Question about American Standard Kitchen Faucet 6310 020 White Easy Touch Pull-Out Kitchen...
American Standard Easy Touch 6310 kitchen faucet leaks at base
I called American Standard and was sent an internal body & seal to fix the problem. They said there would be instructions and it was an easy fix. No instructions. I removed the handle, escutcheon cap, and cartridge, but I can't get the body out in order to replace the internal body & seal. The 6310 is a one handle with pullout spout. When I sent AS an email requesting instructions, their "contact us by email" redirected me to Faucets Direct! FD told me to contact AS. I hope someone can help me.
  • 297 Answers
You must remove the faucet form the sink. under the plate in the middle is 2 screws. remove the screws to remove the body.
Posted on Jul 15, 2009
Base of faucet leaks- cannot remove set screw at handle American Standard Elite kitchen faucet series 4453
if you are having trouble removing the set screw make sure you are using the correct size allen wrench and confirm that it is a allen screw and not a trox screw. After doing this try tighten the screw slightly before loosening it. This should break it loose.
Feb 25, 2011 | American Standard Kitchen Faucet 6310 020...
I have a kitchen faucet that is leaking at the base where the faucet connects to the base. It leaks all the time. Do I need to replace the O rings in the stem of the faucet? Or do I need to replace all...
hi! if tightening the knob(s), (or if you apply pressure on the knob of the faucet,for the models with no thread for open/close), modify the amount of water leaking ,you need to replace the seats in the faucet. if not ,just replacing the o rings should fix your problem.
Feb 20, 2011 | American Standard Kitchen Faucet 6310 020...
Leaking around swivel
http://www.americanstandard-us.com/assets/documents/amstd/parts/Parts_1859.pdf
You need to replace the O-ring that seals the place it's leaking. The part number
M962303-0070A on the diagram above (click the link)
Feb 01, 2011 | American Standard Kitchen Faucet 6310 020...
Kitchen faucet single handle pull-out. The base of
I have the same problem with an American Standard Reliant Kitchen Faucet that wont swivel anymore. I called American Standard and they are sending me the replacement parts to fix it free of charge, I have had mine 6-7 years and they said it was under warranty. Call 800-442-1902. Good Luck
Jan 09, 2010 | American Standard Kitchen Faucet 6310 020...
I just replaced the cartridge, spacer, check valves and oring that sits on top of manifold and water still leaks within body of faucet. any suggestions?
SOUNDS LIKE A LOOSE FITTING , INSPECT UNDER THE TAPS FOR ANY LOOSE FITTINGS AND TIGHTING THEM UP WITH A AJUSTABLE SPANNER UNTILL WATER STOPS LEAKING.
Nov 11, 2009 | American Standard Kitchen Faucet 6310 020...
I have an american standard pullout disc faucet which is leaking. I replaced the disk. Now it is leaking more than befoe from the base. What should I do? Is it the o seal at the bottom? chuck
Chuck,
Definitely change the O ring, and ensure the disc is installed properly, as well as ensure there is no debris on the disc. It sounds like the O ring was torn during the first procedure. Good Luck.
Steve
Oct 11, 2009 | American Standard Kitchen Faucet 6310 020...
How do you change the cartrige for easy touch american standart k
unscrew a alen screw on the underside of the handle.
unscrew the cap that is holding the main body of the fixture.
pull up the fixture.
install in reverse order.
Jan 06, 2009 | American Standard Kitchen Faucet 6310 020...
We are getting a metallic taste and smell
The metalic taste is coming from the the new faucet
I would call American Standard and ask them if they have any complaints for this particular model
I would run hot water through the faucet for 5 minute intervals
If it persists I would take it back and demand a refund or cal AS and demand a refund or replacement model
I am sure the local news would like to report something like this
Jan 05, 2009 | American Standard Kitchen Faucet 6310 020...
American Standard Kitchen Faucet 6310 020 White Easy Touch Pull-Out Kitchen... Logo
1,522 people viewed this question
Top American Standard Plumbing Experts
Donni Steen
john h
TED
Level 1 Expert
Are you an American Standard Plumbing Expert? Answer questions, earn points and help others
