Question about Philips Televison & Video
Philips 32PW9536 TV, bought in 2002. Screen has been losing resolution gradually for a while, and now onscreen text (PS3, Wii, Satellite TV, even the TV's own menus) is almost unreadable. Occasionally it clears if the TV has been on for a while, but this is unusual. Just wondered if this is indicative of the TV being on its way out, or could it be something reversible?
  • Philips Master
  • 458 Answers
This is very likely the tube is starting to show signs of age, If you turn up your contrast or brightness level does it make the picture look smeary? Your description of the menus does suggest strongly that the tube is the problem & seven years old this is not un-common.
Posted on Jul 15, 2009
Where to start.....alright. I currently have a softmodded Wii console, and I recently bought third party component cables for it. The cables work fine under Standard TV resolution (480i), but when I change...
From the Wii Channels menu, click the "Wii" button on the lower left of the screen. From there choose: Wii Settings > Screen > TV Resolution. In this menu, click on the "EDTV or HDTV (480p)" option and then click "confirm".
Aug 07, 2013 | Nintendo Wii Console
When i turn on my ps3 you hear the sound but the screen remains solid green. What can i do?
Hello
Try this
Reset the PS3. To do this, turn off your PS3, then hold down power button for about 5 seconds until the PS3 beeps. Follow your onscreen prompts to finish resetting the PS3
Also check all input cables,and resolution for tv.
Sep 19, 2011 | Sony Playstation 3 (PS3) Console
How do i connect a playstation 3 to a philips tv
The PlayStation 3 (PS3) is a high-definition gaming console that supports both standard AV connections and high-resolution connections (such as HDMI). Most of the older Philips TVs come with a standard AV input. Newer, flat-panel Philips TVs include standard AV inputs and high-resolution inputs. To get the best video quality out of your PS3, using an HDMI connection is recommended if the option is available. The PS3 does not include an HDMI cable, only a standard AV cable
Standard AV
  • 1 Turn off the PS3.
  • 2 Connect the flat end of the PS3 AV cable into the "AV Multi Out" port on the back of the PS3.
  • 3 Connect the "red," "white" and "yellow" prongs on the opposite end of the PS3 AV cable into the corresponding "red," "white" and "yellow" AV inputs on the TV (usually located on the side or in the back).
  • 4 Press the "Source" button on the Philips TV remote.
  • 5 Select the "AV" video display mode.
  • 6 Turn on the PS3. The PS3 logo will appear on the screen.
  • HDMI Connection
    Dec 08, 2010 | Philips Televison & Video
    ''Please change your computer screen's resolution''
    i just bought a philips tv and i have the same problem, have you found a solution?
    May 03, 2010 | Emerson LC320EM9 32 in. LCD HDTV
    Flickering in the main PS3 screen with 1080p resolution
    1080 i is what you run going to higher resulution causes that your provider is 1080i or 1080p
    May 02, 2010 | Sony Playstation 3 (PS3) Console
    50' philips plasma tv has sound but picture is distorted
    I sugest you to change the video resolution settings on the PS-3 to see if TV sets to any one resolution...if you have any other video out (analog from PS3)...connect the out to TV and check video at different resolutions. If PS3 has Deep Color settings turn it OFF.
    Apr 10, 2010 | Philips 50PFP5332D 50 in. Plasma...
    Ps3 as no video or sound i bought 3 wires for the tv and no color or soud sows we even used a ps2 cable
    Excerpt from the PlayStation 3 Manual:
    There is no picture on the TV screen.
    *Check that the input mode of the TV is appropriate for the connector in use on the system.
    *There may be a problem with the AV cable in use. Try using another cable that is compatible with the PS3 system.
    *If the video output settings on the system do not match those of the cable or TV in use, there may be no picture. If the screen goes blank, turn off the system. Then, with only the system and the TV connected, touch the system's power button for more than 5 seconds to turn the system back on. The video output settings will automatically be reset to the standard resolution.
    *If the resolution of the video content is not supported by the TV in use, when the video is played the screen may go blank. If this happens, go to the screen for selecting the resolution in the system's video output settings, select "Custom" and then select all the resolutions that are supported by the TV.
    Jul 29, 2009 | Sony Playstation 3 (PS3) Console
    Resolution problems/ Game problems
    Well it might be becuase your ps3 is european. Im no expert on the matter, but when i bought an hdmi cable and hooked it up to my hd compatible tv, i switched to the hd input (which happened to be input4 on my tv) and a message popped up saying that the ps3 has detected hd output, would you like to change settings? and it did it automatically after i hit yes.
    Jan 10, 2009 | Sony Playstation 3 (PS3) Console
    Wii Delay on new Insignia TV
    We just upgraded from a 32" LG tube tv to a 46" Insignia LCD and had the same problem with our Wii and PS3. For us, we just switched the TV settings DCM (digital clear motion) function. We keep it on high for movies and TV shows and turn it completely off when playing Wii and PS3 games. Hope this helps!!
    May 09, 2008 | Televison & Video
    Televison & Video Logo
    65 people viewed this question
    Top Philips Televison & Video Experts
    matt martin
    matt martin
    Jaime Hernandez
    Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
