Temitope, Hard reset. Open computer, remove battery,hold power button down (((1 minute))), reinsert battery, reassemble laptop, push/hold power button a couple seconds.
2nd fix, try to boot laptop without hdd.(hard drive). Remove the hdd, then turn on the laptop.. then it can get into the bios.. reset the bios to the default setting, turn off the laptop, and then turn it on again with hdd reinstalled. This seems to be what works in the forums with this issue found in Asus laptops. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info." Asus Laptop unable to boot black screen no bios How to Fix Laptop that Won Turn On Asus X551M Laptop Won Turn on Fix How to Hard Reset Laptop Asus laptop not booting
Ruby, try pressing and holding on button or you will have to reset.
the green light blinking is normal if set has been unplugged--when set is plugged back it should blink for about 70 seconds and then go out--then you can try to turn it on---it is the DM unit inside the set booting up.
If the light just blinks and never stops you have likely bad caps in the DM unit---there are kits available for that.
The other possible reason is that so called reset switch may be bad--fairly easy way to find that out and it is more common than you would think, let me know if you have questions.
If you have steering wheel controls you can reset it by getting to the oil life indicator (mine is on the left side lower button menu when wheel is facing forward). Then press the arrow button for a few seconds to reset it. If you don't have steering wheel controls you can reset it by turning key to on position but don't start vehicle. Press gas pedal all the way to the floor three times (some say 6 times). Turn key off. Oil life should be reset went you start engine next time. I hope this works for you.
A Blinking Power light on a wrt-54g usually indicates that the firmware is corrupt. You can try to wipe the firmware by following the steps below:
unplug the router using a paper clip or pin, press the reset button plug the router back in while the reset button is still pressed down and hold it for 30 seconds. once you let go of the reset button the router should go through a reset. if it still blinks try the process again.
try doing a system reset press the call control button and the volume mute button at the same time for 5 seconds. when the talk indicator light blinks release both buttons. press the call control button again and the talk indicator light will blink again briefly headset is back to normal then unplug the charger from the charging jack for 5 seconds and plug back in headset is reset. if that doesnt work then replace the battery in headset.
First: Soft Reset 1. Open front cover. 2. Hold down button located under LED's until all LED's
are lit. 3. Release button and make sure drum LED is off, then 4. Close cover
Second: Factory Reset 1. Turn the printer off. 2. Hold in the circular button on the front panel of the printer. 3. Turn the printer back on. 4. When the DRUM light is lit by itself let go of the button. 5. Hold in the circular button on the front panel again. 6. Once the Alarm light comes on, let go of the button. This will perform a factory reset on the printer.
I hope that's everything you want. Please accept this answer if this will help you. Thank you for using Fixya.
I have an FDB1502RGB0 model but had the same problem. I reset the circuit breaker and its working fine now. I'm not sure what caused the problem but it seems to be fine now.
