Question about HP PSC 2410 All-In-One InkJet Printer
Cant receive fax's only can send
Was receiving faxed fine earlier today on my hewlett packard officejet k80, now just receiving error reports with error #'s 232, 394, 423,
    President:
  • HP Master
  • 566 Answers
ECM error message
Noise in the phone line, or low signal strength during fax transmission can result in fax failures. Noise or poor signal strength can cause a partial or complete loss of fax information during transmission. When Error Correction Mode (ECM) is on, the receiving fax machine checks the fax information for errors during reception. If the receiving fax machine detects an error, the receiving fax requests that the sending fax resend the information. Resending all or part of the information can make transmission times longer, but helps improve the quality of the received fax.
If the phone line quality or signal strength is extremely poor, sending a fax can fail. Turning off ECM can improve the ability of the product to send a fax successfully when the phone line quality is poor. However, the image quality of the received fax might be poor.
If ECM must be off to send faxes successfully, have the telephone service provider check the phone line quality. For an HP Fax, turning off ECM from the control panel does not necessarily mean that fax transmission will not use ECM. Fax products use ECM as follows.
  • All faxes sent in color use ECM.
  • All faxes sent at the highest transmission speed use ECM.
  • The ECM setting affects only sent faxes, not received faxes.
Enabling or disabling Error correction mode (ECM)
  1. On the product control panel, press the Menu button (c01743394.gif ).
  2. Use the arrow buttons (c01073166.jpg ) to select Basic Fax , and then press the OK button (c01335940.jpg ).
  3. Use the arrow buttons (c01073166.jpg ) to select ECM Mode , and then press the OK button (c01335940.jpg ).
  4. Use the arrow buttons (c01073166.jpg ) to select On or Off , and then press the OK button (c01335940.jpg ) to confirm the setting.
  5. Press the Back button (c01496476.gif ) twice to return to the main screen.
Mar 06, 2014 | HEWLETT-PACKARD HP 2140 Fax
HP M1319F Stop Printing Fax Error Reports.
go to the fax repots,conformations,their u select send only.
Dec 02, 2011 | HEWLETT-PACKARD LaserJet M1319F All-In-One...
Can send faxes, but no fax tome coming on when the number is called
that's right,you would be able to send fax,but wont be able to hear the fax tone,your fax ring shoud be 2 rings higher than answering machine,or else,do 1 thing when you hear the ring,just pick up the receiver u wud be able to hear the fax tone,do not disconnect the call,just keep the receiver aside without disconnecting,and then press start fax...you will be able to receive fax...........
Aug 25, 2009 | HP Hewlett Packard Officejet Pro L7680...
Error message on my Hp Officejet J6480-Fax log full
Press the Setup button (c01361401.gif ).
  1. Press the Right arrow button (c01185072.jpg ) until Tools displays on the control panel, and then press OK .
  2. Press the Right arrow button (c01185072.jpg ) until Fax Log displays on the control panel, and then press OK .
  3. Press the Right arrow button (c01185072.jpg ) until Clear Fax Log displays on the control panel, and then press OK . A message that says the fax memory is clear displays on the control panel.
  4. Press the Cancel button (c01235250.gif ) to exit.
Hope this helps
Feb 23, 2009 | Digital Products Hewlett Packard OfficeJet...
Error is fax full cannot send or receive. Please help !! Hp J6480
I have not found the answer to this in the manual however, you may solve the problem in the following steps:
1. From the Setup menu, choose #6 Tools
2. Choose #6 Clear fax log
Problem solved! Hope you found this answer helpful.
sg
Feb 18, 2009 | Digital Products Hewlett Packard OfficeJet...
01.12.2008 i fax to one number. now i want aknowledgement of that fax. its gone or not. How i can find on HP Officejet 5610 all in One System?
You can get the manual here if you do not have one - LINK.
Here is an exert form the manual on this:
Print fax confirmation reports
If you need printed confirmation that your faxes were successfully sent, follow these
instructions to enable fax confirmation before sending any faxes. Select either On
Fax Send or Send & Receive.
1. Press Setup.
2. Press 2, and then press 1.
This selects Print Report and then selects Fax Confirmation.
3. Press to select one of the following, and then press OK.
Off Does not print a fax confirmation report when you send and
receive faxes successfully. This is the default setting.
On Fax Send Prints a fax confirmation report for every fax you send.
On Fax Receive Prints a fax confirmation report for every fax you receive.
Send &
Receive
Prints a fax confirmation report for every fax you send and
receive.
Dec 10, 2008 | HP Officejet 5610 All-In-One InkJet...
Cant hook up HP (Hewlett-Packard) Officejet J4580 All-In-One Printer in order to send and receive fax from standard phone line
Usually pluging the unit into a phone jack with a standard phone cord is all that is needed to send and receive faxes. You may have to set a switch on the device to switch from manual to auto fax receive. For more detailed instructions go to this page:
http://h10025.www1.hp.com/ewfrf/wc/product?product=3645100&lc=en&cc=us&dlc=en&submit.y=10&submit.x=4&lang=en&cc=us
Nov 10, 2008 | Office Equipment & Supplies
How do i retrieve fax report from hp 4215 all in one
1 Press Setup.
2 Press 1, then press 1.
This selects Print Report and then selects Automatic Reports Setup.
3 Press ! to scroll through the following report types:
– Every Error: prints whenever there is any kind of fax error (default).
– Send Error: prints whenever there is a transmission error.
– Receive Error: prints whenever there is a receiving error.
– Every Fax: confirms every time a fax is sent or received.
– Send Only: prints every time a fax is sent.
– Off: does not print fax reports.
Note: If you select Send Only, you will also receive error reports if there is
any kind of error generated.
4 Press OK to select a report
More information? you can download manual here
http://h10032.www1.hp.com/ctg/Manual/c00095626.pdf
Sep 05, 2008 | HP Officejet 4215v All-in-One Printer
Confirmation page
You can configure your HP all-in-one so that it automatically prints error and confirmation reports. If you need printed confirmation each time a fax is sent, follow these instructions before sending any faxes and select Send Only. To set automated report options from the control panel Press Setup. Press 2, and then press 1. This selects Print Report and then selects Fax Report Setup. clip_image001.gif Press to scroll through the following report types: Every Error: prints whenever there is any kind of fax error (default). Send Error: prints whenever there is a transmission error. Receive Error: prints whenever there is a receiving error. Every Fax: confirms every time a fax is sent or received. Send Only: prints every time a fax is sent indicating whether the fax was successfully sent or not. Off: does not print any error or confirmation reports. Press OK to select the report.
Jul 29, 2008 | HP OfficeJet 6210 All-In-One InkJet...
HP PSC 2410 All-In-One InkJet Printer Logo
316 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
