Question about Canon imageRUNNER 5570 Copier
Waste toner collection IR 5570
Where is the waste toner collection unit on a Canon IR5570?
  • Anonymous Mar 18, 2014
    Can i use another cannone toner for ir5570?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 118 Answers
Remove the small lower( rear)right side cover 2screw then you will see the waste bottle youcan pull it out and throw away the waste toner
Posted on Jul 16, 2009
The window on the canon ir 5055 says the waste toner recepticle is nearly full. Do I need advance notice to order a part once the recepticle is full?
Basicly, the waste toner bottle is emptied out by your service person or if you work on it, then it is you. There is a counter that will display that it is nearly full. The counter will need to be rest and the waste toner has to be looked at and emptied if needs be. The waste toner & the cleaning web have about the same life / couter life. It is not a big deal..... I've never saw a waste toner bottle over file before, but if it is not looked at or checked it may cause some problem. Good Luck
Mar 29, 2011 | Canon imageRUNNER 5570 Copier
E000821-0002 ERORR WHY R U COM THE COD OF CANON IR5570
these means that copier is detected too much waste toner in cleaning blade assy.
Book says:
Clogging of toner inside the cleaner has been
detected with reference to an abnormal rise in the
cleaner thermistor.
Try to:
- Remove the waste toner from inside the cleaner.
- Replace the air filter of the heat discharge fan.
and I would also recomend to check waste toner stiring "snail" and waste toner container.
Hope that helps!
For service manual you can contact me on emma.servis@gmail.com
Sep 07, 2010 | Canon imageRUNNER 5570 Copier
Replace waste toner container message on IR 5570
on right hand side is waste toner you should be able to dump it yourself the main problem is reseting the counter that is not included in your manual Go into service mode by depressing the additional function key, then 2 & 8 at the same time, then aditionall function key. Select copier, then at the top far left side select counter. I blieve the counter is under MISC as waste toner. Select waste toner, depress the " C " buton on the keypad and it should reset to all 0's
Jan 15, 2010 | Canon imageRUNNER 5570 Copier
Where is the waste cartridge for the canon ir 2018
If you open the front cover and release the leaver of the drum unit.Remove the drum unit.On the drum itself is a plastic plug,remove the plastic plug and remove the waste toner in to a bin.The waste toner is stored behind the drum and must be removed reguarly.
Dec 14, 2009 | Canon imageRUNNER 2018 Copier
Remove the waste toner cartridge from a canon imagerunner 6020. I wasn't sure and couldnt get the instructions from the 5570 to work
i think the waste toner bottle is on right side, its on the lower level of right side of the machine there is four screws, unscrew them and empyt the bottle, but u have to clear the waste toner bottle mode after. if this machine the waste toner in the front cover, just open the front cover, left the green handle and pull the waste toner,.the empty it and put it back
Jul 08, 2009 | Canon imageRUNNER 5570 Copier
Canon imagerunner c2880 (GPR-23)- Waste receptacle
i dont know about any counter to reset,the message is displayed when there is waste toner in the sensor window of the waste toner bottle.That window can also be cleaned.
Jun 09, 2009 | Canon imageRUNNER iR C2880 Color Copier
Canon imageRUNNER 2020 alternates between displaying Error Code E019 and saying "Waste Toner Full".
hi you have a waste toner error code, the waste toner is apart of the drum unit in these machines so you will need to order a new drum unit for it.
easiest way to fix the problem.
Canon Tech
May 28, 2009 | Canon imageRUNNER 2000 Copier
Canan ir 1018 make sound
Normally nise come from the drum unit when the waste toner is too full.Remove the waste toner by removing the drum unit and remove the waste toner plug and disgard the waste toner and reinsert the drum unit.
May 18, 2009 | Canon imageRUNNER 1023iF Black and White...
A message is poping out saying replace the waste toner container.
I'm taking it that you have a IR-2270, not a IR-5570 correct??? The waste toner bottle is behind the front cover... It is in front of the drum unit. It is measured by the weight of the bottle, you just need to empty the bottle and you should be all set.... There is one screw in next to the toner bottle.... The other one is on the top left front corner of where the paper comes out. You have to push the front pannel to the left to remove the cover... Good Luck
Apr 14, 2009 | Canon imageRUNNER 5570 Copier
5570 imagerunner question
If you can find the main power switch to the machine, you can find the waste toner bottle. Find the doors on the right side of the copier that are used to clear paper jams, or find the bypass tray. Then look towards the rear of the machine and you will find a small cover where the on/off switch is located that is attached with two screws. Remove the screws, pull out the bottle and dump the waste. Slide the bottle back, reattach the cover and you are done.
Jun 05, 2008 | Canon imageRUNNER 5570 Copier
Canon imageRUNNER 5570 Copier Logo
666 people viewed this question
old marine
old marine
