Question about E-Machines eMachines T3830 PC Desktop
Switch Wiring E machine Tower..Need the black and white wire assembly that goes to the on off switch. Where can I get one.
  • 112 Answers
You can look here if you have the model number http://parts.emachines.com/
Posted on Jul 15, 2009
Wiring schematics
There are no wiring diagrams for this manufacturer.
General wiring practices are that the Hot wire(black) goes to the thermostats, and the neutral wire( White ) is attached to the heat element for the return.
Switches are on the Black wires to break the circuit before power reaches the item it is controlling. A white wire on a switch is for the return from the light in the switch.
Nov 18, 2013 | Nostalgia Electrics KPM-508 Popcorn Maker
Tip
Regular switching and switch loops
A switch loop is a technique that is often used in home wiring to cut back on wire used and to make the circuit less complicated. In a normal switching circuit power comes into the switch box with the white wires tied together and black wires on the switch and then continues to the lighting box where black is connected to black and white is connected to white. With a switch loop the power starts at the lighting box in the black wire that does not go to the switch. That black wire is connected to the white wire that goes out to the switch (note the white wire must be taped with a small piece of electrical tape to show that it is now a powered wire). At the switch both black and white wires must be connected to the switch (the white wire here must also be taped). So now back at the light box you should have two wires. A white wire from your incoming power cable and a black wire from your switch cable. Now all you need to do is tie black to the black of your light and white to the white of your light (note: if you have terminals, white goes to the silver terminal and black goes to the brass terminal.) The wiring is done in this manner because in electrical work black and white make a light, and the the colors are never mixed up because it allows the next person to diagnose any problems much easier.
on May 19, 2010 | Electrical Supplies
I have a clarke bench grinder model 1002. I have a light that I would like to attach into the wiring though the grinder wiring in it's base. The light has two wires, and the grinder has a ground that...
Attach the white wire on your lamp to the white wire on the grinder.
Attache the black wire on your lamp to the black wire on the motor side of the switch.
This will give the lamp power any time the grinder is turned on.
You can put a switch inline of the black wire to the lampp and it will allow you to turn it off when not needed
OR
You can attach the white wires together and the black ones before the switch.
If you choose this way you will need a switch as the lamp will be power all the time.
May 21, 2011 | Vacuums
I need help wiring my fan. I can't get the fan to work, but I do have the light working. From the ceiling I have a white, black, red and ground wire. How should these wires connect to the White, Black,...
White is your neutral so white goes to white. Blue on the fan is for the light kit you need to wire that to the wire from your switch so it works the lights. Black is the hot wire that is always hot not switched so tie that to the wire that is not on your switch. Green is ground so green to green. white to white / green to green/ black to black/ red to blue/
Nov 06, 2010 | Hampton Bay 24750 Huntington III Ceiling...
Moved into a new house with existing fan. Fan works but lights do not. There's no remote and fan turns on with wall switch but lights don't come on.
OK .. check to see if there is a second switch for the lights. .. Then I would have to look at the switch wiring and the wiring for the fan .. if there is only a black and white wire at the fan hook up .. then the white goes to the fan white and the black goes to the two black wires from the fan. Or black and blue wires.
If there is a red wire at the fan , then the black goes to the black, and the red goes to the other fan wire for the lights.
At the switch .. if there is one switch then you should be OK .. IF there are two switches , the red wire should be on one and the black wire on another .
Plaese Vote !!
Mar 10, 2010 | Air Cool AC436-GB Fan
Switch wiring
If you will get the model and date code from the bottom of the machine and contact customer service, we can further assist you.
Jan 22, 2010 | Bunn GR10 Coffee Maker
Wiring from plug to switch to three lights
Run a cable from the plug to the switch box with two wires and a ground. Connect the black wire to the black side of the outlet and the white wire to the white side of the outlet. Ground to ground. In the switch box connect the black wire to one side of the switch and the white wire goes directly to the white wire of the cable going to the first light. The black wire connects to the other side of the switch.(either side). Then the cable from the switch goes from light to light connecting one light to the next, maintaining black to black, white to white connections.
Dec 13, 2009 | Coffee Makers & Espresso Machines
Need help with the wiring on the reddy heater 110 btu
CIRCUIT CARD-
-Photocell blue wired go to two terminals marked BLUE PHOTOCELL (any order)
-Motor red wire plugs onto terminal marked MTR MAIN, motor white wire plugs into terminal marked WHITE MOTOR.
-potentiometer (thing with knob) two white wires plug into terminals marked TEMP SEL
-Black wire from switch to terminal marked L1 BLACK
-White wire from power cord goes to terminal marked N White
-Ignitor (used to be yellow wires) goto terminals marked IGNITOR and IGNITOR RET (any order)
OTHER-
-White wire from power cord goes to switch terminal marked 3A , other pigtail of the white wire goes to board as described above.
-Black wire from power cord goes to swtich terminal marked 4B
Nov 14, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
I replaced the fwd / rev switch on my Club Car 1985
I recently replaced a F/R switch and just happened to write down which wires went where so maybe I can help. The front switch ( closest to front of cart) green/white wire to top contact, white/black to bottom.
Middle switch red/white to top, orange to bottom.
Rear switch green to top, black to middle and white to bottom.
Jul 27, 2009 | 3d Rose Londons Times Funny Cow Cartoons -...
E-Machines eMachines T3830 PC Desktop Logo
89 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
