It's most likely that you have a loose or bad cable. Specifically, the pins handling blue are probably bad or loose; either 3 or 8. Take a look at the image below and it will help to see why this iis happening.
If your cable is built in to the display then it could be diffcult to fix but if your cable has connectors on both ends it is pretty simple to just get another one and try it. Be sure to inspect the pins on the connectors at both ends and carefully straighten any that are out of place.
There's also an outside chance that the same issue is occuring either on the video card itself or internal to the display.
Hello there, I hope you can help. My laptop screen has turn all whites to yellow tint. How can I...
(More)
Hello there, I hope you can help. My laptop screen has turn all whites to yellow tint. How can I rectify this back to clean white? Please advise. Kind regards, wot2eat
A kid was playing with the front control functions and on my eView17s and now the tops of screens...
(More)
A kid was playing with the front control functions and on my eView17s and now the tops of screens don't display. (Ex. The Edit and Review areas of Word) Instruction book says to press "R" for reset to factory settings but my model doesn't have a front location reset button. How do I get the monitor display to original factory settings?
h.p. laptop monitor model zd702ous the monitor screen has gone yellow. used to be intermittent now...
(More)
h.p. laptop monitor model zd702ous the monitor screen has gone yellow. used to be intermittent now stays yellow
span.jajahWrapper { font-size:1em; color:#B11196; text-decoration:underline; } a.jajahLink { color:#000000; text-decoration:none; } span.jajahInLink:hover { background-color:#B11196; }
we have one crt with ttl signal of video and the different frequency of vertical and horizontal...
(More)
WE HAVE ONE CRT WITH TTL SIGNAL OF VIDEO AND THE DIFFERENT FREQUENCY OF VERTICAL AND HORIZONTAL SIGNALS THAN A MONITOR.THIS CRT MADE IN MOTOROLA COMPANY AND WE WANT CONVERT THIS CRT TO MONITOR BECAUSE THE QUALITY OF VIDEO AT IT WEAK .HOW WE CAN DO IT.
the monitor menu pops up and wont go away when pressing exit. Ive tried to update the driver. It...
(More)
the monitor menu pops up and wont go away when pressing exit. Ive tried to update the driver. It just pops up then goes away. Doesnt let me control the functions with the 4 buttons on the front of the monitor.
