Question about Saeco Odea Go
Not working. Power on but shows a red flashing exclamation. Doesn't start making coffee.
Hi! I'd like to ask for help with my Saeco Odea Go V2 that suddenly has stopped working and shows a flashing red exclamation. Looking for some info in the internet I found some disassembly diagrams and some how-to videos. I've realized that the problem is in the coffee brewing unit and have disassembled it following the diagrams to see how it actually operates. I've also activated the Test Mode and operated the brew unit so I noticed that I can put the brew unit all way up. The upper light flashes when it reaches the top but the problem is that a second after it starts its movement from the lower point the exclamation light also flashes and keeps flashing until I put the brew unit back down. It stops flashing a second before it reaches the bottom point and the lower light flashes once. So I've noticed that the trouble is on the lower switch of the two ones that interact with the big gear that moves the brew unit, but I've checked it with a electronic tester and it seems to be working properly, opens and closes the electric circuit when I manually operate it. The upper switch seems to be a limit switch one that stops the brew unit movement in both directions, lifting and lowering. But I don't know exactly what the lower switch is for. I think it could be pre-end switch to change the speed of the movement or so... The fact is that if it is NOT OPERATED (moving or upper point) the exclamation flashes showing the error and the coffee machine doesn't work at all. If it is OPERATED INDEED (only near or lower point) the exclamation stops flashing. May it be causing problems because of a software malfunction or any other matter? I've managed to repair the coffee machine by putting an adhesive tape that blocks the switch as always operated cancelling its function. Not a very stylish solution thought ;- but at least it works!!! Can anyone please give me any clue about the real function of this switch or a way to repair this coffee machine? Thanks everyone for reading and for your help!!!
  • sebbaz
    sebbaz Apr 17, 2017
    Hi, thanks for the workaround: blocking the lower sensor. I have the same issue. Did you troubleshoot the cause since 2016?
  • Francisco Apr 30, 2017
    Hi! Really? Same problem? Happy to hear it was useful for you. I haven't been able to get any other solution, but can say that it is still working properly, so not so a bad fix at least... Hope it can help others!!!
    Habit-Forming:
  • Saeco Expert
  • 151 Answers
Did you try to put grease on the brew unit to make it movement easy?
Posted on Apr 30, 2017
Testimonial: "Grease was not needed as the movement is done easily. Seems to be related with the electric signal of the lower sensor... I'm starting to think it may be a pre-programmed obsolescence fail :("
SOURCE:
EsWorld
  • 1618 Answers
SOURCE: The machine was working fine until the trouble
Sounds like the brew unit is blocked, check the screen under the red O-ring.
Posted on Mar 08, 2010
  • 81 Answers
SOURCE: Coffee not brewing after grinding
After grinding did you hear the brew group goes up and pump start? If you hear the pump start and stopped, itis blockage in the brewunit metal screen. Just needs cleaning.
If you don't hear the pump starting, the problem is with the faulty micro switch inside the gearbox , that is behind the plate of brewunit.(service center job)
Posted on Apr 15, 2010
kapishtech
  • 2272 Answers
SOURCE: "Saeco ODEA GO" red light
The sensors on these machines can be a little temperamental, so we often see them in for warranty repair because of this.The water level sensor is a white rectangular piece (1" x 1/2" x 1/4") located between the water tank and the grinder. Check out.Keep updated.Thanks.
Posted on Sep 02, 2010
EsWorld
  • 1618 Answers
SOURCE: My SAECO Talea Giro is not working. I have cleaned
The thing that comes to mind is the brew unit is blocked and or the grind is too fine. Remove the brew unit and clean the screen under the red o-ring.
Posted on Aug 09, 2011
  • 81 Answers
SOURCE: saeco odea does not brew. coffee beans will grind,
Hi...Keep on grinding until the Auto Dosing System readjust the amount of grind to be in the optimum. Normally it takes 3 to 4 grinds. Whenever we change the type of beans, this condition happens, it is not a problem.
Posted on Aug 30, 2011
Saeco coffee machine with a red blinking exclamation point light won't make coffee, how do I fix it?
When the red exclamation point is flashing slow, something is not where it is supposed to be, bean hopper lid, door, brew mech, water tank empty, dregs box or water tray on dregs container is full. If the red exclamation point is flashing quickly, open the steam valve for pump priming. If pump turns on, and water passes correctly, the light should go off and return to heating stage. If not, we have a blockage or a pump that is not working correctly.
Nov 16, 2015 | Saeco Odea Giro Plus Coffee Maker
Saeco Eclipse stopped functioning
Have you solve your problem with Odea. Mine is new out of the box and not working at all. Red light blinking, manually prime it and so far only tree cups of coffee. After priming it the green light was solid and could make 3 cups then stopped. Any advise greatly appreciated.
Dec 12, 2011 | Saeco Odea Go
If I want to leave my Saeco Odea Go turned on for a few hours I am not able to make any coffee and I am getting a flashing green light unless I turn off the machine and start it again. What is the problem?...
hi,
when the machine is On for long time ,it going in the STAND BY MODE-green light is flashing slowly.Just press coffe button and wait for a 10 seconds.
When the red light is ON and no flashing it is mean there is no water in the water tank or too much water in the drip tray.
Dec 29, 2017 | Saeco Odea Go
Saeco Giro II Red Light stays on, even after removing watertank, dredge drawer and brewing unit, and replacing. Red light does not flash after removing dredge and brew unit.
Had the same problem, if you used steam or hot water, make certain the steam knob on top is all the way back in the close position, if not the red exclamation sign will stay lit.
Dec 12, 2010 | Saeco Odea Giro Espresso Maker -...
Flashing Red bulb
That is the descale light, you should run a descale through the machine. After you have done that hold on the water button and the descale light will go away
Jun 26, 2010 | Saeco Odea Go
New Saeco Odea Giro machine not working
That is the machine is saying to empty the drip tray, pull out the tray on the side and wait until the red light start flashing then put back the tray.
Dec 24, 2009 | Saeco Odea Giro Plus Coffee Maker
What does it mean when the red exclamation mark light is flashing?
Either you need to prime the pump, or the brew unit is not in correctly, the steam knob is not in the right position, the tray is missing.
Sep 20, 2009 | Saeco Odea Go
New Saeco Odeo Go has solid red exclamation mark, doesn't budge
You have to 'manually' prime the pump: When the red exclamation mark shows, press the water switch on the right side (the picture of the water drip), then open up the steam nozzle and let the machine pump hot water into a cup until the red light goes out.
Jun 11, 2009 | Saeco Odea Go
Saeco odeo giro and the red squiggly light
This is the descaling indicator.
If it flashing your machine needs descaling.
Feb 22, 2009 | Saeco Vienna De Luxe Espresso Machine
Saeco Odea Go Logo
304 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Pierre Laplante
Ray Murphy
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
