Question about Mitsubishi WS-55807 TV
Picture screen borders is not to size - Mitsubishi WS-55807 TV
Picture size mis too large. No matter what screen ratio or zoom setting, the picture borders are outside the screen. AkAI tech support phone # is no longer in serrvice.
Normallly, if the picture size button on the remote for the television does not achieve the desired affect, then, a cable box or a satelite box is where the change needs to be made. For example: A Motorola Cable box needs to be set up to go to a wide screen or zoom when an analog signal is detected. Some Dish Network boxes have Size buttons on their remotes and also in their main menu. It's difficult to determine the repair without knowing the types of the peripherals. Hope this helps.
Jul 30, 2007 | Akai LCT3201AD 32 in. LCD Television
My screen picture used to be the full size of the secreen, now there is a border on the top and bottom cutting the picture down like in the movie theatres. How do you get rid of the border and get back...
If you are using cable TV there a button on the remote "*" which zoom in and out. You can also check with your cable company in case you have HD TV and not using a HD box.
Jun 20, 2014 | LG 50" 5700 Series LED HDTV - 50LN5700
Hello, pretty simple probably. How do I use the entire screen for the picture, I can hardly read the news scrolls that come at the bottom of the screen cuz of the 3 inches of black border all the way...
No.Some u can't changes the tv picture on the screen sizes,because depending the bandwith of ur tv are recieving.Most u can changes the tv on picture to wider screen or to fit the whole tv screen.U have the tv original remote wright?Yes.Look a button that said like Viewmode,Aspect Ratio,Picture sizes,Zoomming.Pushes one of these name buttons u will able to changes tv on screen pictures sizes.
Aug 23, 2011 | Vizio 42 in. LCD TV
Black border with some channels
if you mean the left and right sides of screen, look for a button on remote might be labeled several things, like picture size, aspect etc.. the borders pop up when you go to a non high def channel. some chs put borders all around the picture in those cases you won't be able to get rid of those.
Apr 07, 2010 | Memorex MVDT2002 20" TV
Computer screen isnt working properly
Hi, Lady
I am Sandeep could you please let me know the exact issue, Are you not able to see the clear pictures, text , blurr images, Font size is big, Black border around image or Black border at all sides of the screen,
Please let me know the exact issue and marka mail to my E-Mail address, I am an Hp certified technican,
With regards,
Sandeep.
raigirisandeep@yahoomail.com
Feb 15, 2010 | E-Machines eMachines Desktop PC
Picture problem
I had the same exact same problem. You can get a repair kit from this site. http:///www.magnavoxhelp.com
Aug 29, 2008 | Philips Magnavox 51MP392H Rear Projection...
Gray borders on the HD channels
Have you tried to change the screen size? To do that press the "Psize" button on the remote till you find what you need.
Dec 29, 2007 | Samsung LN-S3251D 32 in. LCD HDTV
Picture size is always too big. No matter what the zoom setting or display setting, the image borders fall outside the screen. AKAKI tech support tel # is diconnected.
there are only normally 4 options for picture size, 4:3, 16:9, 16:9 zoom and auto, unless you are using High definition. Any other settings should be found in your cable reciever box as the picture size can be altered in its settings also.
Mitsubishi WS-55807 TV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
