Question about Dell W3000 30 in. HD-Ready LCD Television
My 42 Inch Plasma television started becoming slow about coming on. Then red & green streaks came across the screen then it would not power on. The blue power light will come on but the picture or sound will not come on.
  • 3,741 Answers
NO VOLUME bars means your Display panel isn't even PRIMING (that's when the panel "gently lights up" before the video comes online)
That also means that either the X-sus, Y-sus or the Z-sus board isn't powering up the pixels....I doubt the power supply is faulty since you dont get the sound.
it has to be checked by a meter to locate the faulty part.
you can get the required parts at
www.partstore.com
thanks.
Please do rate the solution. Thank you for using fixya.keep updated. thanks
Posted on Jul 15, 2009
VIZIO Tv E422VA picture showing red or green color on dark areas of screen.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Oct 29, 2015 | Vizio E422VA 42-inch Widescreen LCD TV -...
Why does my Hitachi 42HDS69 42 inch Plasma TV have horizontal green lines across the screen? I have checked all connections and tried to tweek the color settings but nothing has helped. I went thru th
Line, faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Dec 13, 2014 | Hitachi 42HDS69 42 in. Plasma Television
Philips flat screen 42" flashing red light 7 times it stops for 5 seconds and 7 more flashes if i unplug and plug it a few time it will come on
my 42 inch phillips, i turn it on green light comes on for 10 sec then red light comes on and flashes 4 times then stops for 5 sec then repeats.
Apr 20, 2010 | Philips 42PF9631D 42 in. Plasma Television
Phillips 42 inch LCD 42PF9730A Redlight flashing
Common short the cover cap over the video & sound boards short out if you remove it the cap only (shield metal) it usually will fix this
Jun 16, 2009 | Philips 42PF9631D 42 in. Plasma Television
Vertical lines on screen
1. Frist on the BURN MODE.
2. Check whether same
Vertical lines on screen ?? 3. If yes ..?
4. Then change the LOGIC BOARD or PDP
Jan 11, 2009 | Hitachi 42HDS69 42 in. Plasma Television
42'plasma phillips tv
I had the same problem and fixed with a great online tutorial. Just replace 3 capacitors available at Radioshack onthe the board. 2662, 2663, 2664 1 is a 1000uf the others are 100uf. Max Volts need to be over 25. It worked great, check http://dynamicorange.com/2008/06/25/fixing-a-plasma-tv/
for more detail.
Jan 06, 2009 | Philips 42FD9932 42 in. Plasma Television
Philips Plasma Flashing Red
every plasma tv ive come across with this symptom eneded up beeing a new panel. what i do is replace the x and y sustain boards and if that dont work youll need a new panel.
Sep 08, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Red line across top half of screen
My maxent 42" has green and red flashing pixels all across the screen, what is the problem?
Thanks
Aug 30, 2007 | Maxent MX-50X3 50 in. HD-Ready Plasma...
Dell W3000 30 in. HD-Ready LCD Television Logo
27 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
gwix50
Level 1 Expert
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
