Question about Sony FD Trinitron WEGA KD-36FS130 36" TV
Rolling screen! I need to know how to adjust the verictal and horizontal lines on my Sony Trinitron WEGA.Thanks
    Genius:
  • Sony Master
  • 1,689 Answers
The sync is automatic and controled by the uPC. It is strongly not recomended to mess with the factory service set-up. There are no so-called user adjustable controls for the horizontal and vertical frequency on this model.
The fault is usualy failed components in the sync seperator and sync amp sections.
An experienced TV tech can troubleshoot this and replace the necessary parts for you.
Jerry G.
Posted on Apr 19, 2008
KV-HP212M83 greenish blackout blinks 2 times
Measure B+ on the set , If normal check G2 voltage
G2 adjustment is on the Flyback Transformer
Oct 14, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
When i put my tv sony trinitron on, i hear the sound for 15sec en then the tv go out en de leds blanks
Hello
There is some sort of indirect short inside your TV. It is in the main circuit board. Most of this kind of fault in Sony Tvs are related with horizontal output stage. You just replace the horizontal output transitor [which drives the Line Output Transformer] of your TV first. If the transitor is leaky, the above said falult may occur. If it doesn't help Line Output Trnasformer [LOT] may need replacement. Check whether the replaced transistor overheats within seconds or minutes. If it overheats the LOT is faulty. Ok.
Oct 18, 2010 | Sony FD Trinitron WEGA KD-36FS130 36" TV
The screen is rolling. The frames are rolling and I can't find anything on the trinitron to stop it like we used to have on even older tvs. There used to be dial or something where you could stablize the...
The first one is to check variation of power supply out puts. meaning power supply is not giving constant voltage outputs. Mostly caused capacitors changing values.
If the power supply tests okay, then check second option, the capacitors around the line transformer. A line transformer is a round transformer with a red cable going to a tube of your tv.
Oct 04, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Picture shifted to the left
Check the horizontal circuit visual check for any burned coils or Inductor. check also the ceramic capacitor in that area.
Jun 02, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Fine interference lines running diagonally across picture.
Hi There,
Sounds like your Horizontal Output Circuit is leaking current causing diagonal lines across the screen. I hope this will help and thank you for using FixYa!
Mar 29, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Top of screen slants on the right and left side horizontally
go in touch with SONY i assume ur set is still under warrenty.....call customer help and support
Mar 12, 2009 | Sony FD Trinitron WEGA KV-36HS420 36" TV
I have a KV27FS210 sony wega trinitron tv. It turns on and has a single horizontal line across the center of the screen then buzzes shows a continuous zigzag line from the top to bottom of the screen with...
The single horizontal line is a problem with the vertical circuit. Look for a small flat id attached to a heatsink that should be marked LA7837 or something similar. Try resoldering the pins of this IC first. If that does not resolve it, replace the IC.
Keep us posted.
Dan
Feb 20, 2009 | Sony FD Trinitron WEGA KV-32FS100 32" TV
WHITE horizontal lines across screen
You need to adjust Screen voltage (decease a bit) to disappear white lines on TV. If you want to do it yourself, let me know to help you further.
Regards,
Aug 13, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Sony trinitron
the problem is that the horizontal blanking pulse wont tun off during horizontal retrace period. the problem is in the IC. that process the TV signal.
Apr 10, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA KD-36FS130 36" TV Logo
138 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
