Question about Pioneer GPS AVIC-X1 car radio
Error code 11 - pioneer avic 1r
It keeps showing error code 11!!!!!! help!
  • 626 Answers
Re: error code 11 - pioneer avic 1r
From Pioneer;
"Error code 11 is more specific, however, indicating that the player’s read laser cannot focus properly, most likely due to a fault with the disc."
Try a different CD, or you may have to have the laser cleaned.
Best of Luck.
Posted on Nov 17, 2007
My pioneer car audio shows error -11 when ever i play audio cd in it
what it means and how it can be corrected
Posted on Jan 13, 2009
0 characters
3 Points
Avic 5000nex Bluetooth error-02
Jason, links to manual below.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Pioneer AVIC 5000NEX Owner Manual
Pioneer AVIC 5000NEX Manuals
Feb 27, 2016 | Pioneer Car Audio Receivers
Error code 11- help-
Error 11 is a disc read error.
1. The disc is not clean or inserted upside down
2. If not the lens is dirty
3. Mechanical error fault. Issue with the mechanics that loads the cd into the spindle motor.
Hope this helps
Positive Feedback ALWAYS Appreciated :)
Mar 06, 2011 | Pioneer DEH-1300 CD Player
Im using pioneer stereo and when ever i insert any CD,i shows ERROR 11.Pls help me to erect it soon
Try using a CD-AUTO Automobile Lens Cleaner kit. Keep in mind you pay for what you get. Try using a name brand cleaning kit.
Hope this helps, don't forget to vote.
Nov 16, 2010 | Car Audio Receivers
Need wireing diegram
Here's the Installation Manual.
181 Pages in 5 Languages....
and/or here's the page where all of the AVIC-X1 Manuals can be found, including the above installation manual...
It appears that the speaker wiring diagram, by colors at least, shows up on Page 9
But there's a lot of wiring to that thing and this manual has lots of pages showing all sorts of wiring.
I hope that works out for you.
Feb 07, 2010 | Pioneer GPS AVIC-X1 car radio
I have a pioneer avicx1r and when i try to eject a disc it keeps on coming up with mechanism error
The problem is the disc. It is most likely warped. I had the same issue and I actually removed the unit from the dash still connected, tapped the top and pushed the eject button and out came the disc. I played a little longer and reinserted the disc and it showed the error again, tapped it and ejected it then tried another disc and no problem at all. I tried several and they all worked and every so often tried the original one and it showed error each time. It seems as though the fact it was warped it was catching the unit or a sensor was seeing it as a problem and not allowing it to eject. Hope this helps
Sep 20, 2009 | Pioneer AVIC-X1R CD Player
Pairing with a nokia n73
how to do "master reset"for pioneer?
Jun 08, 2008 | Pioneer GPS AVIC-X1 car radio
Pioneer automotive stereo cd player error 11
I have the same problem now too. It shows up error 11, 12 or 17. I tried using a cleaning CD but did not work. I think the lens needs to be replaced.
Apr 05, 2008 | Car Audio Receivers
Pioneer KEH-P6600 diplays "error-11"
use your user guide to read the problem related to error 11 .. most probably your wire connecting your changer witht he head uint is either cut or not functionall ... hope that answers the question
Jun 25, 2007 | Pioneer KEH-P6600 Cassette Player
Pioneer GPS AVIC-X1 car radio Logo
2,413 people viewed this question
Top Pioneer Car Audio Receivers Experts
xxxxxx xxx
Are you a Pioneer Car Audio Receiver Expert? Answer questions, earn points and help others
