Question about Kitchen Ranges
I have a Rosieres Paul Bocuse range cooker but no manual for it. I need to replace 2 of the ignition electrodes on the hob and don't know how to do it. Can you help?
  • A JONES Jun 06, 2013
    I NEED A MANUAL TOO - DID YOU LOCATE ONE? THANKS
Http://www.awardappliances.co.nz/content/RBC%20127%20USE%26CARE.PDF
Posted on Oct 05, 2009
Hobs all working oven not working
Hob stopped working, oven still fine on electric cooker, any ideas ...
forums.moneysavingexpert.com/showthread.p...
MoneySavingExpert.comDec 25, 2010 - From this point, we'll assume that you are happy to receive all .... have a "problem" that covers the hob not working but the oven doing so. Gas Hob Ignition Not Working!
May 22, 2007
Oven not heating - Please help
Oct 14, 2006
Oven won't get hot - help please
Aug 24, 2006
More results from forums.moneysavingexpert.com
How to Diagnose a Fault With an Electric Hob ' eSpares
www.espares.co.uk > Advice Centre
Jan 01, 2016 | Logik LFTC60W12 White 60 cm Electric...
I have an old belling farmhouse cooker the hob works fine but the oven isn't igniting manually or by the electric ignition The timer is manual and is stuck on the red patch I can't seem to shift it ...
Take the tiny screws of there are loads down right hand side then release screws on hob once you can lift hob plates up. Undo the covers on back of timer clock control . Make sure you un plug from mains . Take the neutral of back of timer clock. This will allow your oven to auto ignite again
Jan 07, 2014 | Belling FarmHouse 931 Gas Kitchen Range
Where can I get a manual? Can it be downloaded? Thanks
.pdf user manuals can be obtained via steve.richardson@fisherpaykel.co.uk Quoting the exact model number located on the rating plate located on your appliance as detailed below.
Range Cookers
Behind the Drop Down Storage Panel beneath the oven door or on the Oven Chassis behind the door
60cm Freestanding Cookers and Ovens
On the Oven Chassis behind the door
Hobs
On the underside of the hob (any oven or hob situated underneath the hob may need to be removed to gain access.).
Feb 15, 2011 | Stoves Ovens
Rosieres 4040DB cooker - Problem with oven doors
hi can you please give me a call re this... I have the same problem on my 4040db and I am keen to know if/how you resolved it, many thanks Simon 07787 511443
Jul 07, 2010 | Ovens
Ignition not firing on a neff hob, gas fine
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Feb 22, 2010 | Cooktops
Seized screws in Stoves 'Range 1000G Gas Range Cooker (LPG)
I let the screws soak for a few days in release oil but with no success. I decided the only way to get the seized screws out was to drill and tap new holes through the hob and into the hob burner mixing tube support flanges. This allowed new screws (stainless as opposed to the standard, chrome plated steel screws) to be screwed into place. Once this was done I then drilled out the heads of the remaining seized screws. This allowed the hob tops to be removed so that the oven thermostats could be changed. The hob screws were then screwed back into place and lubricated with loads of high temp. copper grease to prevent corrosion. I will also remove and re-grease these screws every six months or so to prevent any chance of seizure in future!
A few points to remember: (a) make sure that any holes in the hob top are sealed with something such as a screw coated with high temp fire cement etc. to prevent any possibility of unburnt LPG getting into the space below the hob top. (b) make SURE that you do not drill or tap into anything that could damage the cooker and cause a gas leak or damage any of the gas ignition leads etc. (c) Make sure that the appliance is totally 'gas tight' after doing any work which will disturb the gas connections, and (d) If you don't have gas qualifications and are not sure of what you are doing then get an expert, registered gas engineer to do the work for you. Don't take a chance with gas!!
Oct 07, 2009 | Stoves 1000DFDL Dual Fuel (Electric and...
Ignitor will not stop sparking on AEG Electrolux Cooker Hob
gud day,try to clean the bottom of knob control by removing of knob then clean if by using a vacciumm,if u want to use manually ur cooktop unplug the unit to stop the cliking,then use macthes every time to on the gas cooktop.
Jan 09, 2009 | Cooktops
When i turn on the oven the top hobs keep clicking on my canon cooker
Hello Brian
Welcome to Fixya.
You said, when you turn on the oven the top knobs keep clicking on my canon cooker.
If you mean the electronic ignition keeps clicking when you turn the oven, It sounds like one of the switches that is controlled by the knobs, is stuck and malfunctioning! It sounds like it needs to be replaced.
There are 5 electronic igniter's on a 4 burner gas range, and the fifth is in the oven.
Let me know how you do.
Please remember to leave a rating when you finish.
Thank You, Huuum
Oct 02, 2008 | Kitchen Ranges
Kitchen Ranges Logo
1,094 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
