Question about Kitchen Ranges
Pilot ignitor comes on but main gas will not come on
  • 55 Answers
Hello. If the ignitor is on but not lighting it is because the ignitor is not drawing the proper ohms to make the valve actuate. You will need to replace the ignitor. Provide me with the model number and I will get you the part number you need.
Posted on Jul 15, 2009
Burner won't come on or shut off have to manually hold contact open
On some gas-powered appliances -- such as gas ranges, water heaters, boilers and gas fireplaces -- the pilot light works to ignite the main flame when the gas is switched on to the burner by the regulating valve. If the pilot light is not lit, the gas burner will not ignite, which could cause a dangerous situation by letting highly flammable gas escape into the air. If the pilot light goes out, you can relight it after the gas is shut off using a match or the unit's electronic ignitor if it has one, following the proper safety precautions
Nov 12, 2017 | Heating & Cooling
I have a pitco 18ss-gv.the pilot is lit, but the ignitor wont fire the burners on. It worked last night, but not today for some reason.
Where the pilot light is should be a small copper tube connected to a smaller copper tube that goes back to the main gas valve. It's called a thermocouple. That's what tells the main gas valve the pilot is lit and allows the main burner to come on only when the pilot is burning so it doesn't flood the room with gas. The thermocouple is most likely bad. They usually have them at hardware stores like ace or you can have a professional replace it. It's fairly simple, if you do it yourself, bring the old one with you to the hardware store.
Dec 27, 2016 | Kitchen Appliances - Others
When the heat cycle calls for gas there is no ignition is my gas valve bad?
I don't know what kind of furnace you have. But most furnaces have some sort of pilot first than after it is proven than the main gas will come on. Either a standing Pilot with a thermocouple. A hot surface ignition or Spark ignition with a flame sensor. Or a direct fire system where hot surface or spark ignitor start first than all the burners send a 1 sec blast of gas which is proven by the flame sensor if it proves the gas valve stays on.....
In what you have said you have 24 volts to the gas valve and it has not lite. then does the gas valve have a pilot tube???Does it have a thermocouple?? Do you smell gas?? If you don't smell gas then the main part of the valve has not opened. The Pilot valve has to open first and prove before the main gas will come on. I hope this helps. If you still need help repost with the name and model # of the furnace.
Nov 18, 2013 | Honeywell Furnace Gas Valve Sv9501h2409
Honeywell sv9520
check for gas at pilot tube first . if there and pilot not lighting then pilot line or orifice is clogged. if pilot is lighting check for 24v to main gas valve terminals. if have voltage either you have a bad gas valve or carry over tube on rack is clogged . if older unit clean carry over tube reinstall and check for voltage and if lights if not then gas valve is bad
Oct 24, 2013 | Heating & Cooling
I lit my gas fireplace and left the room. When I came back both the pilot and main burner were off. I figured my t-couple dropped out. Turned the valve to pilot, pressed the knob down, hit the ignitor and...
Pilot must have gone out along with main burner ,but it takes 30 secs to shut off would say you hit the ignitor at the wrong time to blow out glass . So you will need a new glass if broken , clean pilot and burner I would change thermocouple , then checkif gas valve is not sticking open . Maybe best to get local gas company to check this all out.
Dec 31, 2012 | Heating & Cooling
I have a sv9500m 2674 tha has a sticker that says it has been converted to L P gas. The ignitor lights the pilot and the fan comes on. The pilot stays lit and the main furnace fan comes on but the burner...
Hello,If you cleaned the flame sensor and it is in the pilot flame,Try adding a ground wire from the pilot assembly to any close screw to boost the (pilot on) signal.Also if the valve has been sitting for a while give a tap once during (pilot on) to make sure the diaphram is just not hung up.I would hate to replace the valve and still have the same problem.
Oct 15, 2010 | Honeywell Heating & Cooling
My pilot light comes on< but the oven will not
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
May 13, 2010 | Magic Chef 31000 Gas Kitchen Range
Rheem/GE power vent water heater, pilot lites, but not the main
I would check to see if the switch on the blower pressure sensor is closing...When T-stat calls for flame, the circuit starts the blower, then the blower pressure sensor switch closes to allow the main gas valve to be powered.
Jul 08, 2009 | Water Heaters
Raypak 207a ignition issue
Is the ignitor sparking when it clicks?  If no spark then bad ignitor.  Is gas flowing to pilot?  If no gas then clogged line or bad pilot gas valve.
May 29, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
GE GAS RANGE OVEN PROBLEM
two options.first does the pilot flame look good (a nice blue flame)?if so you will see a metal probe next to the pilot,use some sandpaper and clean that probe up.if that solves your problem so be it.second if the first thing doesnt work its probably the ignitor board not sensing the flame.the way to definitly tell the one or the other use a small torch and heat up the probe like i said and turn the oven on.if the main burner comes on then you know its the probe which is called a thermocouple and is cheap.hope this helps.
Aug 08, 2007 | GE JGBC20 Gas Kitchen Range
Kitchen Ranges Logo
44 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
