Question about Nokia N95 Cellular Phone
SET THE LOCK FEATURE FOR A SIM CARD CHANGE BUT FORGET CODE
NOKIA N95 8G
Online chat
Go into ur phone settings, security settings, phone and sim. Scroll down to lock code.
To change the code to ur own, select it, and it will ask for the default lock code which is 12345. Once confirmed, it will ask u for ur new code which can be
4 or 5 digits. Pick something u wont forget. Then it will ask u to confirm it.
Done.
Now if ur phone has an autolock feature, u can set it by selecting it and selecting user defined and set a time, like 10 or 15 minutes, up to u. Ur phone will lock after
that set time of inactivity. U will still be able to take calls, but need to put the code in to do anything else. Code will be requested each time u turn ur phone on.
Depending on ur nokia, u may have remote lock feature. With this, u set a password, and if ur phone is stolen and ur worried that it hasnt autolocked, u can send that
password to ur phone from any other phone by sms and it locks it.
U may also have the feature to have the phone lock if the simcard is changed and u can enable that too.
Finally, u have pin lock. This locks ur sim card, even if a theif takes it out and puts it in another phone, the code will be required to use ur sim.
To change the pin code, its the same as the lock code change, but the default code u need to put in first is different. Its usually 00000 but if that doesnt work, select
cancel, and call ur service provider, they will give u their sim pin default code, and after uv done that, select pin request on, and it will ask for a code every time u
turn ur phone on.
Its a good idea to make ur pin and lock code the same so u just enter them consecutively on start up
Hope this helps. [answer taken from Yahoo.answers]
Jan 22, 2014 | Nokia Cell Phones
I forget mt my Nokia 6300 security code. please help me
if you not lock the systum which asking did want lock ever sim change or no if you did not please change your sim card it well open other wise wait i have also this porblem in Nokia N95 GB
Apr 08, 2010 | Nokia 6300 Cellular Phone
Reset code for nokia e61
This is a pin code that locks the sim card until you enter the correct code. This protects your account, even
if your sim is put into another handset. The default code is set by the Service Provider (often 0000 on
. You can change it if you like, but make sure you don't forget the new code.
Aug 03, 2009 | Nokia Cell Phones
Lost my Security code on my Nokia N73me
ur default code is 12345. but if changed ur master code is 0446524363. try by it. or u can visit www.nokiaunlokecode.com
Jul 25, 2009 | Nokia N73 Cellular Phone
Lock code N70
i forget my nokia n70 lock code
May 28, 2008 | Nokia N70 Cellular Phone
How can i change security code which i forgot nokia 3110 classic?
SIM pin code:
if your sim is put into another handset. To reset it, you need the PUK code:
Pin Unlock Code (PUK)
If you miss key (or forget) your SIM pin code, and enter the wrong one 3-5 times in a row, the SIM will lock up, and you’ll need to enter the PUK unlock code to release it. You should ask your Network Service Provider for this code when you need it. Don’t try to guess it, because after a few wrong guesses, the SIM card will be permanently disabled.
Phone Security Code:
This locks the handset, as opposed to the sim card. You can also set some handsets to only accept a “new” sim if the phone security code is entered. To reset it, you need the Master code code:
Master Reset Code
Sometimes known as the Master Code, this allows you to unlock a handset if you have entered the Security Code wrongly too many times.
Which is the one that you want?
The default security code for Nokia is 12345
Apr 23, 2008 | Nokia 3110 Cellular Phone
Unlock Nokia N95 8GB
plz give nokia n95 master cod
Apr 05, 2008 | Nokia N95 Cellular Phone
Forgot lock code nokia n73
i lost my lock code how to clear it
Mar 27, 2008 | Nokia N73 Cellular Phone
Help nokia n73
Well, the good news are the Master Code is correct for your phone. The bad news are:
SIM PIN Code This is a pin code that locks the sim card until you enter the correct code. This protects your account, even if your sim is put into another handset. The default code is set by the Service Provider (often 0000 on Vodafone, 7890 on Virgin). You can change it if you like, but make sure you don't forget the new code.
Phone Security Code This locks the handset, as opposed to the sim card. Some phones will accept incoming calls with this lock enabled, but many require the code to be entered even to answer a call. You can also set some handsets to only accept a "new" sim if the phone security code is entered. The default code varies according the handset make and model. You can change it if you like, but make sure you don't forget the new code.
Special Code/Service Provider Lock Code This code is required to allow a phone locked to a particular network's sim cards to be used with a sim card from another network.
The unlock code varies from individual handset to handset.
Which one is it?
The Master Code is used when you have entered your Security code wrongly too many time. The phone requests it, you leave your phone alone for about 10 minutes, then enter the Master Code.
If you want to unlock the network lock, I need to know the Country you're in and the network you're on.
Then I'll send you the codes.
Feb 25, 2008 | Nokia N73 Cellular Phone
Nokia N95 Cellular Phone Logo
57 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
