Question about Refrigerators
Excessive heat between doors of refrig & freezer sxs
  • 55 Answers
Hello. It sounds like the motor on the back of your unit, by the compressor has gone out. You will need to replace this motor and your problem will be solved. Send me the model number and I can get you the part number you will need to replace.
Posted on Jul 15, 2009
GE Side by Side Refrig - loud noise behind the ice maker section Model PSS25SGMB BS
it sounds like the evaporator fan blade is hitting some ice that has built up around the blades i have seen this happen a lot on g.e. SxS lately,if you can remove the ice maker and dispenser you can see the fan blade,if you dont want to do this then shut down the refrigerator and leave freezer door open and heat it carefully with a hairdrier to speed the process up to melt this ice then restart it and the noise should be gone
Aug 30, 2012 | GE PSS25SGNBS Side by Side Refrigerator
GE REFRIG GSS22JFMAWW Damper STAYING CLOSED AND REFRIG SIDE STAYING WARM BUT FREEZER IS OK
the damper door assy located in the upper left corner just left of the water filter of the refrigerator compartment probably has a broken damper door shaft on one side and has jammed in this position,this is very common with G.E. SxS I have glued these shafts back together with good success,but you may want to just replace it
May 07, 2012 | GE GSS22JFMWW Side by Side Refrigerator
The strip between the freezer and refrig door is extremely hot. Never felt hot before. It is not the door, but the refrig and freezer itself. The refrig is still cold and freezer is frozen.
The heat you are feeling is normal, I wouldn't worry too much about it. If you start having a problem with cooling you may want to look into getting a repair guy to look at it but many refrigerators will heat up in that strip between the fridge and freezer.
Dec 12, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Can't get water at the dispenser on a GE sxs
GSS25QMFC I beleive is manufactured by GE. The line could definitely be frozen. 99% of refrigerators you cannot get into the doors. They are glued together and filled with spray in insulation. There is no easy way to do it. You can try a hair dryer or just let the fridge sit for 24 hours turned off with the doors open. Another place to check for a freeze up is in the rear of the refrig section. Most refrigerators run the line in the refrigerator to chill the water and if your refrig section gets too cold they can freeze in there. Most of the time refrigerators have a disconnect in the water line at the bottom corner of the freezer door where it goes through the hinge. You might have to yank off the lower grill to see it, but you can sometimes disconnect it there and let water run out. Good Luck
Sep 11, 2009 | Refrigerators
GE SxS refrig. frosts up at ice dispenser
this is i moisture problem that we have down here in miami i see this all the time
report this to factory service i have found no quick fix
Apr 13, 2009 | GE Refrigerators
Hot Point Refrig.
this could have been due to leaving door open by accident so excess ice formed. water just evaporates with heat from the compressor
Sep 04, 2008 | Hotpoint FFA60 Bottom Freezer Refrigerator
Service code EC?
CODE INDICATION
05 Refrig. Cabinet Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
06 Refrig. Evaporator Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
07 Freezer Cabinet Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
08 Freezer Evaporator Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
20 Defrost Under-heat with No Voltage Feedback Through Gray/White Wire at Defrost Start
21 Defrost Overheat
22 No Voltage Feedback Through Gray/White Wire at Defrost Start
23 Defrost Overheat with No Voltage Feedback through Gray/White Wire at Defrost Start
24 Defrost Under-heat
30 Excessive Icemaker Water Valve Solenoid Activation (Exceeded 15 Seconds)
40 Excessive Freezer Compressor Run
50 Excessive Refrigerator Compressor Run
Jan 21, 2008 | Sub-Zero 632 / S
Freezer is very cold and refrig is cool
Hi. As long as the evaporator motor is working its one of the two as you mentioned. If the compressor and evaporator fan is running and the refrigerator door has been open, with the freezer door closed, reach into the back left top where the diffuser is located and put your hand in front of it and see if any air is coming out. You should feel a moderate breeze. If not, open the freezer door with your hand in front of the diffuser and if the air comes out good now, the return air is blocked (normally ice build up). If no air is felt, the damper is most likely bad. Use a mirror and see if the damper is closed or frosted up. This can happen from the refrigerator or freezer door being left open for some time.If you have a mechanical damper, make sure it is set in the middle. You want more air to the refrigerator section. Email me on ebay, user name themackshack if you need parts! Good luck, Mack
Jan 06, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
35 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
