Question about HP Photosmart 2575 All-In-One InkJet Printer
Printer won't print documents and has trouble feeding paper
I have just changed the cartridges and they are new, but when I print, the printer does not print any words on the paper.
My printer has trouble loading paper, i have to manually fee the printer and even then I get several times where there is a paper jam, because the printer cannot properly load the paper to print.
  • xcite_freque Jul 15, 2009
    DUH! That is NOT the problem or reason...I am NOT stupid!
  • 112 Answers
Did you make sure to remove the tape covering the end of the cartridge?
Posted on Jul 15, 2009
Printer is making a clicking sound when trying to print and paper won't feed all the way through. This is the first time this has occured. I have turn the printer off, turned off the computer and...
Leading cause of paper jams is debris/foreign objects that accidentally fell into the paper feed area. Please follow steps below to fix the problem:
1. Remove the sheets of paper from the feeder.
2. Grab a flashlight and look inside the feeder for any debris or foreign objects.
3. If you're willing and physically able, you may also turn the printer over. Any debris should just freely roll out from the feeder.
4. If feeder is clear, place the printer back on the table, open the printer cover and remove the cartridges.
5. Check the cartridge area for any obstructions/debris in the cartridge carrier's path or the paper path.
6. If cartridge area is clear, close the cover.
7. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
8. When the printer turns on, reinsert the cartridges and load some paper. Try to print a document again to verify that the problem is fixed.
Sep 24, 2011 | Lexmark X73 All-In-One InkJet Printer
Blank page feeding during print job
Please adjust paper size in printer properties.
Oct 09, 2008 | HP Deskjet 6940 InkJet Printer
My printer X3350 has trouble grabbing the paper from the paper tray. What can is the problem. I tried cleaning the grabber wheel. But it still won't grab the paper.
Sep 21, 2011 | Lexmark X3350 All-In-One InkJet Printer
My Lexmark printer 2600 series won't print. It pulls the paper towards the right but won't feed it. How can I fix this?
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sep 03, 2011 | Lexmark X2600 InkJet Printer
Lexmark X85 won't feed paper. When trying to
There could be something in the paper feeder that's blocking the paper path. Please follow steps below to identify and fix the problem:
2. Grab a flashlight and look inside for any debris.
5. Check the cartridge area for any obstructions/debris that could cause this error or problem.
7. Unplug and re-plug the printer into the power outlet to reset it.
8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again.
ns Serif"'>6. When the printer turns on, reinsert one cartridge first.
7. Close the printer cover and check for any errors.
8. If no error appears, reinsert the other cartridge. Close the printer cover.
9. Replace whichever cartridge is causing the error to appear with a new cartridge.
Jul 11, 2011 | Lexmark X85 All-In-One InkJet Printer
My hp officejet j5750 does not copy
hi im josh in cebu phils.try my solutions
.tt1 {font-size: 10pt;} If your printout is not as you expected, there might be several causes. The most likely cause, believe it or not, is our old friend the poorly connected cable. If all the instructions don't make it from the computer to the printer, your printout will be incomplete, if not totally out of whack. Check all cable connections to ensure a good throughput of data. If that doesn't fix the problem, just change the printer cable. An old or damaged cable could be causing your problems.
tip
tip_icon.gif Printing the printer's self-test page is also a good way to determine whether the problem is in the printer or in the computer—or somewhere in-between.
Another cause of print garbage might be the printer itself. If you have a low or old toner cartridge in a laser printer or a near-empty ink cartridge in an inkjet printer, your printout will be lighter than normal, perhaps even unreadable. If necessary, change the cartridge and run the print job again.
If you're using a laser printer, you might get black streaks on your output. This problem is most often caused by an old toner cartridge, or by a dirty roller or printer cleaning bar. If you replace the toner cartridge and clean the suspect parts (using a cotton swab) and you still experience black streaks, your printer might need service.
If you're using an inkjet printer, it's possible that your print jets are clogged. You'll need to unclog the print jet by inserting a small pin into the jet.
It's also possible that a paper misfeed in your printer caused the printout to become smudged or out of line; if this is the case, straighten the paper feed and start the print job again.
An incorrect printer setup in Windows can also cause unusual printouts. Make sure that Windows is configured for the exact type of printer you're using. Also make sure that you have the correct landscape (horizontal) or portrait (vertical) printing option selected.
If none of this works, you probably have a problem somewhere in your printer. Although a bad printer port on your PC could be the culprit, more than likely some internal problem with your printer is causing the poor printout. (You can confirm this by printing a self-test page; if it looks bad, the problem is in your printer.) Consult your friendly repair center.
Problem: Your Printed Page Looks Half-Finished If you're trying to print a document with a lot of graphics (especially on lower-priced laser printers), you might find that your printer doesn't have enough memory to print the entire document. What you'll get is about half the document—and not always a contiguous half! You can do one of several things to rectify the problem:
  • Add more memory to your printer. If you do a lot of heavy graphics printing, you probably need at least 1MB of RAM installed in your printer. You might be able to add the memory yourself, or you might want to have a qualified laser printer technician do the job for you.
  • Instruct Windows to print this document at a lower resolution. Go to the Printer Properties dialog box for your printer and select the Graphics tab (if your printer has this option). Select a lower resolution (which requires less memory and gives you less finely detailed output) and see if you can now print your document.
  • Simplify your document. If you're using a lot of different fonts and graphics, take some out. It's not an ideal solution, but it might be the only way you'll get this particular document printed on time!
Problem: Your Printer Prints, but the Fonts Aren't Correct If you create a document on a PC with one set of fonts installed, and try to print it on another PC with different fonts installed, you could be in for a real surprise! Windows will try to "match" missing fonts, but quite often the match leaves a lot to be desired—resulting in different line lengths and page breaks than what you had originally. Your options are to install the missing fonts on the PC you're printing from, or change the fonts in the document in question. (A word to the wise: stick to common fonts such as Arial and Times New Roman if you think you'll be sharing a document on multiple PCs.)
Problem: Your Color Printer Doesn't Print All Available Colors This problem is most likely caused by an old ink cartridge. It's not unusual for some colors to get depleted before others, throwing off your color output. If you're seeing less blue (or red or yellow or black) than normal, chances are it's time to change your cartridge.
Problem: Paper Jams in Your Printer It's possible that your printer's internal paper feed mechanisms are getting dirty. You can try taking the printer apart yourself to clean out any pieces of scrap paper or other debris, or you might want to take it into the shop to let a pro deal with it.
You might also be getting some paper sticking to other sheets of paper in your paper tray. (This happens more often with cheaper paper—spend a little more and get the good stuff!) Try thumbing through the stack of paper before inserting it into the tray; this should loosen up the paper and make it feed easier into your printer.
Finally, you might need to change the grade of paper you use with your laser or inkjet printer. Lightweight papers tend to jam up the works, so switch to something heavier if you experience a lot of problems.
THE ABSOLUTE MINIMUM
  • Most printer problems are caused by a bad cable connection, a misconfiguration in Windows, or a bad or outdated print driver.
  • All printers need periodic maintenance; make sure you regularly change toner or ink cartridges, clean the paper path and feed, and—if you have an inkjet printer—use the cleaning option to clean the ink jets and cartridge.
  • If you're having trouble printing graphically intense documents on a laser printer, you might need to add memory to the printer or simplify the documents.
  • Lightweight paper can cause unexpected paper jams; use a better grade of paper to keep things running smoothly.
  • good luck friend
Mar 05, 2009 | HP Officejet Pro L7480 All-in-One...
Lexmark C1150 printer doesn't print
First I try to uninstall the printer, it didn't work, so I reinstall the the printer anyway, it worked for one print only.
As second attempt I disconnected the printer completely, turned the PC off, and after few minutes on again. Uninstalled printer.
Reconnected the cables again, install the printer - it works well!
Dec 05, 2008 | Lexmark X1150 All-In-One InkJet Printer
HP Photosmart 3200 All-In-One not printing yellow
Step1
If you're setting up the printer or changing the toner or ink cartridge for the first time, double-check the instructions to make sure that you installed the cartridge correctly and, for new printers, that you have removed all the pieces of cardboard or plastic packing material.
Step
Check to see whether paper is feeding from the paper tray. If it's not leaving the tray at all, try feeding a page manually (if that's an option) or using a different paper tray. Sometimes a problem with the tray can be traced to a broken spring or a piece of plastic.
Step
If paper is feeding from the tray but jamming in the printer, examine where the jam is occurring and then inspect the printer carefully to see if you can find what is causing the problem. A piece of paper, for instance, might be blocking the paper path.
Step
If paper is feeding through the printer but coming out blank, check to see whether the printer is out of toner or ink. A defective toner or ink cartridge could be the problem.
Aug 20, 2008 | HP PhotoSmart InkJet Printer
HP Photosmart 2575 All-In-One InkJet Printer Logo
125 people viewed this question
Seeker5211
Seeker5211
