Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Magnavox PTV910. The picture is good but color is bad
I have a Magnavox PTV910. The picture is good but has a very noticeable RED tint to entire picture. The TV's color adjust does not fix the problem. I've seen where you check the color tubes, but it sounds complicated, is this something I can do at home? If so, how?
  • Philips Master
  • 8,617 Answers
The coolant in the blue and green crts has congealed which is causing the red tube to become dominate. The coolant can be changed at home. You can get the phillips coolant replacement kit at the following link which contains the coolant and the CD with instructions.
http://www.tvrepairworld.com/
Posted on Jul 16, 2009
I have magnavox 910 ptv and the orange dlp lamp flickers what can I do to fix the problem
Posted on Aug 12, 2010
4 Suggested Answers
Slinteriors
  • 8617 Answers
SOURCE: MAGNAVOX PROJECTION TV- GOOD PICTURE , BUT NO COLOR
you need the ssm panel. You can get a replacement panel for your model at the following link.Which is the correct board for your model it controls color, convergence and etc.
http://servicemanuals.vstore.ca/product_info.php/pName/phillips-ptv900-series-ssm/cName/sale-items
Posted on Apr 22, 2009
Sparko1
  • 167 Answers
SOURCE: I have a Philips Magnavox ptv843 and it has a red
These TV's are known for polluted coolant in the picture tubes.The coolant is between the lense and the tube. The factory has a Service Bulletin about this problem and they say to change the coolant in each picture tube. This will make the TV look like it did when it was new.
Posted on Aug 02, 2009
maatmartin7
  • 1229 Answers
SOURCE: How do I adjust the picture tube for best results
The problem is an aging tv. The small signalboard needs reworked. Send it to PTS elctronics for repair. It will be guaranteed work. Tell your local tech.
Posted on Sep 17, 2009
Magnavox ptv910
The coolant in the green and blue tubes has discolored causing the red to dominate the screen,. This is a common problem that you can fix yourself with a CRT or Dull video repair kit from www.TvRepairKits.com
Dec 24, 2011 | Philips Magnavox 9P6034C 60" Rear...
Picture on my magnavox 9p5544c102 is fuzzy with green tint
Its the CRT coolant which needs replacement. You can get the Phillips CRT coolant kit at www.tvrepairworld.com which contains the Coolant for all three CRT's plus has the CD with instructions.
Jul 14, 2010 | Philips 9P5544C 55" Rear Projection...
Tv cloudy and faces are red
TV needs CRT coolant replaced, once this is done the focus and color level of each CRT needs to be adjusted for optimum picture. expect to pay around $300 good luck, Julio at Millenium TV , Las Vegas NV (702) 736-1091 milleniumtvsvc@gmail.com
Jul 21, 2009 | Philips E-Box FTR9965 DTV Receiver
The color is bad
my rear projection Phillips TV Picture has a green tint.
Jan 02, 2009 | Philips Magnavox 9P6034C 60" Rear...
Phillips Magnavox 60 inch Projection Tv
That model is famous for having bacterial contamination in the CRT coolant causeing halos, and dim pictures with bad overall color issues. You can look into the lens of the CRTs when the set is laying and if the coolant looks cloudy or has any growth there you will notice it right away, and changing the coolant will restore color, clarity and brightness.
Jun 15, 2008 | Philips Magnavox 9P6034C 60" Rear...
Rear projection
Sounds like the red CRT is shorted. I have some magnavox/phillips crts listed on my website for about a third of what they normally go for and i am currently adding The CRTs from a PTV910 43P8431. let me know if you would like me to post a link to the website.
Mar 07, 2008 | Televison & Video
Red tint on the entire picture
Always try your extended warranty!.....Probable cause = bad
red tube. One adjustment may help---turn down red screen
control, located behind technician access panel in front of set.
Nov 04, 2007 | Mitsubishi WT-42311 42" Rear Projection...
The colors off...
Wrong or poor color is usually caused by bad CRT's -----
each tube,red,green and blue must function properly for
good picture.Tube replacement is about 400.00 each....T.
Oct 27, 2007 | Philips Magnavox 9P6034C 60" Rear...
Dim picture
If decide to do yourself, ya only have to do the green and blue ones, the red light spectrum won't allow fungal growth. Pull whole CRT assembly out to prevent spilled/leaking glycol from onto lower main boards
Sep 04, 2007 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
1,037 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
