Question about Dryers
Dryer stopper working i can hear the timer but when i push the start button it dont start
I must assume since you say, "Will not start", this implies you do not hear the motor and fan exhaust spin. Yet the timer continues to count down. This is most likely the "thermal fuse". It is easily accessed when the rear dryer cover is removed. Sears sells them for $14.45. Your parts manual will show where it is. Or go to Whirlpool site and view the manual there. But if it is the thermal fuse, which it seems certain it is, you need to solve why it blew. Which most likely is because the timer keeps advancing, putting you into the next cycle, turning on the heat, but with no manual push start on console button, the motor and fan do not come on, thus overheating the unit and burning the fuse. A new timer will cost about $85.00. Good luck.
Posted on Jul 24, 2009
  • Virgil Watts Jun 17, 2014
    If it is the thermal fuse , remove the cover on the blower fan and get all the lint & no telling what else out of there. Also clean all lint out of inside dryer and from the dryer ventto the vent on the outside of house. That's most likely what caused the fuse to blow & if you don't clean it it will do it again.
  • 867 Answers
I think your belt broke. plz rate
Posted on Jul 15, 2009
Dryer has power to timer, but won't start...I have an Amana electric dryer that allows me to set the timer and I can hear it running, but when I push in the the timer knob to start the dryer (drum
The fuse is mounted on the heater element. When it blows nothing in the heater or motor circuit works but the power to the timer is not interrupted therefore you can hear. Service manual
Feb 11, 2013 | Amana Dryers
When i push the start button i hear the timer working but nothing else happens. when i release the start button the timer stops working.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 06, 2010 | Dryers
Dryer start button doesn't work
door switch or possibly the motor. if you hold the door switch in and push the start button have someone turn the drum by hand if it starts running it is the motor
Jul 04, 2010 | Frigidaire FEX831CS Top Load Stacked...
Dryer will not start. thermal fuse ohms thru as does the heating element and the thermal cutoff ect. can the motor be jumped to bypass the timer? if so how ? i have no manual or schematic, any idea how to...
Try first by jumping out the door switch. then push the push to start button.
if still dont go on jump out the push to start button.
i replaced one not to long ago.
if still wont start it will be the motor or the timer.
Timer usually you can hear it running making a clock like sound. motor you have to ohm it out and see if it is good. a service manual will have the correct ohms with blk to white, to red, to blue etc. i dont have em
its only in the book. you can do the door sw. and push to start yourself. but sfter that you must decide to i want to spend $300 FIXING THIS ONE OR $300 ON A NEW ONE???
Mar 27, 2010 | Whirlpool LER5636P Electric Dryer
Whirlpool dryer will not start, used to start if I turned timer
whirlpool electric dryer will not start when you push start button. Model No. LER5634AW0. There is power to the dryer. The door switch appears to be working,(didn't check it with a meter). I push the start button, run it through all the cycles and still nothing. Are there any resets or circuit breakers that I could check? Where do I go from here?
Mar 06, 2010 | Dryers
The dryer will not start, you can hear timer.
your problem could be : Door switch, Motor, Thermal Fuse, Timer.
I would start with Door switch and Thermal Fuse.
Jan 07, 2010 | Dryers
My 1987 GE Dryer, Model # DDE5300GALWH,will not run all the time.
sounds like you need a new timer you can actually take the timer apart to check for a burnt connection
Jan 07, 2010 | GE Dryers
Dryer timer or start will not work
Yes, it does sound like the timer. You could do an ohms test if you have the ability but timers aren't too terribly expensive or hard to replace anyway.
Apr 08, 2009 | Kenmore Dryers
My whirlpool dryer wont start.
check the door switch and also the push to start button. Timers will advance even if the unit is not on
Mar 30, 2009 | Dryers
Dryers Logo
109 people viewed this question
Top Dryers Experts
