Question about PC Desktops
Jumper settings for old Compaq M/B to accept AMD K6 2 500
Hi all
I am attempting the above but have no reference with which to set the jumpers to do so. I am more worried about the core voltage than the speed settings but would prefer correct settings for all.
I'm removing a Cyrix MII 333Mhz processor with is set to operate at 249MHz or 83MHz Bus speed with 3 x Clock multiplier (I assume) but operating at 2.9V Core Voltage
The M/B is in an old Presario Desktop 2282 and the labelling on the board is:
PCA P/N : 387432 - 001
PCB P/N : 01090 - 001
SPARE P/N : 387610 - 001
And the three jumpers as as follows:
3 Banks of 3 jumpers with pin 1 assignment markings and columns labelled CLK0 CLK1 CLK2. The following is an approximation using '===' as jumpers and 'o' for open posts. ALso '|' is PIN 1 assignment.
=== o | CLK0
=== o | CLK1
o === | CLK2
Second jumper J32 is again 3 banks of 3, however the row labels are FREQ0 FREQ1 FREQ2. Once again the following is an approximation with the same usage as above:
FREQ0 o === |
FREQ1 === o |
FREQ2 o o o |
The 3rd bank, J29 which I assume is for Core Voltage is 4 banks of 2 with the following closed for 2.9V
o o
o o
I can't find any references to this board so I was kinda hoping someone would know this information anyway.
Any help is appreciated as have been stuck for a number of weeks with someplaces not even registering that I have made an inquiry?
Thanks in advance.
    Problem Solver:
Re: Jumper settings for old Compaq M/B to accept AMD K6 2...
That motherboard will not support that processor.sorry for the bad news!!!
Posted on Nov 18, 2007
0 characters
3 Points
Power on password
What are you looking to do with the power on password?
You can typically reset it by pulling a jumper on the motherboard. I've attached the user manual for your system below, consult it to locate this jumper:
HP Compaq 6005 Pro Series QuickSpecs c04123349 pdf
Hope this helps!
Feb 20, 2015 | HP Compaq 6005 Pro SK557UC Small Form...
I'm refering to jumpers on the mobo itself. The only one that was on it was the cmos jumper. There are places where other jumpers could go. I thought that perhaps I had accidently knock one off
Jumpers can go on Hard drive, but it is no longer usefull since with SATA connectors, you don't have to specify with a Jumper which one is the master or slave HD.
Feb 28, 2013 | Acer Aspire M3100-U3401A Refurbished...
How can i reset my bios password ,logged out/dell computer
You can call Dell and they can reset the bios password for you. But if it doesn't have a warranty anymore you can simple open the casing of your computer and there's pin(jumper) on the motherboard that you can pull out and then put it back in. The password will be reset.
Oct 27, 2010 | Dell Dimension 4600 PC Desktop
My computer has a password on it when you hit the f2 button. How do I retrieve the password
Backdoor Passwords READ COMPLETELY!!
Many BIOS manufacturers have provided backdoor passwords that can be used to access the BIOS setup in the event you have lost your password. These passwords are case sensitive, so you may wish to try a variety of combinations.
WARNING: Some BIOS configurations will lock you out of the system completely if you type in an incorrect password more than 3 times. Read your manufacturers documentation for the BIOS setting before you begin typing in passwords.
aLLY Condo PINT 01322222
ALLY d8on pint 589589
aPAf djonet SER 589721
_award HLT SKY_FOX 595595
AWARD_SW J64 SYXZ 598598
AWARD?SW J256 syxz
AWARD SW J262 shift + syxz
Phoenix BIOS Backdoor Passwords:phoenix PHOENIX CMOS BIOS
Misc. Common PasswordsALFAROME BIOSTAR biostar biosstar
CMOS cmos LKWPETER lkwpeter
setup SETUP Syxz Wodj
Other BIOS Passwords by ManufacturerManufacturer Password
VOBIS & IBM merlin
Dell Dell
Biostar Biostar
Compaq Compaq
Enox xo11nE
Epox central
Freetech Posterie
IWill iwill
Jetway spooml
Packard Bell bell9
Siemens SKY_FOX
Toshiba Toshiba
Toshiba BIOS
Most Toshiba laptops and some desktop systems will bypass the BIOS password if the left shift key is held down during boot
Press both mouse buttons repeatedly during the boot
Using the Motherboard "Clear CMOS" Jumper or Dipswitch settings
Many motherboards feature a set of jumpers or dipswitches that will clear the CMOS and wipe all of the custom settings including BIOS passwords. The locations of these jumpers / dipswitches will vary depending on the motherboard manufacturer and ideally you should always refer to the motherboard or computer manufacturers documentation. If the documentation is unavailable, the jumpers/dipswitches can sometimes be found along the edge of the motherboard, next to the CMOS battery, or near the processor. Some manufacturers may label the jumper / dipswitch CLEAR - CLEAR CMOS - CLR - CLRPWD - PASSWD - PASSWORD - PWD. On laptop computers, the dipswitches are usually found under the keyboard or within a compartment at the bottom of the laptop.
Please remember to unplug your PC and use a grounding strip before reaching into your PC and touching the motherboard. Once you locate and rest the jumper switches, turn the computer on and check if the password has been cleared. If it has, turn the computer off and return the jumpers or dipswitches to its original position.
Removing the CMOS Battery
The CMOS settings on most systems are buffered by a small battery that is attached to the motherboard. (It looks like a small watch battery). If you unplug the PC and remove the battery for 10-15 minutes, the CMOS may reset itself and the password should be blank. (Along with any other machine specific settings, so be sure you are familiar with manually reconfiguring the BIOS settings before you do this.) Some manufacturers backup the power to the CMOS chipset by using a capacitor, so if your first attempt fails, leave the battery out (with the system unplugged) for at least 24 hours. Some batteries are actually soldered onto the motherboard making this task more difficult. Unsoldering the battery incorrectly may damage your motherboard and other components, so please don't attempt this if you are inexperienced. Another option may be to remove the CMOS chip from the motherboard for a period of time.
Note: Removing the battery to reset the CMOS will not work for all PC's, and almost all of the newer laptops store their BIOS passwords in a manner which does not require continuous power, so removing the CMOS battery may not work at all. IBM Thinkpad laptops lock the hard drive as well as the BIOS when the supervisor password is set. If you reset the BIOS password, but cannot reset the hard drive password, you may not be able to access the drive and it will remain locked, even if you place it in a new laptop. IBM Thinkpads have special jumper switches on the motherboard, and these should be used to reset the system.
Hope it helps.
If this helps you resolve your problem, please
consider giving me a good rating .It will help me
as well. Thank you.
Sep 30, 2010 | E-Machines eMachines Desktop PC
Computer fails to boot. searching for either hard
These pins are referred to as "jumpers". Each manufacturer can have their own jumper settings. Each device should have letters indicating which pins correspond to master, slave, or cable select. The best method to insure operation is to use the cable select (CS) jumper setting. Using this setting, the hardware will be automatically configured.
Mar 11, 2010 | Compaq Presario 5000 PC Desktop
Compaq presario 5400us jumper settings
Here is the manufactures website that will lead you to the manual.
Dec 10, 2008 | Compaq Presario 5000 PC Desktop
Im looking for the jumper settings on a compaq motherboared. its a presario 7478
hello CAVdesert,
I don't think you ever have to change the jumper settings on the motherboard.You may need to change in few cases but otherwise, changing motherboard jumper settings is not recommended.
However, if you need to configure the jumper settings for your Hard Drive, CD/DVD Drive etc, Please refer to the following document.
Jumper Settings for the Installation of Hard Disks and CD, CDRW, and DVD Drives
Oct 12, 2008 | Compaq PC Desktops
HP Compaq Presario C5170 Desktop
Hello, i think you want reset CMOS
1. You can remove battery on mainboard turn PC on then off install battery.
If you see there slot with three pins and two of them are connected with connector remove connector turn on PC then turn off PC set connector.
Sep 07, 2008 | Compaq Presario 5000 PC Desktop
PC Desktops Logo
121 people viewed this question
Top PC Desktops Experts
Brian Sullivan
Brian Sullivan
Are you a PC Desktop Expert? Answer questions, earn points and help others
