Question about IBM Wheelwriter 30 Typewriter
I have lost my settings
According to the manual I have lost my settings because the indicator light panel keeps blinking. I have replaced the batteries and I have checked the ribbon and printwheel. I have tried turning it off after I replaced the batteries but all it does is beep a few times then continually blink.
Can I reset the settings or do I need to call for service?
  • IBM Master
  • 3,594 Answers
You probably have a bad keyboard but you didn't say what molel it is. Unplug the keyboard, if the problem stays the same it's the keyboard. Contact George Beyers Co. @ 800--392-8085 they do a great job on keyboards.
DickyO
Posted on Jul 15, 2009
Why is the front panel screen HP DesignJet 4020ps plotter show a blank screen with a blinking green light?
According to the manual, a blinking green power light indicates that the unit is transition between off and on.
Dec 30, 2014 | HP DesignJet 4020PS InkJet Plotter Printer
I just bought the Panasonic KX-TG9341T. This model has 4 remote extensions. My problem is the light on top of each phone keeps blinking. I checked to be sure I don't have any messages or anything else,...
The message indicator lights up when you have a new voicemail message, answering machine message, when you are receiving a call, or when the handset is placed on the charger. You can change the setting for the voicemail indicator and message indicator by pressing [MENU], [#][3][4][0], and press [▲] or [▼] to switch between off and on, then select [Save]. It is not possible to turn off the LED for an incoming call, or while it is on the charger.
Good luck...
Sep 05, 2008 | Panasonic Lands Phones
I bought a glowbuoy about a year and a half ago. I have only used it 2 or 3 times. I recently went to use it. I recharged the battery but when I tried to turn it on there was no light.red light steel...
According to the owner's manual for this pool light, a blinking red light indicates that an error has occured during charging. It says that if you have unplugged and tried again and still have a blinking red light, the condition of the battery is questionable and it might need to be replaced. The only place that you can purchase these replacement batteries is from an authorized pool store or directly from the manufacturer. You will not be able to replace the batteries yourself.
Jul 01, 2010 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
Tcp42x1 wont power on, red light blinks 7 time
hello, one thing that is good is that these panasonics have a safety fualt feature the light blinks and the number of blinks indicate what board is affected. the best way to find out what to exchange is by aquiring a service manual for your brand and model tv then review the service manual it will tell you according the the blinks what to replace or what board is bad..hope this helps..
Jun 06, 2010 | Panasonic TH-42PX60U Television
I've lost my manual. Does the red light that
The red light that looks like an empty cylinder on the Sharp AL 1631 Grayscale Copier panel is the "drum replacement required" indicator. The "cartridge replacement" indicator is represented by 6 dots forming a triangular shape.
The drum replacement indicator lights up when there are about 1000 copies left until its end of life. It is only when the indicator starts blinking that the drum really needs replacement.
The part number for the drum is AL-100DR.
I hope this helps.
Nov 19, 2009 | Sharp AL 1631 Copier
After a power outage,the tv wont turn all the way on,the blue light keeps blinking.why?
hello, if you have a blinking light this means theres a voltage drop or failure causing a circut fault some where inside, you need to find a service manual for your set or have it checked out by a tech. there are high voltages and live circuts inside so if your attempting a fix on your own be aware of this and get a service manual it will tell you according to the blinks whats the trouble or what part to replace or service. hope this helps.
Oct 14, 2009 | Televison & Video
Philips 42" plasma -- blinking red light
hello, if you have no picture with blinking or flashing leds this means you will need service. its a common problem with these newer sets they have built in protection circut that cuase the tv to shut down and start blinking. this indicates a power problem and according to the number of blinks indicates the fualt location for the repair tech..
it is not something easily reset or user repairable
hope this helps
Dec 18, 2008 | Philips Televison & Video
Panasonic TV pt-50lc13 bulb replacement
Take the bulb out, there should be a access panel in the front, power the set on,(be sure to have the lamp door closed) if you hear a rapid ticking noise from the set, the Ballast is trying to fire the lamp, this is a good indication that the set is functional but the lamp needs to be replaced. If not, the ballast is not getting the voltage needed to start the lamp.
Sep 09, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Durabrand PDV709
According to the manual "the LED Indicator will flash when charging the battery and will be steadily on when the battery is fully charged."
If you would like a copy of the manual, I can sell you one for $8.99 including shipping to lower 48 states. If interested, email me at 1topwop@comcast.net.
warm regards,
Marisa
Jun 22, 2008 | Durabrand PDV-705 Portable DVD Player
IBM Wheelwriter 30 Typewriter Logo
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
