Question about InFocus LP70+ Multimedia Projector
Lamp is not working and I replaced the bulb twic
The lamp is not working while the unit is running and and I replaced the bulb twice
  • 2,237 Answers
If you don't hear a high-pitched whir, the colorwheel is bad. if you do hear the whir, the ballast needs replacing.
Posted on Aug 10, 2009
What do I do if my mitsubishi tv shuts off after 2 to 3 minutes and shows a solid red light code, which is saying the bulb is bad, I replaced bulb twice and both bulbs are new. What could be wrong?
What model is the TV? Also, what brand is the lamp? A lot of cheap lamps are truly junk and will not work. The bulb should be made by Osram or Philips.
Sep 11, 2016 | Mitsubishi Televison & Video
Powering up
the projector is quite good and may not have any internal defect
may the bulb has really burnrd out......
try a new bulb if it works or not
Oct 15, 2008 | Sony VPL-HS20 Multimedia Projector
After four months of waiting for my twic card and calling to update the staus I still don't have a clue about my twic card or my money.Now I'm missing work because of this delay. Not fair for a hard...
Roy, I'm not even close to America, and I still want to answer questions on Fixya. I think you made a mistake with the site you want to address. We don't receive any money and we don't send cards. We are not connected to twice and we don't answer phones. Please next time before you press send, answer or post, check the URL on top of the page, to make sure the message is delivered on the correct place.
Sorry, we can't help you.
Feb 05, 2015 | Cell Phones
Why doesn't the license plate light on my 2004 Kia Sorento work ? Tail lights work, back ups,etc, but no license plate light
Have you checked for power to the bulb socket with a voltmeter? Is there a good ground?
Nov 06, 2014 | 2004 Kia Sorento
TB25-LMP replaced but TV will not work
Sounds like the ballast is having an issue. The ballast is easially replaced and should be available from www.tvcircuitboards.com
Feb 10, 2013 | Toshiba 56HMX195 52" HDTV DLP Projection...
I have a 2005 G6, the front drivers side turn signal lamp is not working. The drivers rear blinks twice as fast. I have replaced the bulb, I switch the bulb and headlight assembly from the driver to the...
fast flashing on the one bulb is a fault is due to the failure of one bulb, hence the holder for the flasher unit not wirking has gone defective the contact may have broke in the flasher unit not working , look in where the bulb goes and compare the working and non working unit, you may see a contact missing, hence repace unit, or repair
Dec 22, 2009 | 2005 Pontiac G6
Need to know what size bulb goes in dome light
For 1991 TOYOTA Pickup replacement bulbs, review the list and check it in other brand with this model:
High & low beam headlamp
H6054
H6054ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
H6054XV XtraVision Halogen - The Brighter Light
H6054CB Cool Blue Halogen - The Whiter Light
H6054LL Long Life Halogen Upgrade: Lasts 6x longer
Parking light
168
168LL Long Life Upgrade: Up to twice the life of the standard lamp
194
194LL Long Life Upgrade: Up to twice the life of the standard lamp
Front turn signal
1156
1156ST Silverstar Signal Lighting: Complete the Look: Crisp, Clean, Style
1156LL Long Life Upgrade: Up to twice the life of the standard lamp
Rear turn signal
1156
Tail light
1157
1157LL Long Life Upgrade: Up to twice the life of the standard lamp
Stop light
1157
License plate
194
89
Back up light
1156
Front sidemarker
194
Glove box
161
161LL Long Life Upgrade: Up to twice the life of the standard lamp
Step/Courtesy light
DE3022
DE3175
DE3175LL Long Life Upgrade: Up to twice the life of the standard lamp
7443LL Long Life Upgrade: Up to twice the life of the standard lamp
Hope helped with this (remember rated this help). Good luck.
Nov 11, 2009 | 1991 Toyota Pickup
Red Light Flashes twice KDF-E50A10
Are you putting the lamp cover back in place before trying to turn the set on? The 2 blink error is a temperature error you might want to check the thermal sensor, is your lamp door warped?
Oct 30, 2009 | Sony KDF-50E2000 50" HDTV
Bulb replacement
WAIT!!! Before you just take the lamp cover off and try to replace the bulb that way, which would MAKE SENSE!!!, stop! All you'll do is snap the bulb off, leaving the metal screwy end of the bulb in the socket. Believe me - it happened to me. Twice.
The only way to ensure that you'll be able to get the entire bulb out, because the only way you can actually SEE what you're doing, is to remove the bottom cover of the microwave. It's about 6 screws along the underneath surface of the unit. After removing the screws, the front of the cover will hang down and the rear will stay nested in a groove at the back. At this point, you'll be able to see the backs of the light sockets. Remove the two screws on either side of the sockets, and you can gently pull the bulbs out of the housing so you can actually see and work with them.
Chances are, the bulbs have been GLUED into the sockets with silicone, which GE says it does to prevent moisture from getting into the sockets. Right. Then why is it that the replacement lamps work just fine without being glued in?! Anyway - GE actually instructs in the manual to "run a knife around the edge of the socket" to break the silicone seal. Hmmm..Sounds safe to me.
So, after you've eliminated the silicone one way or another, just gently unscrew the lamp like you would any other.
Trust me - you do not want to try to remove the lamps without removing the bottom cover. Oh, yeah - most importantly, unplug the microwave first! Good luck.
Jan 04, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
InFocus LP70+ Multimedia Projector Logo
89 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
