Question about Canon PIXMA MP830 All-In-One InkJet Printer
CANNON SUCKS what the *&#$*# is scanner lock switch other than to **** people off.. the switch OBVIOUSLY IS NOT WORKING.
Their may be further details in the manual.
Posted on Jul 15, 2009
Why can I not run my Lide 500F scanner with a Windows 7 PC?
I have a cannon flat scanner 2000 & I came across this once before, I uninstalled all the cannon drivers then re-started the PC & next instead of using the Cannon drivers, I used Microsoft's Drivers & it's worked fine ever since.
I hope this works for yourself as well. Best Wishes. Malcolm.
Jul 17, 2014 | Canon CanoScan LiDE 500F Flatbed Scanner
Error 5010
If your printer is a Cannon, this code usually means the scanner lock is on. refer to your user or install manual to take off the scanner lock which is a plastic sliding switch located on the scanner assembly.
Dec 28, 2010 | Office Equipment & Supplies
When I turn on my MP830 Cannon the error "release the scanner lock switch and turn the power off and back on" appears. I have done it . The scanner appears to attempt moving, but does not get very far
hello, what i have found out so far, sometimes a small bit of tape they use on the scanner and ribbon cable rubs on glass, then catches on the white calibration area, but not all the time, when a machine has been used really well, and taken care of, the scanner just fails, replace whole top unit, not the doc feed, just scanner unit only, if main pcb still good machine will work just fine
Sep 21, 2010 | Canon PIXMA MP830 All-In-One InkJet...
I am repeatedly getting error code 5010 once I scan any document.
Ok it can be either 2 things: The FIRST is if you have not UNLOCKED the scanner lock switch. The scanner lock switch is a switch that keeps the scanner assembly frozen in place so that when you move your scanner from room to room or apartment to house, the scanner wont freely move around the unit causing it to be dammaged.
To unlock the Scanner lock switch just lift your document cover and look for the swtch on the LEFT hand side of the scanner's glass bed.
SECOND: IF the scanner lock swtich is set at UNLOCK, then your scanner assembly is broken and needs to be replaced. You must then send it to Cannon or any Mulitfunction printer repair place.
I hope this helps you :)
Mar 15, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Does the Visioneer OneTouch 7100 work with Windows 7? Where can I find a driver?
I scanned by cannon scanner (canoscan D646u ex).Suddently the error message appeared that Release the lock switch, detach the usb cable and reconnect.close the scanner driver. What can I do ?
Jan 11, 2010 | Visioneer OneTouch 7100 Flatbed Scanner
Error message says: Scanner is locked, Computer cannot communicate with scanner.
Have you checked the obvious? The scanner lock switch is located on the bottom of the scanner back right corner. --Ted
Jun 29, 2009 | Canon CanoScan 4200F Flatbed Scanner
Error 5020 scanner lock switch will not turn off.I am using printer pixma mp810
Does anyone know how to fix error 5020 release the scanner lock switch and turn the power off & on.The Cannon MP810 Printer. Please Help!Thanks
Dec 07, 2008 | Office Equipment & Supplies
Cannon mp830
hi,
its next to the scanner glass, open the top up like you would copy and its there to the left
hope this helps
Oct 22, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Cannon capture perfect 3.0
Check the location where you are directing the scanner/computer to store the scanned image. If it is full, obviously it cant store. Change the location where there is space.
S. Mohan
Oct 14, 2008 | Canon DR-9080C Path-Through Scanner
Canon PIXMA MP830 All-In-One InkJet Printer Logo
98 people viewed this question
old marine
old marine
