Question about Mitsubishi VS-50603 50" Rear Projection Television
Won't turn on
My mitsu vs-50603 manufactured in 12/98 will not power on. the green light on the front panel is on all of the time. nothing happens when power is pushed on set or remote-----no sound or noise from the set at all.
  • srainess59 Jun 18, 2008
    Same thing here.. Was told to contact local technician from Mitsubishi. Green light is always on. Unplugged it, etc....
  • 927 Answers
Good Day, Check these two areas: 1. CHECK IC700 PIN 4 (AC-OFF) FOR 0 VOLTS DC, IF HIGH, CHECK FOR LEAKY D980 PART # 264P045040 ON THE MAIN PCB. 2. CHECK FOR 4.7 VOLTS DC AT CONNECTOR RF PIN 3 AND 4 ON THE SIGNAL PCB IF LOW SUSPECT PROBLEMS WITH THE SWITCHES/BUTTONS ON THE CONTROL PCB PART # 935D394001. 2). CHECK FOR 10 VDC AT PIN 5 OF IC502 OF LOW, CHECK IC503 PART # 270P704010 ON THE MAIN PCB. 2. CHECK R529 .82 OHM 1/2 WATT OFF PIN 4 OF THE FLYBACK. IF OPEN CHECK C411 2200 UFD @ 35V AND IC 451 PART # 270P064020. ON THE MAIN PCB. Good Luck, big IRISH.
Posted on Aug 31, 2008
Mitsubishi Projection TV Model #VS-50603 will not turn on.
The TV is going into a "protect mode", the micro-processor has sensed a circuitry problem and has shut the set down so that no furhter damage can happen, you will need to have the TV serviced by a Mitsubishi tech. Good luck !
Jan 07, 2010 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi Proj. TV,Model VS-50603, S/N 119340, won't turn ''ON'' when pushing TV ''ON'' button or remote. Green ''ON'' light comes on and then immediately off. Whats the problem?
62" mitsuabishi WD62525 had it over 5yrs now, we have been changed lamps three times,(geee lots money!!!)it worked ontill now...
two weeks ago blinking red lamp light was on , i thought lights out again so soon, i order new lamp, i cant turn on TV but blinking green timer light, TV is not working, try reset botton, turn off TV few days.
Please help
Lilly
Dec 06, 2009 | Televison & Video
Mitsubishi VS-50603 Wont Turn on
The power supply will need to be changed. The capacitors inside the power supply are not sending the correct amount of power to tv and will need to be changed.
May 13, 2009 | Mitsubishi VS-50603 50" Rear Projection...
I have a Mitsubishi VS-50603 that will not turn on.
Good Day, jessayala;
It sounds like you may have Ethylene Glycol on the boards, leakage from the TV's CRT's. The Glycol is a fluid that help's the tube cool. If you are not handy, very, very handy, I would call an Authorized Service Center to come out and give you an estimate before the repair is performed.
Good Luck, big IRISH......PS..... If can handle your self ..... come back here.
Aug 28, 2008 | Mitsubishi VS-50603 50" Rear Projection...
MITSU VS - 50603
Good Day, wecalvin;
Suspect fluid on the PCB's.To find suspected liquid on the PCB's, remove the front speaker cover and the small board held on by 5-6 screws. Look at the first 3 to 5" on the PCB. Use bright light it's not always easy to see. If fluid is spotted remove the boards from the back of TV. Use small brush, like old tooth brush, and acetone. You can get acetone from hardware stores
Look for rusted wires or parts and replace as necessary.
Aug 05, 2008 | Mitsubishi VS-50501 50" Rear Projection...
My Mitsu WD-62628 will not turn on
It is probably by coinsidence that the set has failed. I doubt it was from the house cleaner. The set most likely failed on its own. The power supply is a common fault in most LCD screens when they fail. Sometimes a failure can occure on any of the other boards, and thus cause a fault in the power supply.
Jerry G.
Apr 16, 2008 | Televison & Video
Mitsu. VS-50707 problems
12 = No error detected, check power supply.
check all your voltage coming out of the power supply and check the fuses.
Dec 10, 2007 | Mitsubishi VS-50707 50" Rear Projection...
Mitsubishi WS-48513
I had a similar problem with my 55' WS Mitsu TV. Their are a number of capacitors inside the TV that were blown (top of capacitor had a convex appearance). TV repair man replaced the capacitors. Ran about $300 for the repair (done at my house).
Apr 10, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS50603 will not turn on
If you are not a tech the tv needs to go to a tech to be fixed.the probleis in the power supply or related circuit good luck.
Apr 01, 2007 | Mitsubishi VS-50603 50" Rear Projection...
Televison & Video Logo
123 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
