Question about HP Pavilion F1903 19" Flat Panel LCD Monitor
Black screen and yellow flashing power button on hp f1903 monitor
Black monitor screen and yellow flashing power button on hp f1903 monitor. Pulled inverter board and inspected the soldering. resoldered one capacitor that had one bad looking solder joint. box shaped capacitor 33mfd.
All components look fine and no obvious burnouts.
Burned/smoky odor from board but more noticeable at transformers on board.
Reasselmbled monitor but still have flashing yellow light at power button. Screen does not light.
  • Buddy Mcsparrin May 11, 2010
    Hello, Can you send me a picture of your inverter and powers board? You issue sounds like bad capacitors in the power supply. You may have some capacitors that have died but don't have visible damage. The capxon caps are known to die with no visible sign. If you can send me a picture of your power board as close and clear as possible I may be able to direct you replacing caps to get you going. Buddy Corporate Computer www.ccl-la.com tech@ccl-la.com
3 Suggested Answers
Matampong
  • 153 Answers
SOURCE: Screen flickers, turns on and off
Normally this kind of problem needs only the dry soder, cause theres some loose components some where on the main board. Try to resolder any visiual suspicious terminals of components.Try to see carefully if any of the capacitor has any buldgy appearence on top of them. If there is try replacing them.cheers
Posted on Nov 23, 2008
  • 1684 Answers
SOURCE: Hewlett-Packard vs17 half fixed, what to do next?
I have also seen this type of problem. Have you checked the large caps on the inverter board, no just the power supply board? Many LCD monitors have 2 caps on the inverter and I have had to replace them from time to time. The next thing to check would be the driver transistors. I hope this helps.
Buddy
Posted on Jun 23, 2009
When i turn on the monitor it flashes on once for a few seconds t
faith1114, Try this first! See if any thing seems a little similar to your f1903 type of complaint. Problem been around a long time!!! Go do some reading here: http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution. After doing some reading there, you will be in a better position to make decision to DIY repair, contract out the repair work, trade in for new , DIY repair + buy a new monitor keeping refurbished f1903 as emergency spare. Here is a little clue. If unit can display Win-desktop for 2 seconds and then the "black screen of death happens" you certainly need to do some reading and viewing of DIY videos at YOUTUBE so you can understand the big problem all major CCFL back-lit lcd monitor manufacturers are facing. do some additional reading here at fixya in the profiles of ccfl backlit lcd monitor technicians "budmrtn" "buddymc" , "12fixlouie" (late) "louie12fix" (old) Follow links you find there. Once you understand basic problem you will never walk past the new curlie-Q, screw-in energy-efficient CFL light bulbs at the local hardware or big box homecenter ever again with out having a slight grin on your face!! Bye for now. 12fixlouie
Jun 02, 2010 | HP Pavilion F1903 19" Flat Panel LCD...
What causes a dark screen and a flashing power button for a HP Pavilion F1903 19" flat screen monitor?
Probably find the screen inverter has failed and needs replacing. Can be a fiddly job as you have to dismantle the monitor so take it to your repair shop if you're not familiar with this type of repair.
Apr 28, 2010 | HP Pavilion F1903 19" Flat Panel LCD...
Moniter went black, power button flashes yellow
it sounds like a capacitor blew from the inverter board.. if u can open it it should be obvious which one the messed up..
May 04, 2009 | HP Pavilion F1903 19" Flat Panel LCD...
MY HP PAvilion F1903 19 " gone black blank
Problem is generally dry solder joints around the inverter transformer on the inverter PCB.
Feb 16, 2008 | HP Pavilion F1703 17" LCD Monitor
"Desact.monitor"
my monitor says desact monitor and I dont know what it means.
Feb 12, 2008 | HP Pavilion F1903 19" Flat Panel LCD...
HP F1903 FLAT PANEL POWER PROBLEMS
internal power supply failure in the monitor generally repair is more costly then replacement,that can be verified if you can find a tv repair shop that provides free estimates.
Dec 26, 2007 | HP Pavilion F1903 19" Flat Panel LCD...
Flashing Power Light
When this occurs an inverter, backlight, vga connectiosn, etc could be the cause, my suggestion is connect it to some other device, if you get the same result then your monitor is bad!
Nov 26, 2007 | HP Pavilion F1903 19" Flat Panel LCD...
HP Pavilion F1903 19" Flat Panel LCD Monitor Logo
629 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
