Question about Coleman Heating & Cooling
I would like to have my central air unit removed and disposed of properly. How do I go about doing that?
  • rs59 Jul 17, 2009
    Thanks for the fast response! I did just that; google local HVAC businesses, called and its being removed today.
    President:
  • 2,777 Answers
Hello there, you say you want to remove and dispose of a central air unit? If that is the case then you truly will need to hire a professional HVAC person to come take it away. If it is a smaller portable air conditioning unit then you can dispose of it yourself.
Air conditioners regardless of type, all contain some form of cooling refrigerant. As there are federal or state/province regulations as to disposal of these types of appliances, before you dispose of it in a landfill, recycle or trash bin, call your local sanitation department to find out if it needs to be prepared before it can be discarded. It may just need to be taken to a certain disposal area, or it may require a qualified technician to remove the coolant, similar to what is done with disposal of refrigerators and freezers.
If you are buying a replacement air conditioner, check with the retailer to see if they'll take and dispose of your old model for you. Some merchants may provide this service as part of the sale.
Posted on Jul 15, 2009
When removing a ceiling cassette type air conditioner do i need to remove the gas before removing the ceiling unit
If your removing any type of Ac system, you will want to remove the gas. Some units have a pump down feature as in central units, but i have not seen to many on mini's as most of them use variable speed technology, thus no valves to close properly, just depends on the type of unit you have with what will need to be done..
Mar 11, 2015 | Heating & Cooling
Will not drain
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Dec 03, 2009 | Whirlpool Dishwashers
Water does not drain
Hi
Thanks
Rylee
Dec 03, 2009 | GE Dishwashers
My diplomat dishwasher wont drain
Hi
Thanks
Rylee
Nov 21, 2009 | Dishwashers
My dishwasher will not drain. Have not installed a new garbage disposal or new dishwasher. Just all the sudden stopped working
Hi
Thanks
Rylee
Nov 09, 2009 | GE Nautilus 24" Built-in Dishwasher
The intake/drain light is flashing. I've removed the drain cover, but dont see any blockage
Hi
Thanks
Rylee
Nov 03, 2009 | Miele Touchtronic G894 SC Built-In...
Dishwasher wouldn't empty
Hi
Thanks
Rylee
Nov 03, 2009 | Dishwashers
Dishwasher won't drain
Hi
Thanks
Rylee
Oct 22, 2009 | KitchenAid Dishwashers
Triton triclean not draining
Hi
Thanks
Rylee
Sep 26, 2009 | GE Dishwashers
Pluged drain
Hi
Thanks
Rylee
Sep 06, 2009 | GE Dishwashers
Heating & Cooling Logo
Top Coleman Heating & Cooling Experts
Bill Long
paulcarew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
