Question about Digidesign 003 Rack Factory Firewire Audio Interface Promo/Demo License for PC, Mac, Sun (9900-38730-02)
=My PC crashed, a short circuit problem when I kicked the power board. My laptop HP DV6000 PC with Vista was repaired, but my Pro tools Le 8 does not recognize/locate the 003 hardware anymore. The PT was on record ready mode when the short occured. I was adjusting mics. In my computed the ieee 1394 port was not recognized by the device manager, so I purchased an express card that does recognize the ieee 1394, but does not upload or use the drivers and can't get it to recognize or use the drivers. Also the "link" led light next to the firewire in the back of the 003 rack is always off now. Can you help me? Comments: Jul 15, 2009 - N, Thanks for the reply. I got an "express card" and connected it to the slot in my computer, to create a new port. It is recognized by the PC, however I can't get it to recognize the 003 rack interface when i launch pro tools. So what you are saying is that the fire wire ports in the back of the 003 were probably damaged? One thing to note is that both the PC and the interface were on two separate outlets, so I only created a circuit for the PC outlet. The only thing connecting the 003 rack and the PC is the 6 to 4 pin firewire cable. Is it possible that I also busted my two firewire outs from the 003? thanks, ale Jul 15, 2009 - My PC crashed, a shortMy PC crashed, a short circuit problem when I kicked the power board. My laptop HP DV6000 PC with Vista was repaired, but my Pro tools Le 8 does not recognize/locate the 003 hardware anymore. The PT was on record ready mode when the short occured. I was adjusting mics. In my computed the MoreMy PC crashed, a short circuit problem when I kicked the power board. My laptop HP DV6000 PC with Vista was repaired, but my Pro tools Le 8 does not recognize/locate the 003 hardware anymore. The PT was on record ready mode when the short occured. I was adjusting mics. In my computed the ieee 1394 port was not recognized by the device manager, so I purchased an express card that does recognize the ieee 1394, but does not upload or use the drivers and can't get it to recognize or use the drivers. Also the "link" led light next to the firewire in the back of the 003 rack is always off now. Can you help me? Could this also affected my fire wire ports out of the 003 rack? Both units (PC and 003) were connected to different outlets and the only connection between them was the 6 to 4 pine firewire cable.
  • 3,741 Answers
Yes it can affect the firewire ports if its a short circuit.and a 6 to 4 pin firewire cable is enough to short the fire wire ports.also it can be possible that the 6 to 4 pine wire port is faulty.it has to be checked by spare part of same type by reconnecting.if you yourself does not have this another same type of spare a local hardware repair shop work center is the best option.as they have all the required ports and wires in spare to check out the fault.
this will help.
please do rate the solution.thank you for using fixya.keep updated.thanks
Posted on Jul 15, 2009
Code spice
chang the battery or check mother board
Apr 23, 2013 | Computers & Internet
HP pavilion laptop freezes up
You didn't post the OS you are using? Start by verifying the fan and vents are clean and free of dust. Open the Control Panel, select Power Options, set to High Performance, select Change Plan settings, under Plugged in set both to never, You may have to many processes running at startup. USE CCLEANER to clean up the HDD, and it the TOOLS section, STARTUP section, disable ALL unnecessary startup programs. you can find freeware CCLEANER at: http://www.filehippo.com/download_ccleaner/ ALSO, Download freeware MALWAREBYTES at : http://www.filehippo.com/download_malwarebytes_anti_malware/ In the install UNCHECK the TRIAL PRO version, you want the freeware version, Run a FULL Scan, delete ALL results, reboot. Use this Procedures to Speedup your machine: http://windows.microsoft.com/en-us/windows-vista/optimize-windows-vista-for-better-performance AND http://howto.wired.com/wiki/Speed_Up_Windows_Vista AND http://www.pcworld.com/article/143538/windows_vista.html
Mar 15, 2013 | Microsoft HP Pavilion DV6276US Notebook PC
Describe your HP Pavilion dv6000z 15.4" Notebook Laptop PC (AMD Turion 64 X2 Duo Core TL-50 1.60GHz, 1GB RAM, 100G... (d6000z) PC Notebook Problem SCREEN WONT TURN ON LED LIGHTS OF POWER BUTTON...
The dv6000 series was commonly affected by the video card heating up and reseating itself. This was usually a soldering issue. You have a few options, You can either replace the motherboard, or have the motherboard reflowed. Unfortunately the video card itself is not detachable or individually replaceable.
I personally would recommend the second option as purchasing another dv6000 board will likely end you up in the same situation a year or 2 later.
A repair / reflow services on ebay
Dv6000 Repair
This repair tech only does amd processor models, Not intel.
Hope this helps.
Aug 29, 2011 | HP Pavilion dv6000z Notebook
I have an HP DV6700 Laptop Computer. The internal powersupply prong is loose...How can I fix it?
The laptop needs to be disassembled down to the motherboard, the power plug is not soldered to the motherboard, it is actually a satellite card attached to the motherboard via a small cable. The entire assembly can be purchased on Ebay for under 30 bucks. Below is an example of the listing. I will include a link to an illustrated disassembly guide.
Ebay: http://cgi.ebay.com/HP-DV6000-V6000-DC-Jack-USB-Board-DAOAT8TB8F2-/260636627698?pt=LH_DefaultDomain_0
DV6000 disassembly: http://www.insidemylaptop.com/take-apart-hp-pavilion-dv6000-laptop/
Aug 11, 2010 | Computers & Internet
HP Pavilion dv6000 plugged in not charging, I have a new battery.....PLZ Help.
Its the DC charging jack that you plug the charger into on one of the sides of the laptop. Do a google search, go and search for "HP dv6000 DC jack problem charging" (leave out the quotes) and you will see this is a common issue with the dv6000 and laptops in general. Many will just replace the whole laptop motherboard as the DC jack is attached to the board. If you know what you're doing, you change out the jack, quick repair job and keep your own board, but fixed. I would fix it if it were mine. You may be able to find someone local online but if you need someone to do the repair, I'm in the repair directory, as are many others qualified.
Note: It may come to a point, or the situation may just fit better to replace the entire board instead of the port alone. This is usually when the jack is not seated and easily replaceable, or if you are under warranty, HP will replace the whole board.
Mar 08, 2010 | HP Pavilion dv6000 Motherboard
How to downgrade vista to winxp pro at Hp pavilion DV4-1204TU ?
Well, this may make you think twice:
I bought a presario from circuit city last year, and I paid $200 to downgrade to XP. Everything was fine until it crashed last week. IT went completely bizzerk. HP won't provide support, cause I changed it. Circuit City is out of business, not much help there.
Basically, I am completely #$%%@@.
I am now paying to get Vista put back in. :-(
Jun 09, 2009 | HP Computers & Internet
Power led goes on and then goes off.
Some years ago I had a similar issue with an IBM and with that one the capacitor that filters out the current (right after the power jack, usually the very first capacitor that gets the power) was short circuited. It was a ceramical capacitor, at least that's how we call them here.
Apr 19, 2009 | HP Pavilion dv6000z PC Notebook
HP Pavilion laptop freezes daily and i force manual shutdown
It sound's like there could be a compatibility problem, maybe corrupt file's, or missing start up file's, have you tried doing a window's update, or doing a disc check on the hard drive, go to my computer right click the drive then go to propertie's, click on tool's then click check now for drive error's. if that do'es not work you may need to reformat back to the original xp os.
Apr 16, 2009 | HP Pavilion dv1000 Notebook
Digidesign 003 Rack Factory Firewire Audio Interface Promo/Demo License for PC, Mac, Sun (9900-38730-02) Logo
52 people viewed this question
Top Digidesign Computers & Internet Experts
ali_zulfikar
ali_zulfikar
Zhenya Ogorodnikov
Are you a Digidesign Computer and Internet Expert? Answer questions, earn points and help others
