Question about Technics SL-1200MK2 Turntable
Tone Arm there are screws that balance the tone arm w/ bearings inside and the top two screws are loose. i would like to know hot to fix them. Because when i screw them in and tighten them the tone arm swings to one side.. Please help!!!
  • 515 Answers
It's very hard to get those screws aligned and tightened correctly. They are machine calibrated with the precise amount of torque. Once they become loose, it's very hard to get them back to original factory settings. Also, those screws are conical screws, which means they have a cone shaped tip on them. That cone shaped section sits on 4 very small ball bearings which balance the tonearm. There is a very thin piece of sheet metal which protects the ball bearings and keeps them aligned, if any of these parts are damaged, or bent in any way, your tonearm is damaged.
Unfortunately, if you can't get the balance correct, you will have to replace the tonearm. You can buy a new TONEARM HERE, however, replacing it, is a whole other process and not recommended if you have no soldering experience, as you could damage your unit even more.
Hope this helps.
- The 1200s Experts
Posted on Nov 22, 2007
I have a realistic clarinette 120 turntable . How do I replace the needle?
Most are held in place by 2 small screws, remove them and carefully unplug the cartridge from the tone arm, reverse to install new one, then check the balance the tone arm and set to correct pressure..
Dec 23, 2016 | Audio Players & Recorders
My dishwasher's top rotating sprayer keeps coming loose. The screw and plastic bearing fall out and I think that it has stripped out the end where it seats into the top of the washer. Any ideas on how to...
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy
Appliance Parts Online
heatman101
Dec 21, 2010 | Dishwashers
The drum on dryer is off balance & making lots of noise can i fix it quick
its probably not the drum it is the bearing in the rear, easy fix if you know how, open the top remove the screws holing the front on, plus a little yellow plastic piece on the top center, remove the front, take out the 3 screws located in the back center of the drum then follow the instructions that come with the new part for bearing replacement
Aug 11, 2009 | Frigidaire Dryers
Magic arm needs tightening but I can't figure it out.
loose the small hex scew on the lever side.
turn in the leverto lower the distance.
fix the small hex screw to block the lever on the bolt again.
be sure that you did not loose the 2 3/ 16"balls on the lever side and the 9 balls on the other side
good luck
Jun 12, 2009 | Bogen Communication Bogen - Manfrotto...
I balanced my tonearms correctly. i think .. but the stylus jumps off the record and when i back spin (cue) the needle skates drasticly. can you walk me through the balancing proceedure and tell me how to...
Balancing the tone arm is a two step process. Set the needle weight adjustment to zero(0) and make sure that the tone arm is balanced. It should rest horizontally without touching anything. Next, set the needle weight (usually 1.5 grams). Both adjustments should be on the rear of the tone arm. That should cause the tone arm to drop toward the record and have the correct pressure for the needle. Also, check the anti-skate adjustment. If that is off, the behavior you describe will occur as well.
Dan
Jul 21, 2008 | Technics Audio Players & Recorders
Singer Steam Press PRO9S
I have a Singer steam press Pro-9S, the top plate is loose from the screws holding the hot plate and the cover arm, I like to know how to remove the hot plate cover from the arm to tighten those screws. Thank you.
Feb 18, 2008 | Irons
Arm Looping
ive had this problem djing in front of 700 people...Not good!! i can tell you exactly what it is, the tone arm bearings are being pinched too tight or there is a tiny piece of debris in the bearing race of your tone arm or blatentley your vinyl is scratched lol.... assuming you ve set your stylus correctly and the turntable is level on both axis???? slightly unscrew the tiny screw on top of the tone arm just enough to release the pressure on the bearings inside, but not so much that it wobbles about??? happy mixing
Jan 25, 2008 | Technics SL-1200 Turntable
Technics skipping
hi fletch83.
this could be the tone arm bearings too tight,damaged or in need of a little oil.
i had a similar problem on my 1210, it kept jumping all the time,ruining my mixes! it turned out it was the bearings too tight.
unscrew the counter weight so that the arm hovers over the platter and move it to the centre with anti-skate on zero.
slowly turn the anti-skate round to three and the arm should move over to the arm rest smoothly,if it stops before the arm rest or isnt smooth theres your problem,loosen the bearing adjuster slightly and try the hover routine again until its as smooth as you can get it. it is possible,if the turntable has been transported without dust covers the bearings or the pin could be slightly damaged from knocks on the top of the tone arm assembly.
let me know how you get on or if you need any more help.
darren
Oct 10, 2007 | Technics SL-1210 Turntable
Technic SL1200 M3D
1) This turntable either has bad RCA cables or a faulty tonearm - in either case, none are easy fixes. FYI, If you use Ortofon Concorde series, they are notorious for causing faulty connections with your tonearm, and eventually deteriorate your tonearm over time. So you might want to think about changing them if you get a new tonearm put on. If you use the Technics headshell, you are fine. 2) This turntable definitely needs to have the tonearm replaced. Once the arm comes loose from it's bearings, it's next to impossible to get it back to factory specs, and you will have skipping issues. Both will require professional servicing. Check out www.1200s.com if your in the NYC area.
Sep 07, 2007 | Technics SL-1200M3D Turntable
Technics mk2 tone arm replacement
once you soldered to circuit board place - this might help Advanced Tonearm stuff Tightening the suspension on your tonearm Some TT's have tonearms which seem to be loose. If you grab the tonearm and pull it gently back and forth and it seems loose you can tighten it. It shouldn't move at all. A loose suspension can severely affect it's performance - from jumping needles to binding. It's pretty easy to tighten the suspension. You'll need a small flat screwdriver and a large one. Use the large one to loosen the outer locking screw on the top of the pivot point. Now use the smaller screwdriver to loosen up the smaller screw. Put a drop of oil where the bearings are (under that top support on the other end of the adjustment screw) so that it doesn't bind. Now tighten the small screw slowly until it just contacts the bearings. Adjust the tightness so the tonearm doesn't wiggle if you pull on it but leave it loose enough for the tonearm to pivot freely without binding. Adjust carefully and don't overtighten otherwise the bearings will be damaged! When done, tighten up the locking screw. Tightening up the headshell locking ring Have you put on your headshell, twisted that knurled tightener at the end of the tonearm as tight as possible and have found that the headshell still moves around? What will happen is that the headshell won't sit parallel to the record but may be tilted as a result of twisting of the headshell. This usually occurs when you change headshells a lot or if you've had your turntable for a while, and can contribute to needle jumping so here's what you do to fix it. First read 3.2 on base disassembly. Remove the rubber base. There will be this big piece of hard black plastic covering almost everything. You'll need to remove it. To remove the tonearm assembly look for three screws (all formerly under that black plastic) and unscrew them. Be careful not to drop the tonearm when you remove that last screw! Now, remove the tonearm assembly from the rest of the 1200, and look at the bottom of the tonearm where the headshell is put in. There will be two tiny philips screws there. Get a jewelers screwdriver of the CORRECT size and tighten those up. Put the headshell on and try wiggling it to make sure everything is right. Now put your tonearm back on and close everything back up. hope this helps peace DJ Nyce
Jun 14, 2007 | Technics SL-1200MK2 Turntable
Technics SL-1200MK2 Turntable Logo
353 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
