Sound like you have no boost. Turbo or actuator faulty
Mar 26, 2017 | 2001 BMW 330
My printer keeps jamming paper, and making a lot of noise
Try taking the imaging unit out (as per instructions in the manual) dusting around in the cavity and putting it back in again.
Nov 03, 2008 | Samsung CLP 300 Laser Printer
LOUD RATTLING NOISE
check out for any oil leakage...
May 28, 2008 | 1997 Toyota Camry
Lexmark Z1420 Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
