Question about Water Pik Aqualink Rs4 Package - Pool and Spa Combo
Why does the spa empty when the pump shuts off? just got a pool with an aqualink RS4 and no manual to look at. thanks
    Problem Solver:
  • 6 Answers
This problem can be caused by a couple things. the two most likely culprtits are either the absence of check valves and or incorrect actuator settings when the pump shuts down.
Your spa is most likely higher than the pool. You most likely have a spill over (waterfall) feature from the spa into the pool. This is so the spa water can be recirculated in pool mode. One of your actuator valves may be slightly off closed position in order to allow spill over in the spa, or you may have a dedicated overfill pipe in the circuit to feed water to spa in pool mode.
Whichever spill over piping you have set up, when the pump shuts down, water from the spa ( higher level than the pool) will backfeed through the overflow spa circuit, back through the pump and into the pool through either drain or return. Effectively rendering your spa level the same level as your pool.
To fix this problem, simply install check valves into the spa runs and as a secondary measure put one into the pool return run ( the run that feeds water to pool).
This will insure that when the pump shuts down, no matter which position the valve actuators may be set, water can not back feed through the pump circuit from spa to pool.
Posted on Aug 23, 2009
  • Louie Reale Jun 07, 2013
    Can you send me a diagram showing where check valves need to be. I have a pool self cleaning spa above pool. It has been emptying into pool . I replaced check valve guts and still doing same thing . I think my actuator is at fault going past its setting. Please advise Thanks' Louie
Aqualink rs4 manual pdf
hit cancel after that shows up for each program that will get rid of them or you can write down all the information then hit clear memory and reprogram all you auxs
Aug 27, 2014 | Jandy Aqualink RS4 Pool/Spa Combo -...
My pool pump will not turn off automatically I have turn shut it down manually
Sometimes if two time setting overlap the RS will do what they call "ghosting" and any manner of odd thing may happen. Reset the timing for the main pump after clearing out all the other time programs. See if that works.
Sep 03, 2013 | Jandy Aqualink RS4 Pool/Spa Combo -...
Jandy Aqualink RS4 Filter pump relay switch location
relay behind lower panel above breakers with red and black wires to it
Apr 13, 2011 | Water Pik Aqualink Rs4 Package - Pool and...
How do i empty the spa into the pool?
Cycle through your valve settings until you get spa drain.
Nov 30, 2009 | Water Pik Aqualink Rs4 Package - Pool and...
Spa does not turn off.
There SHOULD be a valve that you can close to disable the spa.
Sep 27, 2009 | Jandy Aqualink Rs4 One Touch Control...
Water Pik Aqualink Rs4 Package - Pool and Spa Combo Logo
1,391 people viewed this question
Top Water Pik Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Water Pik Pool and Spa Expert? Answer questions, earn points and help others
