Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
Frigidaire FEZ83AS1 washing machine fills with water but won't start cycle
My (washer/dryer, stacked) washing machine fills with water but won't start cycle. It's intermittent. Sometimes it will start right away and sometimes it will sit with the clothes and water in it for hours and then it will start.
I will change the cycles (whites to colors), the wash time (4, 8, 12), i will stop and start the cycle or i will turn the tumbler (the thing that sits in the washing machine...and nothing works. please advise.
  • Tony55440 Jan 07, 2008
    This unit is seven years old and has worked fine until a few weeks ago. It will fill but when agitation tries to start it makes a humming sound for 15 seconds and then sits for five minutes and repeats this until I turn it off or it starts. Could start in an hour, half hour, overnight or not at all. Will do this on and off for a week or two then work fine for a week or month.
    All other functions work. Jumped the lid switch even though it always agitated with the lid open. Checked the capacitor and seemed fine as much as and ohm meter can indicate. Disconnected the capacitor and it made the same sound but spin stopped working.
    When it happens there is no reason and nothing can be done to start it, just let it sit and will start running when it wants to.
    Can this be a thermal breaker problem and is it replaceable by it self or is it part of the motor?
  • 3 Answers
I bet it's the electronic card of the machine in both cases. If you are handy, you can dismount it and try to find some broken/burned component or something strange. I'd go for a broken capacitor, but it may not be at sight. You'll have to check them all with a proper tool (generally, a home tester is not useful for capacitors).
Posted on Nov 07, 2012
  • 196 Answers
I will answer this in two parts.
1. Sounds like a worn lid switch. Some Units will not start if this switch is worn/faulty. This can cause intermittent switch contact.
2. The motor thermal switch is a definite possibility. This switch is part of the motor assembly and cannot be replaced by itself.
Posted on Jan 08, 2008
Why is my Amanda 7300 tandem washing machine not doing the wash cycle? It stops after water has filled and stats to beep 3 times in intervals....
Sometimes this can happen when the power button does not return completely when pressed in. My cheap & cheerful solution was to use a bit of Blu-Tak on the button, so I could pull it all the way out.
Sep 23, 2016 | Amana Tandem 7300 Washer and Dryer Stack...
Kenmore Model 21082000 won't fill during wash cycle
Try checking the lid switch. Sometimes the switch goes bad or the stem breakes and when the lid shuts it will not activate the switch. Usually located on the right side of the dryer. When the lid closes it will allow water to.fill. Washers are easy to fix and the part is cheap. Get it from amazon dont pay the crazy price your dealer wants. Trust me, i just fixed my mothers...
Feb 16, 2013 | Kenmore Calypso
Kenmore stackable washer wont work on Cold cycle only hot water
Here are a couple of tips that I wrote to help people that are having problems with the washing machine not filling...
Washing Machine2_bing.gif Problems No Water
Washing Machine Fix Washing Machine No Water
May 07, 2010 | Kenmore 98702 Stacked Washer/Dryer
Won't fill with water and goes right to wash cycle
Chech the pressure lelvel switch and hose that is connect to the pressure switch and tub
Mar 25, 2010 | Frigidaire FEX831CS Top Load Stacked...
Maytag s1000 stacked washer will not start water fill and cycles.
could be wash spin relay stuck in spin must be 15 years old
Feb 19, 2009 | Maytag LSE7806A Top Load Stacked...
Water fills the washer during spin cycle
defective timer...a model # should be under the lid...or open dryer door and on front dryer panel right hand corner..onthejob
Jan 16, 2009 | Whirlpool LTE5243D Top Load Stacked...
MLE2000 front load washer
Hi..I had the same problem yesterday...the maching would start when I pushed the button and then stop..I had to push the button again to get it going..My stacked set is around 8 years old.
Here's what we did..moved the washer away from the water source and unscrewed the water intake lines..there is a little screen there...took the screen out of both hot and cold screen has some debris in it..the other was almost completely blocked..we are on a well and sometimes dirt..etc..gets in the lines..
Today no problems doing the laundry..its working like new..
Oct 26, 2008 | Maytag MLE2000 Front Load Stacked Washer /...
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
157 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
