Question about Iomega MiniMax Desktop - Hard drive - 500 GB - external - Hi-Speed USB - 7200 rpm - buffe
My mac cant see my minimax 500GB, it powers on and spins up, but i cant see it on my desktop. I'm using the firewire cable.
  • gianmarco_f0 Jul 19, 2009
    it doesnt even see it in disk utility though, i think its broken
  • gianmarco_f0 Aug 06, 2009
    i have now tried the usb cable too,it doesnt work either. still cant see it AT ALL, the weird thing is that the drive works on my dads windows???
  • 739 Answers
The above answer is wrong. All MiniMax drive are formatted for Macs out of the box (that why they are shaped exactly the same as a mac Mini).
Try connecting with a USB lead to see if that works.
These units are generally very good (i've installed about a dozen in the last year) but I have known some be DOA (I've only had one). Do other externals work in your FW port? If they do, plug them into one of the other ports on the MiniMax and see if they still work.
There is always a chance that your FW port is faulty - they have been known to need resetting (you'll have to google that as I can't remember the exact procedure - I think a quick way is to disconnect everything from the mac - yes everything! and leave the mac sitting naked and forlorn for about 20 minutes, then reconnect everything including your minimax and power up the mac. With luck it should come on and mount. Let us know what happens.
Posted on Jul 26, 2009
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 41 Answers
This is because the HD needs to be mac formated you need to format the hard drive using support software that came with the hard drive if it doesn't have mac support try google or goto disk utility and format it as osx extended and journaled
Posted on Jul 15, 2009
  • iCow
    iCow Jul 15, 2009
Loose hardware
There are not many parts in a hard drive.
  • Data platters (secured with 5 or 6 screws)
  • logic board (doesn't move)
  • Actuator arm moves rapidly to read data.
Some whining or crunching sound is normal. I'd say either the logic board is burnt out, the reader head crashed or the data platters have lots of bad sectors. If it isn't working or detected your best bet is to replace it.
Nov 24, 2012 | Iomega Minimax 2tb Minimax 2048 Gb Usb 20...
Damaged 24 iMac screen - want to use ext monitor via "mirroring" in screen preferences, but cannot access system preferernce due to damaged screen...any suggestions
There is an elegant way to solve this, but it requires another compatible model Mac.
Boot the damaged Mac into FireWire Transfer mode by holding down the "T" key immediately after hearing the startup chime. Attach a FireWire cable between the two Macs. Start up the other Mac by holding down the "option" key after hearing the startup chime. Choose the startup drive from the broken Mac. Now your good Mac is booted off the drive of the broken Mac, and any configuration changes you make will be made on the hard drive of the broken Mac.
Attach the external monitor temporarily to the good Mac. Open System Preferences and set the monitors up in mirrored mode. Shut down the good Mac. Then hold the power button in on the broken Mac until the power turns off, and remove the FireWire cable.
Now move the external monitor to the broken Mac and boot it. It should come up in mirrored mode.
Jan 20, 2010 | Apple Computers & Internet
My Apple G5 and WD Passport 500Gb don't mount
You need to determine whether the problem is at the disk interface or at the computer interface. Will the drive mount on ANOTHER machine using FireWire? Will your computer mount ANOTHER device using FireWire? This will tell you which machine is at fault. It's not unheard of for the FireWire channels in a Mac to just go bad, and (unless it is a Mac Pro) it typically requires a logic board replacement to address. For a G5, this would not be cost-effective. On the other hand, as I say, it could just be a bad interface in the drive itself. It's up to you to determine which it is.
Sep 20, 2009 | Apple iMac G5 Desktop
I have an Iomega MiniMax Hard Drive that was previously formatted for a Mac. It is supposed to be 500gb but when I format it for my PC it only shows about 234gb in the primary partition. How can I regain...
connect your harddisk to computer.
Then right click on my computer icon then click on "Manage"
then click on "Disk Management"
then find your removable device then you find unpartitioned space create new partition .then check.
Also check jumper settings of your harddisk.
It should not be on 16 bit or 32 bit in hardisk.
Jul 16, 2009 | Iomega MiniMax Desktop - Hard drive - 500...
Lacie 500gb quadra external drive won't boot using USB cables.
Microsoft has had some issues in regard to external devices (especially after running some updates). There is a registry patch for this situation. Click below to install the patch. It should fix your external drive problem. All the best!
Greg
http://support.microsoft.com/kb/925196#fixit4me
May 19, 2009 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
My external hd blue light just flashes and i dont have access.
Do you connect via USB or firewire? Can you / have you tried another connection method?
Does it sound like the disk is spinning normally, or is it making a heap of clunking noises or not spinning?
The most common problem (assuming it has power, which it obviously does because it has a blue light), is the USB cable. Do you have another that you can try?
Let us know how you go with that and we'll continue...
Apr 27, 2009 | Acomdata 500GB External Firewire HD 500 GB...
Iomega
Yes. The MiniMax is designed to match the MacMini from Apple and comes formatted out of the box to work with a Mac. (One of the few drives that is!)
I think Iomega supply various Windows drivers on the CD
Apr 09, 2009 | Iomega MiniMax Desktop - Hard drive - 500...
Failure to mount on desktop
Iomega which is now a thing of the past were renowned for their fragility It may well have died
May 23, 2007 | Iomega MiniMax (33464) 250 GB Hard Drive
Open Questions:
See all Iomega MiniMax Desktop - Hard drive - 500 GB - Questions
Iomega MiniMax Desktop - Hard drive - 500 GB - external - Hi-Speed USB - 7200 rpm - buffe Logo
554 people viewed this question
Top Iomega Computers & Internet Experts
Owen Barnes
Martin Murray
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
