Question about VinoTemp Refrigerators
My vinotemp will not stop when it gets to 55 degrees - it keeps running and starts beeping when it gets into the 40's - it is a 2 door 500 bottle model
    Problem Solver:
  • 14 Answers
Check the coils to ensure they are free of dust(can be vacuumed) and the doors on the unit are sealed properly. Sounds like there is a thermostat problem. You can get these parts from Vinotemp @ 800-777-8466
Posted on Sep 25, 2009
Left door of F/P fridge part for a week. Now red light is flashing, beep stopped but fridge not cold enough.
Hello Jennifer;
My name is Peter. I am a retired field service refrigeration technician.
No. Your problem is not defrost.
The normal temperature setting for a freezer is -2 to +2 degrees F. or -18.8 to -16.7 degrees C. The fresh food section should be set at 35-40 Degrees F. or 1.6 to 4.4 degrees C.
Reset your temperature controls to the recommended settings.
Up plug your unit for 10 minute to power down. Plug your refrigerator in.
Jan 01, 2015 | Refrigerators
Why is fridge temperature not dropping below 70?
Check the door seal by inserting a dollar bill between the seal and the unit then closing the door on the bill. The bill should not slip out easily when you attempt to pull it out with your hand. Check the seal in all corners and along all surfaces. Also, service the condenser coil by blowing compressed air through the coil IN THE OPPOSITE DIRECTION THE AIR NORMALLY FLOWS WHEN THE CONDENSER FAN IS RUNNING DURING OPERATION.
Mar 16, 2010 | Refrigerators
GE refrigerator model #GSS22SGRESS (5 yrs old) Refrigerator compartment worms up to around 55 degree. If you shut the refrigerator off and open the doors for 24 hrs then turn it back on, the refrigerator...
Usually when this happens it is because of a problem with the fan that moves cold air from the freezer section of your unit to the refrigerator section. Either the fan has gone bad or the unit has frosted up to the point of stopping the fan. Try defrosting (unplugging) the unit over night and then check it to see if the fan runs. If not then replace the fan. If it runs and then stops after awhile like days or even a few weeks, then you may need a defrost timer.
The defrost control can also be called an advanced control timer.
The other less likely thing that can go wrong is for the defrosst coil to burn out.
If you have an OHM meter you can check for resistance, if it is open then it is no good.
You can do a search for "appliance parts" and then enter your model number to find replacement parts.
check a couple of sites to make sure you get then best price.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 07, 2009 | GE Refrigerators
Fisher & Paykel Auto Sensor Dryer stops & beeps constantly
Hi emkboyce
my Fisher Paykel auto sensor dryer keeps stopping and beeping, i have to stop it and and re start.
I had the same problem. I took it off the wall and vacuumed up all the lint from everywhere including around the back and including taking off the back and vacuuming everything I could reach inside. I then used a damp cloth to get rid of the rest of the lint/dust.
I thought I was wasting my time but guess what, the problem has gone.
Sep 30, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Vinotemp wine cooler temerature won't stay on 54 degrees
If the unit is a thermoelectric unit it can be the cooling system.
If the unit is a compressor unit it will be the thermostat.
Aug 28, 2009 | VinoTemp 32 Bottle Stainless Wine Cooler
Cools, but not below 60 degrees
It sounds as though you may have to replace the cooling system on the unit, to order it you can call Vinotemp @ 800-777-8466
Apr 18, 2009 | Refrigerators
I have a vinotemp it stopped cooling no light and keeps making a ticking sound, I tried to unplug it for a while and plug it back and the ticking sound goes back again but still no light no cooling, please...
You can fix this for $5. You can confirm the problem by taking the back off and see of the red and green led on the circuit board are flashing. They will be steady if the board is ok. The fan is usually just rocking too like it is trying to start. The part is a capacitor and is $5, but you will need to be able to remove and solder a part on the circuit board. If you need the part, just let me know.
David
Oct 23, 2008 | VinoTemp VT24-G 24 Bottle Wine Cooler
Vinotemp VT-60 Condenser won't shut off, unit running way too cold
It might be a sensor or control board problem. Any appliance repair place should be able to help you out with this. Or you can try contacting the manufacturer directly for help or if you need to purchase replacement parts. Otherwise, my cheapest suggestion would be to hook the cooler up to a timer, so you can turn the unit on and off maybe every 20 minutes or so. That should help keep it from causing more harm and then you can monitor the temperature with a thermometer. Hope that helps!
Aug 29, 2008 | VinoTemp (VT60GNV) Wine Cooler
Cannot close vinotemp
The bottles are too long, and its probably hitting the glass. Try installing without it being double deep and see if that works.
Aug 09, 2008 | VinoTemp (VT60GNV) Wine Cooler
Refrigerators Logo
485 people viewed this question
Top VinoTemp Refrigerators Experts
Ilia Bichin
richie46
Are you a VinoTemp Refrigerator Expert? Answer questions, earn points and help others
