Question about Peavey Pv 2600 Power Amplifier
No output on the right side of the peavey 2600 amplifier but the right is ok
  • 4,234 Answers
Each channel is protected separately. I suspect that the outputs are fried on the right side or the output fuse has blown. This should be checked by a service shop.
Dan
Posted on Jul 18, 2009
My peavey amp pv 2600 only plays on channel A. No output on the B side
Check the "BRIDGE" switch position, "IN" for "BRIDGE", "OUT" for "STEREO", and clean ALL back switches with a cleaning spray and then run the amp again, also check the two green lights activation at front, if they activate, then amp is certainly working, let me know further.
Jan 28, 2013 | Peavey Pv 2600 Power Amplifier
One side stopped workig on my 2600 amp, so i am running thru center out put. now sound fades up and down.
Please be advice that the center output connector is only for BRIDGE mode operation, you should not use that way, try to clean all the back switches with a cleaning solution spray, clean all switches and check amp functionality again in stereo mode.
Jun 13, 2011 | Peavey Pv 2600 Power Amplifier
No output channel B from peavey pv2600
Make sure the Stereo/Bridge switch is out on the back of the amp. If bridged channel 2 will be disabled.
Dec 18, 2010 | Peavey Pv 2600 Power Amplifier
I have 2 peavey 2600 amps with 1 pv6 mixer wanting to run subs off 1 amp and sp2s off other amp but only have 1 main output on the pv6 mixer whats my solution
you can run one amp from the main out puts and the second amp from the CTRL Room out puts. The CTRL ROOM are outputs that are linked to the same bus as the master fader. This will work fine...
Best of luck
Sep 02, 2010 | Peavey Pv 2600 Power Amplifier
I have Peavey Pv 2600 Power Amplifier ,the B side did not work sound did not come
One side of the amp has failed and repair is NOT DIY. Take it in for servicing. This amp has many components in the power amp and repair is complicated. A failure can lead to 20 components being damaged. Failure to replace all damaged ones can result in immediate failure destroying the replaced ones.
Aug 28, 2010 | Peavey Pv 2600 Power Amplifier
I have 2 peavey 900 Power Amplifiers i would like to link them together was wondering what is the input wattage it can handle?? not wanting to mess anything up!
You CANNOT link the outputs of the amps. They need to drive seperate speakers.
You can tie the inputs together so they will send the same sound to their seperate speakers.
Max power for the Peavey 900 is 900 Watts RMS into a 4 ohm speaker in Bridge mode... That is enough to blow many speakers.
May 15, 2010 | Peavey Pv 2600 Power Amplifier
Power supply problem
Use the series light bulb trick when trying to first power this up. Use a 150 watt bulb in series with the 120 volt power to avoid damage and blown fuses.
Jul 02, 2009 | Peavey Pv 2600 Power Amplifier
TRANSISTOR TYPES FOR PEAVEY XR684 MIXER AMPLIFIER/ARRANGEMENT
Go to Peavey's website
http://www.peavey.com
You may find what you are looking for here if not you may have to call them.
Jun 30, 2009 | Peavey Pv 2600 Power Amplifier
Peavey Pv 2600 Power Amplifier Logo
324 people viewed this question
Top Peavey Music Experts
Ben Armstrong
Vito Vacirca Jr.
Lawrence Nentwig
Lawrence Nentwig
Level 1 Expert
Are you a Peavey Music Expert? Answer questions, earn points and help others
