Question about HP LaserJet P3005n Printer
The printer doesn't respond - HP LaserJet P3005n Printer
  • jk_10_79 May 11, 2010
    What have you done already to try to fix it? Turning the power off or even unplugging it completely to reset it can clear up a lot of problems if the problems just started. Are there any error lights flashing?
  • Damien Gole
    Damien Gole May 11, 2010
    Hello can the question be longer or with more details?
    Problem Solver:
  • 17 Answers
Also make sure that the JetDirect card is recognized by the printer as well. These have been known to fail for various reasons. Using the front panel you should be able to print out a configuration page that will include the settings for the JetDirect card...if you don't see this information turn the printer off, reseat the card, power the printer back on, and then try again after about 5-10 minutes. If still no luck, try a different network card to see if the issue is with the particular card that is installed in the printer.
Posted on Jul 27, 2009
  • 25 Answers
Make sure the IP adress for the printer is the same you have in your computer for that printer
Posted on Jul 16, 2009
Printer not responding
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Mar 27, 2012 | Lexmark X3650 Printer
HP 4500...when trying to scan, or make a copy, screen displays "Scanner Failure" and will not work. Please help.
The "Scanner Failure" message appears when the scanner unit doesn't responds to the commands from the printer's processor. This is a major hardware failure - the scanner unit is effectively dead.
Replacing the failed scanner unit with a new one would cost more than a new All-in-One so either use the printer as is (just as a simple printer) or sell it for parts and get a new one.
Sep 02, 2011 | HP OfficeJet J4580 All-In-One Laser...
Hi, i have some problems with my ML-2010R, it doesn't respond to anything from the computer. when i press ON it makes the usual noises,eating and preparing for printing , but when i try to send a file...
try to use a new USB cable maybe the problem is on the cable this transfers the data from your PC to the Printer this is a common issue for printers. Or update your printer driver.
Sep 02, 2011 | Samsung ML 2010 Laser Printer
Print document system responds document is printing system responds that document is printed but no document is printed. Used troubleshooting for alignment and that works with printer?
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
1. Disconnect the printer from your computer.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print/scan again.
Aug 23, 2011 | Lexmark Z816 InkJet Printer
My touch screen doesn't respond to touch and I am unable to make copies.
Does it respond to any touches or is it greyed out? This problem can be caused by either a bad touch pad or a defective scanner. Try accessing other options on the front such as the administrative menu. If those work, then the scanner might be bad or locked? Lift the automatic document feeder lid and check the lock on the left hand side to make sure the scanner is not locked. Restart the machine as well, could be an intermittent problem or static discharge.
Jun 06, 2011 | HP LaserJet M3035 MFP Printer
MP 160 flashing error E then 3. doesn;t respond to anything I try to reset it
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
mbhd13
Jun 19, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Hp 5610 not responding
try turning it off and back on. if that doesn''t work then try to unplug it for a couple minuets and plug it back in
Jan 04, 2009 | HP Officejet 5610 All-In-One InkJet...
Epson FX-890 All lights flashing
when switch printer on after replacing cartrige all the light on printer are flashing how can I reset it
Jun 27, 2008 | Epson FX 890 Matrix Printer
HP Laserjet 1320 Printer doesn't respond
Manual Feed or Continuable
Error
This state can be reached in
the following circumstances:
● Manual feed
● Out of paper for the
specified tray
● General continuable error
● Memory configuration error
● Personality/Job related
error
Solution
To recover from the error and
print whatever data is possible,
press the GO button.
If the recovery is successful,
the printer goes to the
Processing Data state and
completes the job.
If the recovery is unsuccessful,
the printer returns to the
Continuable Error state.
Feb 05, 2008 | HP LaserJet 1320 Printer
Printer won't respond
TRY UNINSTALLING THE THE DRIVER AND REINSTALLING IT. YOU COULD ALSO TRY GOI NG ON THE PRINTERS WEB SITE AND LET THEM SEARCH FOR THE ATTACHED PRINTER AND USE THE DRIVER THAT THEY HAVE.CHECK FOR IRQ CONFLICTS CHECK YOUR CABLES AND MAKE SURE THEY ARE PROPERLY SEATED, TRY HOOKING THE PRINTER UP TO ANOTHER COMPUTER AND INSTAL THE DEVICE AND SE IF IT WORKS
Oct 04, 2007 | HP LaserJet 1320 Printer
HP LaserJet P3005n Printer Logo
189 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
