Question about Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television
I have a 53 inch rear projection tv mine also shuts off right after i turn it on
  • 304 Answers
Probably the Power supply/Deflection bd has a short and needs to be replaced.
Posted on Jul 16, 2009
I think my speakers are blown on my sony 53 inch rear projection tv can I run the sound through my home theatre and bypass the blown speakers?
check your audio menu on your tv. mine can turn off the speakers and sends the audio signal out the rca's when the speakers are off.
Oct 25, 2010 | RCA P52960 52" Rear Projection Television
My 53 Inch Pansonic TV does not switch on. What would be the cause ?
Does the power light blink? If so let me know the number of blinks snd I can help you determine whats wrong.
Jun 02, 2010 | Panasonic PT-53TW53 53" Rear Projection...
52 INCH RCA REAR PROJECTION SHUTS OFF
Your TV is overheating.. easiest remedy is to point a fan at the back of the TV or... clean the inside of the TV, Im sure its full of dust and stuff... this prevents air circulation inside the TV thus creating more heat...
Jun 19, 2009 | RCA HD52W56 52" Rear Projection HDTV
SD-532HD5 TV shuts off when watching
Its is a cold solder joint on the board. The board is the one located at the bottom right of the tv when looking at the rear. Mine did the same thing. After refreshing mose of the large solder pints on the board, it stopped. Hope this helps!
Nov 11, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
53 inch Panasonic tv would not turn on..red light blinks 3 times
just a regular solder Iron will do just unsolder the old resistor and solder in the new one
Aug 27, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Tv shuts off
remove all the external connections connected to the tv.then un plug the tv wire from the power outlet.then after some time just plug only the tv wire back in the power outlet.do not connect the other devices and check if the tv is working as normal or not.if it does not works then
its the problem in the power supply board of your tv.
check for the fuse on the power supply board.
for any blown capacitors or ics.on the powersupply board.
also check for any loose soldering joints on the power supply board.
calling a tech is much advisable.if do not have proper technical knowledge.
it will not be too costly to get it repaired.
it is worth getting it repaired.as this is a common fault faced by many customers.
thanks.
May 28, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television Logo
96 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
