Question about Whirlpool Dryers
Whirlpool gas dryer does not heat, Motor works drum to go around; timer seems to work also. Repair person said it was the controls on the motor; replaced motor but still have no heat. Cleaned out vent duct and removed flexible vent and still no heating. Checked igniter; looked ok but after nearly 20 years could it possibly be bad?
  • 1 more comment
  • famgrp Jul 15, 2009
    I plan to check the igniter with an ohm meter first. Is the Safety Thermostat the same as the Thermal Fuse (located on back of air vent duct)? If not, I do not know where it is located and how to specifically test; would need detailed instructions.
    I did not smell gas while operating the dryer in the dry mode. I let the dryer run for 5 minutes three consecutive times after I reconnected the gas line (yes the gas line valve is open) to purge the air. The igniter (2 wire glow type) did not glow.
    In another web site I learned that the gas valve coils could be weak or not functioning; don't know how to test for this as well.
  • famgrp Jul 16, 2009
    I checked the igniter with a multi tester using the ohms and it read 70 ohms (within the range of 50 to 600 ohms indicating it was ok). Then I tested the Thermal Fuse in the back; it measured 5 ohms (not sure if this is acceptable).
  • famgrp Jul 22, 2009
    I checked the 2 and 4 prong safety thermostats after removing the lead wires on the back of the gas dryer. The 2 prong gave an ohm reading. The 4 prong gave an ohm reading on the red and blue leads but I could not get an ohm reading on the other leads with purple lead wires. I replaced this 4 prong safety thermostat. Dryer still did not heat. A local appliance repair person suggested I check the coils and the flame sensor. The 2 prong coil had an ohm reading and at the 3 prong gave a reading with the 2 outside leads but not when the center was matched with either outside lead. then I removed the flame sensor (easier to work with). I got no ohm reading. The repair person suggested to connect the 2 lead wires for the flame sensor. After doing this, I started the dryer and watched the igniter. Presto, the igniter started to glow. Have part (#338906) ordered. Hope this solves the problem.
    After-thought;I may have had 2 problems and this could have caused difficulty in solving the problem.
  • 396 Answers
I do believe the repair man hosed you on the motor. Most of my experience is with electric dryers but I can try to shed some light on the subject. I would test the safety thermostat if it is open you can temporally short the leads together to see if it heats up. It is about $70.00 so you do not want to just swap it out, do not run for a long period of time if you short the leads out (Fire is Bad). Next check the Sensor on the burner unit which turns on the Electronic gas valve ($200.00 Ouch) or it could be a clog it the orifice. Do you smell Gas by the burner unit? Next is the Igniter which you should hear click. A volt meter is recommended to test the components and an Ohm Meter to test the Safety Thermostat. I wonder if your repairman even took his out of the truck.
Posted on Jul 15, 2009
  • Stephen Yanowich Jul 17, 2009
    Excellent, your process of elimination is great. Try No gas could be positive since the igniter is not glowing. Typically there is only one Safety Thermostat which will not reset. Once it blows it is bad and must be replaced. The Safety Thermostats function is to stop the heat when the unit is to hot because of inadequate ventilation from a clogged filter or vent. I usually find the Safety Thermostat on the back of the drum since it will not rotate. It should look similar to a Power Transistor shaped like a disk with two mounting holes where it is screwed to the drum and two lead wires attached to it. The Schematics in the dryer pocket will tell you if there are two Safety Thermostats. Make sure when you check the resistance of the Safety Thermostat one lead is removed to isolate it from the rest of the circuit. If it reads open (no continuity) it is bad and needs replaced. If you touch the removed lead to the other lead you have bypassed the Safety Thermostat and the dryer should get hot to temporarily test the dryer. To test the Gas Valve use the volt meter to measure the voltage going to the coil. If it has voltage gas should flow and if you do not smell it and you have no glow on the igniter my bet is you will not see any voltages. This is good because the valve will be an expensive part. So I am leaning towards the Safety Thermostat and you checked in circuit giving you a false positive. Or two Safety devices are used one on the drum and one on the vent. I do not have the schematics so I am guessing and believe the valve is good but the Igniter is not glowing which should be on at all times Igniting the gas when the valve opens and closes throughout the drying cycle.
Gas dryer dries sporadically. dial for automatic dry doesn't move
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ...Replaced outlet, cord, and moved the outlet so we don't have the same ... Whirlpool LER4634EQ0 110 v timer motor, when timer contacts TM .... David Villa 7 months ago ... 3 years and now thedryer won't heat and the timer doesn't advance, ...Missing: cu
Nov 17, 2015 | Whirlpool Dryer. Gas Dryer. 7.0 cu. ft. in...
My whirlpool dryer model ler8620pw0 does not shut off in the automatic cycle, but does in the timed cycle. what would cause this?
Dryer will not shut off:
The timer: Located in the control console of the dryer the timer consists of a small motor connected to a series of gears that rotate cams, which turn electric contacts off and on inside the timer. The timer contacts control the dryer motor as well as the heat circuit and the timer motor itself. A defective timer motor or a defect in the timer's electrical contacts can cause the timer motor to fail and the timer will need to be replaced. The contacts can be checked for continuity with a multi-meter. This test should only be made when the dryer is unplugged. Another test u can do is observe by eyesight and see does the timer advance or is it stuck on one cycle?
1. On gas and electric dryers that have an "Auto Dry" cycle, the cycling thermostat is often used to advance the timer as well regulate the drum temperature. Essentially, thermostat will alternately turn on the heat source or the timer motor when the temperature has been satisfied. To check this thermostat, you will have to check for power to the timer motor with a multi-meter, during a cycle. This is a live voltage test and caution should be used.
2. Some dryers will use a cool down thermostat to tumble the clothes without heat, at the end of the dry cycle. Power is routed through this thermostat to the drive motor to keep it running until the drum temperature has dropped to a specific temperature. If this thermostat fails it can cause the drum to turn indefinitely or until the door is opened. You can check the thermostat for continuity with a multi-meter. This test should only be made with the power removed from the dryer.
Lastly check the moister sensor for OHMS according to ur schematic as it must show a certain amount of ohms as per ur unit. When unit has been on short while
Jul 25, 2014 | Whirlpool Dryers
I have an electric whirlpool with start switch not working
OPEN THE DOOR/PUSH THE START SWITCH ON DRYER/THEN PUSH THE DOOR SWITCH/HAVE A PERSON TURN THE DRUM/IF IT STARTS TO TURN (DRUM) OR STILL HUMS AND DRUM WILL NOT TURN YOU HAVE A BAD MOTOR/REPLACE MOTOR.
FREDDY
Feb 14, 2010 | Whirlpool LGB6300 Gas Dryer
Dryer no longer heats up
It could be the heating element, a safety limit, a control problem, or an electrical problem. A heating coil is used to warm the clothes as they get tossed gently inside the drum. A blower mounted on the motor pulls air through the heating element into the drum and out the exhaust. The element gets old and briitle with use and eventually needs replacement. That is what you check first. On gas dryers vibration and age will cause the igniter to crumble and fail. If it turns out the element is fine then one of the safety's might be blown. These safety's are set to a certain temperature
for the dryer to operate safely. The drum temp control for cotton is 160f. A limit on the heater housing is 250f. If it fails another smaller limit is mounted nearby that blows at 300f. If that temp exceeds 350f a duct fuse mounted on the blower housing opens and kills most dryers. On gas dryers the duct fuse will kill the gas assembly but the dryer will still run. If all of those safetys are good the timer could be the problem. The timer has a terminal on it that runs down to the heating element. If you suspect it is bad you can check it with a meter. That leg of the timer should have continuity with other terminals on the timer at different spots on the timer. Turning the timer and checking for continuity will give a clue. If you cannot get continuity with any other terminal on the timer at any position on the dial then you have a burned contact in the timer. If that turns out to be good, you would need to inspect the electrical outlet for proper power to the machine. On American models the motor runs on 120 volts but the heating element must have 240 volts. If you have more questions just post a comment. Good luck on repairing your machine. I have some repair photos: HERE
Jan 18, 2010 | Whirlpool LER5636P Electric Dryer
Heating element broken? It won't dry all the time.whirlpool estate teds840pq0
Go to repair clinic.com. Typed in your model number and found the heating element. Repair Clinic part number is 2438. Third item down in their parts list.
Jan 17, 2010 | Estate TEDS840JQ Electric Dryer
Dryer won't come on
There are a couple of things that may have happened here.  If the lights and control panels, and the timer are all working, but the drum isn't turning, you might have broken the drum belt.  This is a fairly easy repair (if you have experience with tools and taking things apart).  Open the dryer up (assuming it's not under any kind of warranty), and find the *remnants* of the belt.  Take the numbers off of it, order a new one, and install it - it just goes around the motor pulley and the drum.  Put it back together, and it should be fixed.
Now, if there is also no heat, then there is a possibility you have burned a fuse.  There should be a couple of fuses behind the control panel - I would check those.
Lastly (and probably the worst case scenario) the drive motor may have burned out.  In this case, you might have to get a tech out there to take a look at it and replace.
May 26, 2009 | Dryers
Heat cycle stops/goes off
  1. Changing from 3 to 4 wire hookup on a electric dryer
  2. Door switch replacement help for a common door switch
  3. Dryer basics - Venting problems and power supply
  4. Dryer basics - timers and how they work
  5. Dryer basics - power cord problems
  6. Dryer basics - dead dryer
  7. Dryer *general* repair flow chart....Click here
  8. Gas dryer smell
  9. How do dryer thermostats work?
  10. How long can my dryer vent be in length?
  11. How to change a common rear drum seal
  12. How the belt is suppose to look at the motor and idler pulley
  13. Help on replacing dryer motor and some wiring tips for the 279827 motor
  14. Help on replacing dryer motor and some wiring tips for the 279787 motor new25.gif
  15. Help for storing an appliance
  16. Important Disclaimer
  17. I dropped something down the lint filter area....help!
  18. Inglis, Whirlpool and Kenmore most common style dryer - how to take apart ( lint filter on top )
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show( lint filter on top )
  20. Whirlpool or Sears dryer with heater on the floor and four rollers for drum style - take apart helps ( lint filter in the door )
  21. Inglis, Whirlpool and Kenmore electric style dryers - no heat problems
  22. Inglis, Whirlpool and Kenmore electric element changing procedures
  23. Inglis, Whirlpool and Kenmore dryers - air flow
  24. Inglis, Whirlpool and Kenmore style dryers - noise problems....drum rollers and idler pulley information....
  25. Inglis, Whirlpool and Kenmore style dryers - belt change
  26. Inglis, Whirlpool and Kenmore dryer general motor problems
  27. Inglis, Whirlpool and Kenmore gas style dryers - no heat problems
  28. Inglis, Whirlpool and Kenmore dryers - where are my thermostats
  29. If your drum belt looks like either of these....change it!!
  30. Idler pulley slide troubles with newer Whirlpool build Roper dryer
  32. Newer style Whirlpool - Inglis - ( some ) Kenmore dryer front drum support ring install help
  33. Pilot flame help
  34. Sample wiring diagrams
  35. Test for ohm meter checking on electric dryers with no heat
  36. Taking apart an Duet or HE3 dryer for a belt change
  37. Taking apart a Whirlpool Thin twin washer/dryer to replace the belt
  38. Timers and some common Auto dry troubles and solutions
  39. What is a grounded element?
  40. Whirlpool - Kenmore dryer motor problems in the dryer with Even HeatControl....info on this is here + new25.gifExpanded repair helps for a common "Even Heat" dryer
May 15, 2009 | Whirlpool GGQ8831L Gas Dryer
Whirlpool gas dryer turns on drum spins exhaust is clear and blows air but it wont ignite
  8. Gas dryer smell
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show ( lint filter on top )
Mar 30, 2009 | Whirlpool LGR8648L Gas Dryer
Dryer not heating
It it blows cold air it is a faulty element or a faulty thermal fuse, this parts should be tested and eventually replaced.
See There's no heat
Dec 02, 2008 | Whirlpool LER4634J Electric Dryer
Dryers Logo
594 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
