Question about Ricoh Aficio 450 Copier
Reset code what is the reset code for a ricoh 1075 when I change the web cleaning roller?
  • 162 Answers
Press total clear (yellow key) enter 107 and press an hold clear stop key (orange key) more than 3 sec.
enter SP1902 001 to 0 to release SC550.
Posted on Nov 14, 2009
  • hafezfani774 Jun 09, 2011
    hello mr. GURU
    If your answer is about problem aficio mp 7500, we need a fuller answer. please answer to our
    hafezfani@yahoo.com
  • Ricoh Expert
  • 398 Answers
Sp 1-902-001 set to 0. Let me know if this helps. -Carl
Posted on Jul 15, 2009
We have a Ricoh aficio 1075 with sc 541 and we already change the thermistor and reset the sc 541 but its coming back.... what should i need to do so the code can go away... let me know please>>>...
Hi.
Dear i advise you to-replace only Drum unit.
cuz i facing this problem so many time if isn't possible for you to change complete drum unit then change only drum. but if you want to check this problem just once time replace complete drum unit with drum don't fix previous drum.
and please don't wast ur time on heating unit :)
Best Regard's
Syed Babar Ali
Copier International Trading
Cell: +971556272142
Jun 21, 2011 | Ricoh Aficio 450 Copier
All service codes for ricoh aficio 1075 are required urgently.
RICOH ERROR CODES
Error Code Description
SC184 CIS Transmission Error
SC191 Bar Code Scanning Error SC192 Automated SBU Adjustment Error/Bar
Code Number is Different SC193 Image Transfer Error/IDU Error
SC194 SBU White Level Detection Error SC195 DF Gate Assert Error/Serial Number Error
Error SC196 DF Gate Negate Error
Code Description
SC197 DF Gate Error SC101 Exposure Lamp Error
SC198 Memory Address Error SC107 Scanner Lamp Regulator Malfunction
SC199 DF Scanning Finish Error SC120 Scanner Home Position Error 1
SC201: Polygon Motor Error HP Sensor Abnormal-Stays Off
SC220 Laser Synchronization Detection Error SC121 Scanner Home Position Error 2
SC221 Scan Length Detection Error HP Sensor Abnormal-Stays On
SC230 BCU Received no Feedback from LD SC122 Scanner Home Position Error 3
F- Gate Error SC123 Scanner Home position Error 4
SC231 Laser Beam Feedback Signal Error SC124 Scanner Motor Encoder Signal Error
F- Gate Timeout SC125 Scanner Motor Speed Error 1
SC240 LD Power Supply Excessive SC126 Scanner Motor Speed Error 2
SC260 HP Sensor Error SC127 Scanner Motor Encoder Rotating Direction
SC261 HP Sensor Not Turning Off Error
SC285 Line Position Error SC128 Scanner Motor Start Error
SC300 Charge Corona Output Error 1 SC129 Scanner Motor Speed Control Error
SC301 Charge Corona Output Error 2 SC130 SBU defective Error/Scanner Start
Charge Current Leak Abnormal
SC302 Charge Corona Output Error 3 SC131 F-Gate Asserted During Shading
Grid Voltage Error Charge Roller Current Leak
SC142: White level detection error. SC303 Charge Corona Output Error 4
SC143 SBU Auto Adjust Error Grid Leak
SC144 SBU Connection Error Charge Cleaner Motor Error SC150 Scanner ROM Mismatch SC304 Charge Roller Current Correction Error SC170 Scanner DA1 Abnormal/Video Processing SC305 Charge Corona Wire Cleaner Error 1
Error 1 SC306 Charge Corona Wire Cleaner Error 2
SC171 Scanner DA2 Abnormal/Video Processing Charge Roller Home Position Error Error 2
SC310 Potential Sensor Calibration Error 1 SC172 Scanner DA3 Abnormal/Video Processing
SC311 Potential Sensor Calibration Error 2 Error 3
SC312 Potential Sensor Calibration Error 3 SC173 Scanner Lamp Regulator Adjustment Error
SC314 Potential Sensor Calibration Error 4 SC174 Scanner DA2 Abnormal
SC315 Potential Sensor Calibration Error 5 SC181 CIS Lamp Abnormal
SC316 Potential Sensor Calibration Error 6 SC183 CIS Auto Adjust Error
SC317 Potential Sensor Calibration Error 7
www.smilecopy.com
Aug 11, 2010 | Ricoh Aficio 450 Copier
Sc990
sc 990 relates to the nv ram chip on the main board also check the values of the lazer unit are correct and not changed
Jun 16, 2010 | Ricoh Aficio 450 Copier
Error code, SC 547 on a Ricoh Aficio 1075
have you tried sc reset through the service mode and then turn off .. you can get to this by pressing yellow clear button then 107 then hold down the cancel stop button..wait for the screen to change then go to mode 5 and you need to arrow down to sp 5 810 sc reset execute turn off the copier and try turning on to see if it clears.. if not the ac board maybe defective caused by a power surge or static down the line..
Aug 05, 2009 | Office Equipment & Supplies
Error code 000005
Web roller reach its end change web roller and
reset cleaning belt /web roller counter
to reset:
press,
* (with head)
2 and 8 (simultaneously/together)
* (with head)
on lcd press COPIER>Counter>Misc.Fixweb press (C)lear button Fix web counter must be 0000000
Switch power off and on the machine
Jul 28, 2009 | Canon imageRUNNER 5000 Copier
RiCoh 1075 MisFeeding...
The problem you are having is that developer has fallen down into that area good luck once this has happened the box must be taken apart and blown out...  good luck
Apr 22, 2009 | Ricoh Aficio 450 Copier
RICOH IS200E error 1887.
Most of the scanner shows an error and sometimes it wont work because the feed roller counter reaches it life. You might have to replaced the rollers otherwise you can reset the counter by going the the web browser of the machine and look for feed roller counter reset. Then it will start again. Hope this will help.
Mar 28, 2009 | Ricoh Office Equipment & Supplies
Tengo una Ricoh 1075 y me sale el mensaje de SC 541
press "clear" 1 - 0 - 7 and then Stop then turn off then back on
Jan 23, 2009 | Ricoh Aficio 450 Copier
Ricoh photocopier 1075 code sc541
Ok, its a firmware bug, but you should be able to reset it. Press clear modes, 1, 0, 7, and press and hold clear/stop. Press 1 for copy sp. Scroll down to 7, (data log) press 7. scroll to 7807, and reset it. exit all the way out, and recycle the power.
Mar 18, 2008 | Ricoh Aficio 1013F Copier
500's usually means overheating problem
contact service support from your local authorized dealer
Jan 10, 2008 | Ricoh Aficio 450 Copier
Ricoh Aficio 450 Copier Logo
1,099 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
