Question about JVC KS-AX4550 Car Audio Amplifier
When I turn the volume up even a little bit, the protect light comes on and stays on
    Scholar:
  • 113 Answers
Hiya,
Try disconnecting the speaker cables, then turn it up and see if it protects. If not, then connect one speaker at a time (on very low volume otherwise could pop the amp) and see if you can identify a faulty speaker/channel. Then try a known working speaker on the amp channel that is giving problems (to eliminate a fault with the amp). If the known working speaker also trips the amp, then it is that channel faulty. Hopefully you get away with a bad speaker wire though!!
Best of luck
Posted on Jul 16, 2009
800a4 stays in protect mode
Generally thats a sign of a shorted output device, either a bipolar transistor or mosfet. Also ground faults can trigger a protect light.
Feb 03, 2013 | Rockford Fosgate Punch 800a4 Car Audio...
Hi im wondering what the cause of overheating in CYRUS III Amp!! Anybody had the same issue, after using a high volume for 30 minutes or so, then the protection relay operates!! Best Regards, Mac
Protection mode is there to prevent your receiver from overheating to the point of failure. Try this. Make sure it is ventilated real well. Put it by itself. Don't stack anything on top of it. Even if it has a fan I us a little fan behind my receiver to circulate that warm air off of it. This works real well. Make sure your receiver is setting on a nice hard surface too. Not carpet or anything shaggy like that. Receivers and amplifiers will go into protect if they are rode real hard. Keeping it as cool as you can will minimize this. You can also turn the bass and or gain down on it a bit every now and again to help it cool a little bit. That receiver has final transistors in it that get war as power increases along with the time it is increased. Keep it cool and your it will stay out of protection mode.
Mar 22, 2011 | Yamaha HTR-5790 Receiver
Wont stay powered up cuts out even when turning up just a little bit
You might need a 1.2F, 13.8 V Capacitor to make your power stable and eliminate amp from going to protection mode or from turning off.
Jul 15, 2010 | Kicker KX800.2 Car Audio Amplifier
I have a Teac a-R600 integrated amp. The muting light strarts to flash after about an hour playing and mutes the sound until unit is switched off and re started. Any ideas . Thanks Ian
YOU ARE GOING TOO FAR IN VOLUME CONTROL AND YOUR AMPLIFIER TRY TO PROTECT ITSELF BY MUTING-MAKE YOUR VOLUME LITTLE BIT DOWN.IF THE PROBLEM REPEATED WITH LOWER VOLUME SETTING YOU WILL HAVE INTERNAL PROBLEM.ANYWAY CHECK YOUR CABLES FOR GOOD CONDITION.
Dec 19, 2009 | Audio Players & Recorders
Protection Light Comes on
your amp isnt getting enough power to it you may need to install a compacitor unit
Mar 23, 2009 | Sony NTX-2136 DHD 2Channel Car Amplifier...
Sounds like you have an ohm problem, Tryy hooking the positive from one speaker to the negative on the other speaker. Then hook the negative from the first speaker to the negative on your amp and the positive from the second to the positive on the amp this will drop your ohm load and the amp should stop going into protection.
Mar 08, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Works, but goes into protect when you turn up/down volume
If its new call Sony and get service????????????
Aug 28, 2008 | Sony STR-DE445 Receiver
STR-DE598
Well usually the best thing to do is unplug the unit from any power and leave it for about 2 hours to reset. that is a common problem when the unit has been played at a high volume or the speaker connection are not tight
Jan 04, 2008 | Sony STR-DE598 Receiver
Rockford Fosgate P3002 Amp
what are the color of the lights that stay on.red= protect/ green=on.if the amp has little sound it probably still working,check deck output volume(rca)
Aug 22, 2007 | Sony Xplod XM-554ZR Car Audio Amplifier
JVC KS-AX4550 Car Audio Amplifier Logo
99 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
