Question about Epson C64 InkJet Printer
One color not working
Actually, it's an epson photo rx 620. The color, light magenta, won't print out on a pattern test. It seems to keep emptying out right away & won't even print on the test right after replacing it. The printer & computer, however still says it has ink, but after removing it, the cartridges that have windows show it's empty...
  • 43 Answers
Try to clean the print head 3 times and do a pattern test if it still doesnt work then it has to be service
Posted on Jan 23, 2008
Problem printing yellow.
IIf the cartridges is original epson there is some color (light magenta that is clogged.
if the cartridges is non original check that is with the right order
Apr 23, 2015 | Epson Stylus Photo R300 InkJet Printer
Hi, When printing photos, my photos have horizontal light coloured lines across them. When I print the nozzle check pattern all colours match the guide with the exception of the light magenta....
Epsons are notorious for this sort of problem, especially in used infrequently as ink residue dries on the print head; try using a cleaning cartridge, or swab around relevant print head with cotton bud and ethanol/isopropyl alcohol. Here are examples of cleaning carts, there are others
Jan 03, 2011 | Epson Stylus Photo R200 InkJet Printer
My Epson R230 printer does print Light magenta and yellow ink
1. open a document. 2. control-P - shortcut for print. then click properties, click maintenance, then click head cleaning. after this print check pattern. continue doing this until your light magenta and yellow ink gets clearer. if it didn't work replace your light magenta and yellow cartridge.
Nov 18, 2010 | Epson Stylus Photo R300 InkJet Printer
ON Epson RX 520 head cleaner doesn't solve problem
Are you using Epson Genuine Ink Cartridges????
Hello, In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. That sounds like your problem. Also in Purchasing the Brother's . Color that should be Yellow, will turn out Green, etc. All Generic Cartridges, will print lines thru the words, and also do a mix match with the colors. That's what the Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, but you have to fill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for the PRINTERS.
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Jan 01, 2010 | Epson Stylus C88 InkJet Photo Printer
Stylus Photo 820 printing magenta lines
did you clean the communication ports , where the cartridges "talk" to the printer, the ports can get covered with paper dust and erronus signals can cause the printer to activate the magenta cartridge causing your problem. reomve the cartridges and Gently clean the comm ports with a q-tip and rubbing alcohol let dry then reinstall the ink cartridges.
Jul 12, 2009 | Epson Stylus Photo 820 InkJet Printer
Epson Stylus R230 Light Magenta Not working
Print first a nozzle check pattern, self test which they say. Check your manual for your printer, it should be accessible from that if you dont have any manual, go to the epson website and download a manual. Usually the self test would go like this.
While the printer is turned off, you press and hold down the paper feed button, continue holding it down while turning on the printer. It will print the nozzle check pattern standalone. If you see all the colors then the issue your having is a color management issue, if you do not see the cyan, magenta, yellow, black, light magenta and light cyan from that test; then you will need to do 3 consecutive times of Head Cleaning from the maintenance program in your computer. If you have a windows xp it goes like this.
Click on start go to control panel - printers and faxes -
you right click on your printer icon and select printing prefrences. From there, go to maintenance tab and click head cleaning, go through that cycle 3 consecutive times and see if it improved. Good luck....
Jun 12, 2008 | Epson Stylus Photo R300 InkJet Printer
Printing in black & white when color cartridge ran out
One of the possible reason why you can't print black in white because Epson ink jet printers require all of the ink cartridges to have ink in them in order to print any color, black and white, or grayscale images. More than that Epson printers contain a permanent print head that needs to be charged with all colors to work. Even when users are printing black text only, a small amount of color ink is used to keep the print head charged for color printing and prevent air bubbles from entering the color print nozzles which can damage the print head.
Apr 15, 2008 | Epson Stylus Photo 1280 InkJet Printer
RX620 inconsistently only prints part of the page
The epson printer RX 620 only prints partially for my photo while I want the whole picture. How do I get it to print the whole thing instead of it printing it partially?
Apr 13, 2008 | Epson RX620 All-In-One InkJet Photo...
HELP !!!! Instantly empty INK CARTRIDGES Epson Stylus Photo R1800
What i can recommend is call epson and tell them about this issue and for sure they are going to replace the ink and will run diagnostic test on your printer- here is there support line number 562-276-1300
Apr 01, 2008 | Epson Stylus Photo R1800 InkJet Printer
Canon IP3000, problem printing black
Try to change the default printer and check ...
Also try printing from other documents see if you facing the same problem
What version of Works you using ?
Do you have the Dic for Works ?
Apr 14, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
Epson C64 InkJet Printer Logo
114 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
