Question about IBM ThinkPad A30 Notebook
I have a IBM thinkpad A30, Wireless connection but no internet
I have a ZyXEL router, which the laptop can find and says connection excellent but I can't access the internet. I have tried the wizard which says it's trying to connect but comes up with network names don't match. I have tried going into my network settings and changing them in advance but nothing is working. I have tried pinging and got 4 responses but when I try to ping google.com it fails.
  • Diane Murphy Jul 15, 2009
    My home pc is linked to this router and a Xbox so I know that the router is ok.
  • jk_10_79 May 11, 2010
    Do you have software installed for your router? Make sure it is allowing traffic to go outside your internal network.
I cannot get network connection with my ibm t21 thinkpad .have a wireless router abd my hp laptop is working fi
hi
the T21 has PCMCIA slot , you need a WiFi card (PCMCIA) : i dont believe it has built in or isntalled WiFi card.
Feb 05, 2012 | IBM ThinkPad T21 Notebook
Dose all ibm have wireless connection in them
No all ibms dont have wifi built in,,check ibm website to see if your model does,,also jus search online ,,,ibm thinkpad a30 2652 did it come with wifi,,should find answers,,thanks,,goodluck
Nov 20, 2010 | IBM ThinkPad A30 2652 Notebook
Can't set up wireless on IBM Thinkpad
If I recall there are two types of wireless cards that are installed in the T40 series of laptops. Can't advise you which one is installed in your laptop. Download both of them and install one, it it doesn't work then install the other one.
Go to the IBM/Lenovo WEB site - support/download page and download the latest Windows XP or Vista device drivers for your model laptop,
You need to use a computer that has Internet access to download and transfer the files to your computer.
http://www.ibm.com/products/finder/us/finders?pg=ddfinder&cm_re=other-_-suprcn-_-download
Once you get the wireless card operation, you need a wireless router that is connected to a cable or DSL modem which is connected to an Internet Service Provider.
You don't need a wireless router if you only want to connect to the Internet using wireless Hot Spots in public locations or Internet cafes.
Mar 07, 2009 | IBM ThinkPad T41 Notebook
Wireless asistant not found
If you have to be online when u are in wireless then you should use a wireless router for internet and needed configurations in the system otherwise it wont connect at all
we are using R52 only i am able to connect to internet with wireless router..
Thanks
mohan
Oct 15, 2008 | IBM ThinkPad R52 Notebook
Laptop.. cannot connect to internet
if you want to use wireless connection you have to have a wireless router, and you connect your internet cable into the router, so after you can have a wireless connection with your laptop and his wireless card, and you can work with your laptop everywhere in your house.
you can buy a wireless router in every computer shop.
last thing if you have a desktop PC you can connect a new internet cable to the wireless router (type RJ45)
I hope this helps
Please rate accordingly
Thank You
sserpentio
May 03, 2008 | IBM ThinkPad T30 2366 Notebook
IBM THINKPAD R50
You need to setup the wireless, consult the manual on how to configure the wireless.
Apr 14, 2008 | IBM THINKPAD R50 - P M1.5GHZ 256MB 40GB...
Internet Explorer cannot display the web page
your router needs to be configured to let your laptop in the network
Apr 09, 2008 | IBM ThinkPad R50e Notebook
Wireless connection
There are a few requirements other than the laptop and the wireless card. You need to also have an Wireless AP/Router that must be connected to the modem that connects to your ISP. All your PCs must then connect to this router either using the wired/Ethernet ports or WiFi.
If such a device (WiFi AP/Router) already exists and is connected to your modem and your other PC(s) are tied up to it and can access the Internet, you need to install the drivers (in a CD that came with the wireless card) to your IBM ThinkPad. Thereafter, you need to configure your laptop's wireless networking to access the AP/router. Your AP/Router must also be configured to accept wireless clients.
Please post back with brand/model of your AP/Router.
Hope this be of initial help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Feb 01, 2008 | IBM ThinkPad T20 2647 Notebook
Zyxel p660hw and g202 problem
I had an almost identical problem and contacted Tech support at Zyxel. They were excellent and the guy talked me through to a solution. The main issue related to 'Bandwith management' which defaults to active on the router configuration. Unset all three (Wan, Lan, Wlan) and see if it sorts out problem. Because of some other issues I did have to reset the router to start with and on the wireless client I unset 'Obtain IP address automatically' and used an IP address with the default gateway set to the router address. If this does not help, I would recommend talking to Zyxel Tech Support, the consultant I spoke to was brilliant.
Nov 22, 2007 | Zyxel P660HW-D1 Router
IBM ThinkPad A30 Notebook Logo
375 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
