Stuck on drain cycle, not spinning and timer is not working. Tried switching off machine. Cleaned filter, checked water inlet. Switched back on, still the same and cannot cancel to reset?
SOURCE: Machine won't wash but will spin
If your washer doesn't agitate, check these:Lid switchMotor couplerBeltsClutchDrive motorDrive pulleysTransmissionAgitator good-day !
SOURCE: beko not draining and spinning
This means to just restart the wash cycle. But I say the culprit is the lid safety switch. Make sure it is not stuck. This is the main reason washers will not spin.
Check your exit hose spigot, it may be clogged. This is if your filter is all clean (ref manual). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Also must check water level device,if You do not know what is this or where is on machine then call a service.Maybe the hose is precipitate from device.
There is a capacitor in the top of the machine to check/ replace and connections from the timer to check.
SOURCE: beko washing machine not draining
If the drain hose is stretched too much to reach the standpipe, the hose can pitch.
