Question about Cub Cadet Street Sign- tractor lawn riding mower parts
I have a Craftsman LT 1000 17.5 hp. replaced the battery and cleaned all the cables but it only will turn over once then seems like the battery is dead but in a minute or so it will turn over 1 time again
  • 33 Answers
Sounds like your starter is weak or either your making poor contact across your solinoid. Try the solinoid first and if that doesn't fix it then try the starter.
Posted on Jul 22, 2009
My craftsman lt 1000 lawn tractors starter keeps overheating
check the battery cables bypass them with jumper cables to test them that engine needs alot of amprage
May 13, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Hard to start
First I would suggest making sure your battery is completely charged and is in good working order. Have a "LOAD TEST" done on the battery.
Second check and clean all battery connections
If this does not help then you may have a bad starter drive and need to replace it
Mar 31, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a craftsman Lt 1000, 17.5 hp tractor. It
Check for cracked fuel lines, plugged fuel filter, if all ok, then check fuel pump.
Mar 14, 2010 | Craftsman 24 Hp 48" Deck Yard Tractor
I have a craftsman lawnmower lt 2000 42 deck which i tunded up last year and replaced the battery. this season i took out the battry and stored it in my garage. I recharged the battery and put it back in...
Try tracing the positive battery cable from the positive side to the solenoid
to make sure those connections are clean and tight. Then from the solenoid to the starter. Clean and tight. Last of all please check the Ground to frame connection.
Mar 11, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
My LT 2000 lawn tractor starts to turn over but turn once than stops. What is wrong?
Dead battery ... replace it ... at best, you will only get 2 years out of this size battery.
Mar 08, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a Craftsman LT 1000 riding mower that just quit running. Won't turn over or anything. Manual suggests checking fuse as one of the options. Only problem is, I can't find the fuse! Manual says it is...
Start with the easiest thing first !
1) jump start the battery from you automobile, or install a charger for an hour. This will tell you wether you battery or connections are good.
If it started with the jump, before you replace a battery:
2) clean the cable ends and make sure cable hardware to battery posts are good and clean.
If it started with the jump, then you know the fuses are good.
If it did not start with the jump or cleaned and charged battery,
3) check the in-line fuse. Located between the key switch and the solenoid, in the wiring harness, normally behind the firewall behind the engine, or in front of the dash close to the fuel tank (if the battery is under the seat)
4) some Sears tractors use a 'relay' also located on the firewall.
Note: for now, let's see how this works. Let me know if you need further assistance. It can get more complicated, but let's keep it simple for now. rwvanlue
Nov 12, 2009 | Craftsman Garden
Need a blade engagement cable diagram for a 2002 craftsman lt1000
as far as i know, there is no diagram available for the cable replacement. it is covered briefly in the owner's manual, but the best way to do it is to study carefully how the old one is routed, and replace a step at a time
Aug 06, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman LT 2000, model # 917.272234. When I am
what is happening tom is the blades are cutting more than the deck can discharge (spit out) try changing the mowing deck to a higher setting & try that if that works then that is the problem also try cleaning out the top & botton of deck there could be alot of old grass caught under there causing some of it aslo if i can further help e-mail me wade at wadembly@aol.com
Jun 26, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
240 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
