The easiest way (if enabled) is to use the voice menu as if you would assign a new IP to the device.
- Connect a telephone to one of the FXS ports. Lift the handset and dial ***12345 (three stars followed by the digits 1, 2, 3, 4, 5).
- Wait for the 'configuration menu' voice prompt to be played.
- To change the IP address, press 1 followed by the pound key (#).
- The current IP address of the gateway is played. Press # to change it or hang up if you don't want to change it.
- Dial the new IP address; use the star (*) key instead of dots ("."), e.g., 192*168*0*4 and press # to finish.
- Review the new IP address, and press 1 to save it.
Of course you can try the default IP of 10.1.10.10 if the device is set to it's default standards.
If not, you can try a network scanner like angryip (
link) or network scanner (
link) - this might take a long time, since the IP can be virtually anything.
If you have physical access to the device, you can also use a straight RS-232 cable to connect the AudioCodes to your PC and use HyperTerminal to connect (Baud Rate: 115,200 bps (MP-124), 9,600 bps (MP-11x), Data bits: 8, Parity: None, Stop bits: 1, Flow control: None)
If you need the manual (and it never hurts ;-) here is the link:
http://www.audiocodes.com/filehandler.ashx?fileid=36320If you have any more questions, just come back here and leave a comment - I'm happy to help.
