Question about Canon PIXMA iP1500 InkJet Photo Printer
Waste toner receptical problem
I keep geting a message saying the waste toner receptical is almost full but I can't find the waste receptical.
    President:
  • 2,306 Answers
The waste ink absorber is inside under the printer, you need a shop to replace them and reset the counter.
Posted on Aug 07, 2009
Message on screen says "Waste Toner Box Full"
Typically you will need to replace the waste toner box. There is usually a difficult to access part of the bottle that is used by an optic sensor to tell when the box is full. Plus toner is very fine and you do not want it getting into the air. Toner will pass through the filter of most vacuums and go back into the air.
Dec 12, 2015 | Kyocera FS-1035MFP
Waste toner bottle full so replaced but will not reset and says still full
then the clear section of the waste toner bottle is not clear some toner is left blocking the sensor that monitors the waste toner level
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Apr 02, 2014 | Konica Minolta New Bizhub C25 Color Laser...
WASTE TONER IS FULL ERROR
You have to empty out the waste toner bottle... The bottle is a milky white plastic and I believe it is right under the fuser unit. It should slid out toward you. Carefully dump the toner out of the bottle into a plastic garbage bag and re install the bottle and you are done....
Dec 07, 2012 | Ricoh 4506 Copier
Changing waste container
The is no waste container on Phaser 6500. There is a "waste collection box" in every toner cartridge and the waste toner is discarded along with the empty cartridge. The is also a waste toner reservoir on the transfer belt and this one will be replaced along with the transfer belt.
If there is an error message saying, for example, "Waste Full Cyan Cartridge", it means the waste toner counter reached the replacement value for that color and you have to replace the corresponding cartridge. But the waste collection box is not really full.
Sep 30, 2012 | Xerox 6500/N Phaser Laser Printer
Xerox 7120 waste toner error ...
The trick about cleaning out the waste toner container is you have to also swab out the clear plastic piece the optical sensor reads so the device knows the waste toner is full. Clean that out and you should be able to get more than a weeks usage out of the waste toner container.
Hope this helps.
Aug 23, 2017 | Xerox Office Equipment & Supplies
I have a Canon Image Writer 2020. I am geting an
waste toner is full.replace the whole drum unit
Mar 03, 2010 | Canon imageRUNNER 2000 Copier
I dispose of toner and still keep getting messages
I assume when you say you dispose of toner you are emptying out the waste toner bottle and putting it back in the machine. if so here's your problem.
There is a sensor, mounted to the copier, just behind the waste toner bottle (on the upper righthand side). This sensor shoots a beam of light through a small portion of the waste bottle - if the beam is not received on the other side then the copier thinks the waste bottle is full. NOW...even if you have emptied it the interior of the bottle may still be dirty/black enough (leftover residue) to stop the beam from making it through the bottle - this gives you the message. You will need to put in a new bottle.
Jan 23, 2010 | Toshiba e-Studio 350 Copier
Lanier LW324 waste toner bottle full
Open the machine and to the right under the drum you should see the the black powder (toner) going down into container the right lower side  cover must come off. probably a service call will be needed
Apr 20, 2009 | Lanier Office Equipment & Supplies
Copier ha a message that says replace toner drum.
It means that the internal drum unit is full of waste toner and that the drum is worn out too. The people at cannon made the drum unit to last when the waste toner internal compartment is full.
When you buy a new drum the instructions are in the box and very easy to install.
hope it helps
Mar 24, 2009 | Canon ImageRUNNER 1670F Copier
Imagerunner 2016, waste toner full error message
hey, wel if the copier is showing a message saying that the waste toner is full it means the waste toner deposit is attached to the drum unit.
so, open up the frotn cover, pull down the (drum)-lock lever, it should release the left cover, then pull towards you the drum unit, and there you go.
the black case with a small trasparent cap is the waste toner deposit.
you have two ways to go.
1 you may remove that rounded transparent plastic cap and be able to vaccum the waste toner (dont even try reusing that toner, it wont work ok) or
2 you can go the other way wich allows you to easily vaccum it: remove the drum (the roller itself) then the charger roller, then the cleaning blade and there yo go again, but now you got more space to vaccum and believe me it is easier this way.
an additional choice would be to buy a new drum unit gpr18 i think (check please) and forget all about vaccum-ing.
Jan 23, 2009 | Canon imageRUNNER 2016 All-In-One Laser...
Canon PIXMA iP1500 InkJet Photo Printer Logo
old marine
old marine
