Question about Zanussi 24 in. ZSF6150 Free-standing Dishwasher
Wont heat up when put on to wash - Zanussi 24 in. ZSF6150 Free-standing Dishwasher
    Problem Solver:
  • 18 Answers
Try a resolder of the main PCB connections, cured my hot water problems.
Posted on Apr 23, 2010
Maytag atlantis mav600 wont heat up the cold water? brought today, we have no hot water pipe only cold the man who sold it to us says it heats up cold, does anyone know how to put it on this setting
This being a new unit you can check the manual and confirm if there is a HOT WASH. If so all what is needed is to SELECT THE HOT WASH which normally if the best wash and the longest. In this case the wattage will be specified and also the program cycle of the hot wash will be indicated.
I am not sure of this model and so needs to confirm if there is a heating element for the hot wash cycle.
Oct 16, 2011 | Maytag Atlantis MAV6000 Top Load Washer
I have a problem with my hotpoint wf340 1400 spin when i put it on it washes but wont come off the wash cycle and will continue washing unless i stop it manually i then have to select pump out and then a...
it is either a broken wire to your heating element or the element itself is open circuit. when the water does not heat the machine will not move onto next stage of wash.
Feb 20, 2011 | Hotpoint Washing Machines
Hi my wf220 won't do a full cycle the prewash flashes all the time if i put it onto wash it just sticks on wash all the time but will spin if i just set it to rinse n spin or just fast spin could you help...
My guess is heating element, if its broke it wont heat water and because the thermostat does not detect hot water the machine does not move onto next step. i suspect you will not be able to do a prewash.
Part cost ££20 to £30
My machine has same problem but im struggling to pull out the eliment.
Jan 15, 2011 | Hotpoint Aquarius WF220 Front Load Washer
Wife put washing up liquid into the machine and let it run it was full of bubbles and now it wont heat the water think the element is gone but the timer wont move past the heating stage if i replace the...
if you put manual detergent that hapend, it could burnd electronis card (or mechanical timer-programer blowup), thermostat or the presostat, the heating element must be OK.
Feb 23, 2010 | Dishwashers
Maytag performa dryer suddenly stopped working, as if no power. i replaced both fuses and it worked. ran for about 15 mins and stopped again. any suggestions?
did it blow the fuses a second time.try this .put your dryer on a cycle that wont call for heat and turn it on.if the heat strips are not on and it still blows a fuse it is the motor.if the heat strips are on and it blows a fuse the heat strips are the trouble.
Nov 05, 2009 | Maytag Performa PAV2200
Engry problem
HI
Its true you are using power to heat the water....
BUT
all the time its heating through different temperatures, different stains are removed. Also its agitating for all this time. If you put hot water in only it wont wash as long. Also the incoming temperature could be too hot for some fabrics. Also you wil be using your hot water to do all the rinses.
Its up to you, but, zanussi know what they are doing
Feb 17, 2009 | Zanussi IZ12 Front Load Washer
GE ADORA model WHDVH626FWW
you have to clean out the filter on the bottom by removing the lower panel and twisting the cap... careful lots of water comes out but will work great after
Nov 24, 2007 | GE WSXH208A Front Load Washer
Indesit w113 washing machine
check heating element (rear of drum at the bottom) for open circuit, replace if needed, occasionally the timer will start to click round continuously, indicating the machine has a fault, the machine shuts down waiting for the water to heat up, elements available at most appliance shops but you may need to order specially?
Sep 01, 2007 | Washing Machines
Baumatic btwm4 washing machine wont rinse and empty
If it wont empty its either a blocked pump/or filter. If it won't move on, heating element
Jul 11, 2007 | Baumatic BTWM4 Front Load Washer
Zanussi 24 in. ZSF6150 Free-standing Dishwasher Logo
107 people viewed this question
Top Zanussi Dishwashers Experts
paulcarew
Owen Barnes
Gerard Curran
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
