Goodman hp and air model cple30-1 outside unit icing up on auto and not when fan is on
  • 614 Answers
You have stuck contactor or a bad Tstat. Call a service tech and get a free estimate on repair. To check to see if it a bad contactor turn ac tsat to off position and see if it still runs. Open up service panel and check contactor. if possible most Goodmans have a covered contactor unless you take the cover off you can not tell Rus
Posted on Jul 15, 2009
Have ice build up on line leading into outside unit and ice buidup on inside units on my goodman air conditioner
Turn the system off on the thermostat and set the fan to "ON", this will thaw the ice faster if it hasn't already. When the system has completely thawed, which could take hours sometimes, depending on how bad it's frozen, then turn system back to "Cool" and start these checks>
1. Make sure filters are clean!
2. Make sure there is proper airflow through vents.
3. Make sure outside condenser fan motor is running.
If you have either no or minimal airflow, check the indoor blower to make sure it's working, if it is, the evaporator coil is dirty restricting the airflow. Be sure the system is thawed because the ice will also block the airflow!
If the condenser fan motor is not running, either the capacitor or the fan motor will need to be replaced.
If your filters are clean, you have good airflow through the house, and everything comes on like it should, it will most likely be the charge of refrigerant in the system is too low and you have a leak somewhere. If you have to have it charged, be sure the system is thawed before the technician gets there, he will not be able to do anything while it's froze.
Hope this helps and good luck!
Jun 08, 2012 | Goodman Heating & Cooling
I have a goodman cpk j42 -1b ac unit on the outside and a central heat and air unit inside. the ac unit come on and runs fine but when it hit the temp the thermastat clicks and the fan outside goes of but...
Hello BWOOD Check the thermostat FAN button is in AUTO position not ON position.That might be it .The relay is in the blower unit but they RARELY become frozen/welded stuck on.
Aug 30, 2010 | Heating & Cooling
Goodman Manufacturing co Model ck60-1c serial no 0001496410 , last night my downstairs was coold but my 2nd level was realy hot was not coold air this morning i went outside i found a piece ice on my unit...
If the fan motor on the outside unit is still coming on and the blower motor on the inside unit is still working properly, and your return air is not restricted (sometimes just a dirty filter), then your problem would be the charge in the unit. If over or under charged, the unit will freeze up, not just outside, but inside too. Have someone charge the unit with refrigerant and you should be okay. If any of the other problems exist, it will have to be looked into more. Hope this points you in the right direction. Good Luck!
Jul 07, 2010 | Goodman CKL60AR60 Air Conditioner
I have a Goodman A/C unit model # GSC130361F A and a Evcon
The indoor fan should cycle with the outdoor part, make sure the thermostat is not set to fan "ON" and if the fan is on "AUTO" it could be a wiring issue or a fan relay that is stuck.
May 28, 2010 | Goodman CLQ36AR49 Air Conditioner
Not cooling, water is leaking around the outside unit. plus ice has formed around hose on the unit outside. goodman model number gsh130421ac.
take a garden hose and wash the unit real good,if the unit outside cant breath this will cause it to freeze up
May 16, 2010 | Goodman CKL36AR36 Air Conditioner
Goodman A/C won't cool
Fan motor or capacitor has gone out. Running the unit with the motor not running can cause damage to your compressor
May 01, 2010 | Goodman CKL24AR24 Air Conditioner
Outside unit kicks on but inside fan sometime works and sometimes won't and i have replaced thermostat to get to work i have to turn the fan to on and back to auto several times and finally the fan inside...
Goodman air handlers (inside unit) fan have a delay timer that turn on the fan ,sometimes up to 3 minutes after the outside unit is on,this makes the a/c more efficiency.
Sep 19, 2009 | Goodman CKL36AR36 Air Conditioner
Ckl60-1l outside fan runs good,compressor do not run
Reasons for icing up are dirty filters,dirty indoor evap coil or low on refrigerant. Check these. Your compressor is probably overheated. Let it go for a couple of hours if you are in a hurry. Run a water hose over it. Rus
Jul 15, 2009 | Goodman CKL60AR60 Air Conditioner
2 to goodman ac unit model a24-08
Replace the fan relay switch in the airhandler(inside unit).
May 19, 2009 | Goodman Heating & Cooling
Heating & Cooling Logo
216 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
