1997 Ford Expedition Logo
L
Larry Nelson Posted on Feb 07, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The windshield washer spray button wasn't making contact. I replaced the wiper control with a junk yard part. It was likely from a 2001 model. It looks exactly the same as the old one.
Now the wiper control does not work correctly. The wipers run constantly, in any position, even in the off position. In the low and high position, the washer pump runs. Everything but the washer pump button switch worked before changing the control. What could have happened? What do I do to troubleshoot and fix this problem?
John Trigg
Level 2:
Sergeant:
  • Expert 250 Answers
  • Posted on Feb 07, 2016
John Trigg
Expert
Level 2:
Sergeant:
Answers
250
Questions
Helped
61731
Points
746
First thing to do is to get rid of the part you put in, because obviously it's not right. Replace it with the EXACT SAME part, and you should be OK.
3answers
The wipers quit on the 2006 Chevy Colorado. They are on separate motors. We have replaced both fuses and both relays, and now have replaced the multi-function switch on the steering column
wipers-yvtjdmwsd3lmjasjqz1fi5jn-6-0.jpg My database only shows one wiper motor. Did you check voltage and ground, anywhere? Check the wiper fuse for voltage, hot all the time, use test light. At the wiper motor, dark green wire is voltage for lo speed. The purple wire is voltage for hi speed, Turn on key, turn on wiper switch, probe those two wires for voltage, use a test light. That bottom black wire off wiper motor, in diagram, is ground, check that also. If good voltage and ground with no wiper action, I suspect the wiper motor. There are codes for wiper, manufacturer codes, check for codes. good luck
Wipers not working 2009 Pontiac G6 Wiper Motor where is the fuse located so that I can check it? Before I replace the motor
Just replacing parts isn't the way to fix this problem , viewing wiring diagrams too see what all is involved in making the wipers work is . Then using a digital volt ohmmeter to test electrical circuits . Also looking at factory service info. to see how it's suppose to work.
Free wiring diagrams here http://www.bbbind.com/free-tsb/ Enter vehicle info. year , make , model an engine size . Under system click on body & accessories , then under subsystem click on wiper/washer . Click the search button ,then click the blue link. Looking at the wiring diagram i see two fuse's an two relays that are controlled by the BCM - body control module . Also hooking up a scan tool that can read BCM DTC'S - diagnostic trouble codes could be helpful . The wiper switch is a input to the BCM - the BCM will energize the relays to turn on the wipers.
Wiper/Washer System Components
The Wiper/Washer System consists of the following components:
• Windshield wiper/washer switch
• Body control module (BCM)
• Wiper 1 relay
• Wiper 2 relay
• Wiper diode
• Windshield wiper motor
• Windshield washer pump
• Windshield washer nozzles
• Windshield washer solvent container
• Windshield wiper arm and blade assemblies
• Windshield wiper transmission
• WIPER/SW 10A fuse
• WIPER 25A fuse
Wiper/Washer System Description
The body control module (BCM) controls wiper motor low speed operation. The washer pump and high speed operation are controlled directly by the wiper/washer switch. The windshield wiper/washer switch supplies voltage on the signal circuits to the BCM for windshield wiper/washer operation. When WASH, MIST, DELAY, LOW, or HIGH is detected, the BCM energizes the wiper 1 relay by suppling voltage to the relay coil. This allows battery voltage from the WIPER fuse to flow through the relay switched input then through the contacts and out the relay contacts to the wiper 2 relay switch contacts. Since the wiper 2 relay switch contacts are normally closed to the low speed circuit of the windshield wiper motor, the motor will operate at low speed.
DTC B3715 02: Front Wiper Relay Drive Circuit Short to Ground
DTC B3715 05: Front Wiper Relay Drive Circuit Short to Battery or Open
Windshield wipers on a Chevy 2005 trailblazer only works on high
Do you know how to test automotive electrical circuit's using a DVOM - digital volt ohmmeter ? Do you know what a wiring diagram is an how to read one ? Free wiring diagrams here http://www.bbbind.com/free-tsb Enter vehicle info. year , make , model an engine size. Under system click on body & accessories ,then under subsystem click on wiper/ washer's . Click the search button then the blue link.
Windshield Wiper/Washer System Components
The windshield wiper/washer system consists of the following components:
• Windshield washer relay
• Outside moisture sensor
• FRT WIPER 25A fuse
• W/S WASH 15A fuse
Windshield Wiper/Washer System Operation
Accessory voltage and ground is supplied to the windshield wiper motor and provides the power for operating the wiper motor and logic power to the wiper motor module. The WASH, MIST, LOW, and DELAY modes are controlled by the windshield wiper/washer switch through a series of internal resistors. The windshield wiper switch supply voltage circuit is a 12-volt reference from the wiper motor module to the wiper/washer switch, and the switch position determines the point on the resistor assembly where the reference voltage is applied. The windshield wiper switch signal 1 circuit supplies the voltage from the resistor assembly to the wiper motor module and the signal voltage determines the operating mode. High speed operation is controlled by the windshield wiper/washer switch through the windshield wiper switch high signal circuit. The windshield wiper switch high signal circuit is supplied 12 volts by the wiper motor module and when the wiper/washer switch is turned to the HIGH position the windshield wiper switch high signal circuit is grounded through the switch ground circuit. The windshield washer pump is controlled through the windshield wash relay. The windshield wash relay coil and switch is supplied battery positive voltage, and during WASH mode the wiper motor module grounds the washer relay control circuit energizing the relay. When the relay is energized battery positive voltage to the switch side of the relay is supplied to the washer pump control circuit.
1helpful
Wipers will not turn on 2006 colorado
There are two relay's in the under hood fuse / relay box . Wiper relay an wiper relay 2 . Maybe one is bad . also check fuse #14 25 amp. Wiper fuse.Plus the BCM - body control module has a hand in making the wipers work . Are you familiar with automotive electronic control modules ?
• Wiper micro relay
• Wiper 2 relay
• Wiper diode
• WIP/WASH 10A fuse
• WIPER 25A fuse
The body control module (BCM) controls wiper motor low speed operation. The washer pump and high speed operation are controlled directly by the wiper/washer switch. The windshield wiper/washer switch supplies voltage on the signal circuits to the BCM for windshield wiper/washer operation. When WASH, MIST, DELAY, LOW, or HIGH is detected, the BCM energizes the wiper micro relay by suppling voltage to the relay coil. This allows battery voltage from the WIPER fuse to flow through the relay switched input then through the contacts and out the relay switched output to the wiper 2 relay switch contacts. Since the wiper 2 relay switch contacts are normally closed to the low speed circuit of the windshield wiper motor, the motor will operate at low speed.
Do you have any speed !
How do I find out if the wipers on my 2006 H3 Hummeris on a relay?
• Wiper micro relay
• Wiper 2 relay
• Wiper diode
• WIP/WASH 10A fuse
• WIPER 25A fuse
Low Speed Operation
When the wiper switch is in the Low position, voltage is supplied through an internal resistor to the signal circuit. The body control module (BCM) monitors the windshield wiper switch signal 1 circuit, and energizes the wiper micro relay which will operate the windshield wiper motor. The wiper motor will operate at low speed, since the wiper 2 relay is de-energized. Low speed can also be commanded with a scan tool, by commanding Wiper Relay Cmd. ON and OFF. Refer to Scan Tool Output Controls .
High Speed Operation
In the High position, the windshield wiper/washer switch supplies voltage to both the wiper micro relay and wiper 2 relay coils. This energizes both relays and allows battery voltage from the wiper micro relay switched output to the switched input of the wiper 2 relay through its contacts and out the switched output of the wiper 2 relay to the high speed circuit of the windshield wiper motor. The windshield wiper motor will operate at high speed. During high speed wiper motor operation the wiper switch signal circuit is at the low speed signal voltage, and the body control module (BCM) supplies redundant voltage to the wiper relay via the wiper diode.
This info is out of hummer factory service manual !
1helpful
2001 Jetta winshield wiper arm spring
Yes, start calling junk yards for the whole wiper arm or order the arm at your vw dealer, you will not find just the spring. Good Luck
4helpful
2001 Buick Regal LS windshield washer fluid does not spray
There are a number of different issues that could cause this.
-The circuit for the wiper should be the same as the washer; same fuse. -I'd suggest trying to run the washer while the hood is open and the engine off. If it runs, you should hear a dull whine.(a 2nd person might be of use to help look and listen)...(find the pump by following the hoses from the wipers to a unit mounted close to the dashboard in the engine compartment)
-If it runs, check to see if any fluid is coming from a hose that might have become disconnected.
-If the pump runs, and if you see no fluid coming from anywhere, and if you can reach the hose connected to the washer pump, pull that hose off the pump. Try running the pump again to see if anything comes out in a good stream.
-If the pump doesn't run at all, check to make sure the connector hasn't come loose.
-If the pump still doesn't run, check to see if you have 12 volts at the connector at the pump. A simple check can be done with an auto bulb connected to the plug at the motor while the pump switch is pushed.
-If you have power at that point, you likely need to replace the pump and motor.(depending upon the age of vehicle & your mechanical abilities...a call to a local wrecking yard is suggested ..atleast to compare the cost vs. new)
hope that helps
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
