Question about Pentair 250k Minimax Ch Ng Mv Heater
I have a minimax 250 that will only ignite if cranked to max heat. This can get very annoying when you don't want this much heat. Burners are clean. Pump pressure is normal(18psi). Suggestions please?
    Scholar:
  • 91 Answers
Sounds like a defective thermostat or temerature sensor.
Posted on Aug 22, 2009
Triton Purex minimax 400
dan i belive you have a faulty thermastat switch
Apr 01, 2012 | Pentair MiniMax CH Natural Gas Pool...
I have a Pentair Minimax CH 250M pool heater. When I opened my pool, the heater started up fine and heated the pool initially. However, since the initial heater it has not come back on, and the pool is...
Do you have 24V at the brown wire of the gas valve? If you do then it is probably a bad gas valve.
If you don't have 24V on the brown wire it is probably the ignitor.
Jun 04, 2011 | Pentair Minimax Ch 250,000 Btu Natural Gas...
Winterize minimax heater
Lost the manual to my heater. Would like to know how to
winterize the heater. mini max ch 250 M
bl.wilson @ hotmail.com .. thank you, hope you can help me.
Oct 03, 2009 | Pentair Minimax NT Heater
Jet size differnce from natural gas to bottled
You will need more then new orifices to convert from natural gas to propane. The gas valve will also need to be replaced. Not a good idea converting heater.
Jul 12, 2009 | Pentair Minimax Ch 250,000 Btu Natural Gas...
Pentair Minimax 250M
how many times it blink will tell you what is wrong check at the codes. unplug thermostat check fo homs 10 k around is fine at 80 degrees pressure switch require a by pass but DO NOT RUN THE HEATER WITH A BY PASS ANY CONTROL!!!!
Jun 17, 2009 | Pentair 250k Minimax Ch Ng Mv Heater
NT mini max not heating at all - won't fire
wow t pool service is just guessing i guess . weel let see do u have a pilot if yes do u hear a click if yes clean t burners if not check 24v at t brown wir e for t gas valve if v replace gas valve if not replace ignition control . do u have any code on t back or t front this help a little.
Jun 14, 2009 | Pentair Minimax NT Heater
I have a Mini Max 100 pool heater. The pilot
check pressure switch for proper adjustment and make sure filter is clean so system pressure is normal
Jun 07, 2009 | Pentair MiniMax 100 Aboveground 100,000...
Pentair Minimax 250 does not light everytime
that one think thats bad with pentair heaters they say when you turn one on stand to the right cause the door can blow off because the way there burner are set up u need to take out the burner trays and clen them this problem does not happen with raypak heaters
Apr 18, 2009 | Pentair 250k Minimax Ch Ng Mv Heater
I have a Pentair MiniMax NT 250,000 btu pool heater that fails to
Two reasons.
1. There is air in the gas line. Power down the heater and allow it to try igniting until lockout. If it locks out, repeat the process. Most lines will clear within 4-5 attempts to ignite.
2. A plugged burner orifice. Run a small pipe cleaner in the brass fittings on the burner tray. They may have small webs in them restricting gas flow.
If the unit is a Standard (STD on the plate inside) it has a flame sensor that may also be bad. That sensor is on the end of the single wire that is cloase to the ignitor wire near the burners. Also check for a losse ground wire on the heater.
Nov 24, 2008 | Pool & Spa
Pentair 250k Minimax Ch Ng Mv Heater Logo
184 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
