Question about Precor 9.21 Treadmill
Turn on switch, but nothing including the electronics do not come on
    Problem Solver:
  • 18 Answers
Should be the switch or the cable or may be no voltage present on the outlet wall. you can try connecting another electrical apparatus in the plug if this it works well, so you may be call a tenchnician for this inspection the lower board or the switch.
I hope that this helps you in something
Posted on Jul 15, 2009
How do you locate and test flasher relay on a 2006 Chevy Equinox? Turn signals and hazards stopped working after changing audio system. Fuses test good. Thank you, Mike
Did you change any wiring , tap into any wiring ? There is no flasher relay on your vehicle . It controlled by the BCM !
Turn Signal/Hazard Lamps
The body control module (BCM) is responsible for controlling the turn signals and hazard lamps. When the turn signal switch is placed in either the left turn or right turn position, the BCM receives a signal from the turn signal switch. The BCM then sends an on-off voltage signal to either the left or right turn signals and their instrument panel cluster (IPC) indicator. When the hazard switch is pressed, the BCM receives a signal from the hazard switch. The BCM then will send an on-off voltage signal to all the turn signal lamps. All the turn signal lamps will flash including both IPC turn signal indicators.
Your best bet , take it to a qualified repair ! We on here have no clue what you did . On this newer vehicles ,if you know nothing about automotive electronics you really should take to a professional
Aug 10, 2017 | Cars & Trucks
The tv does not turn on when switching on?
power supply board faulty......
cheers
Dec 04, 2016 | Televison & Video
My rear turn signals are not working. front turn signals work rear parking lights work brake lights work
In the diagram for rear lamp, the top wires are voltage, the bottom black wire is ground. The brown wire on either side should be tail lamps, goes hot when you turn on the headlamp switch. The other top wire on either should be for turn signal. With everything turned on, is there voltage on that wire?
Because the front works and the rear don't, possible wiring circuit problem? The voltage for turn signals comes from bcm. The bcm knows when you turn on turn signal switch, either side, then the bcm sends voltage to turn signal lamp at the rear and front.
Oct 17, 2016 | 2009 Chevrolet Chevrolet HHR LS
Where is the blinker relay in my 2011 Chevy Equinox.
PCB Relays
This vehicle is equipped with the following printed circuit board PCB mounted relays.
• High beam
• Low beam
• DRL
• Fog lamp
• Park lamp
• Stop lamp
• Horn relay
They are directly soldered to the underhood fuseblock circuit board. A failure of one of these relays will require the whole under hood fuse block to be replaced.
Vehicles are just not the same as they use to be. Electronics !!!!!
Sep 25, 2015 | 2011 Chevrolet Equinox
ESC OFF is switch on
Yes, and press the switch and ESC will turn on. The switch enables or disables the ESC. When you turn off the vehicle and turn it back on, the ESC will automatically turn on regardless of whether it was on or off when you last turned the car off. If you want to keep the ESC disabled, you will need to push the button each time you start the car. The ESC is not the ESCape hatch. It is the Electronic Stabilization Control. This is a computer operated system of interworking devices that help keep the car stabilized and driving correctly. It includes the antilock braking system, the antiskid system and the traction control system (if equiped).
Mar 08, 2014 | 2006 Hyundai Sonata
Range rider bugy with a kawasaki fc290v electronic ignition with a fully charged battery i turn the key and get nothing any ideas ?
I would say you should check to make sure you are getting juice to the starter when you are trying to start it. This can be done with a simple voltmeter or 12v light tester. If you are getting juice, then the issue seems to be a bad starter. If you are getting juice the it could be the solenoid, ignition switch or a simple loose connection. I will be more than happy to help you get this up and running. First start by testing to make sure you have juice going to the ignition switch and the starter when you turn the key.
Jun 25, 2012 | Cars & Trucks
I turn the electronic switch and the 4 wheel drive does not ingag
replied to your other posting
http://www.fixya.com/cars/t3676989-turn_electronic_switch_4_wheel_drive_not
Dec 20, 2009 | 2006 Ford F-150
Baterry goes dead fast even after charging it all night
Electronics like this have their power regulated by a soft switch that depends on electronics to turn on and off the juice. (In other words, a mechanical switch is not used.) These sometimes go bad in that they "leak" and don't turn off completely. Your battery then takes a hit. . The solution is to have it sent off. The repair center probably does nothing more than replaces the entire circuit board.
Nov 25, 2009 | Nextar MA797 MP3 Player
Precor 9.21 Treadmill Logo
202 people viewed this question
Top Precor Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Shehu Pro
Shehu Pro
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
